S32K388 UART with Hardware flow control
seanwu
Contributor V
Dear sir,
Is there any exmple code which use cts rts in UART function of S32K388?
Thanks.
BR,
Sean Wu
PetrS
there is no direct example for S32K388. Also the RTD driver does not support setup for flow control.
You can add it by configuring MODIR register after UART initialization, assuming pins are properly assigned as well.
I shared with you an example for S32K312 within a Case you submitted, so you can refer to it.
BR, Petr
PetrS
BR, Petr
%3CLINGO-SUB%20id%3D%22lingo-sub-2253154%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K388%20UART%20with%20Hardware%20flow%20control%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2253154%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EDear%20sir%2C%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3EIs%20there%20any%20exmple%20code%20which%20use%20cts%20rts%20in%20UART%20function%20of%20S32K388%3F%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3EThanks.%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3EBR%2C%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3ESean%20Wu%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2253831%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K388%20UART%20with%20Hardware%20flow%20control%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2253831%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3Ethere%20is%20no%20direct%20example%20for%20S32K388.%20Also%20the%20RTD%20driver%20does%20not%20support%20setup%20for%20flow%20control.%26nbsp%3B%3CBR%20clear%3D%22none%22%20%2F%3EYou%20can%20add%20it%20by%20configuring%20MODIR%20register%20after%20UART%20initialization%2C%20assuming%20pins%20are%20properly%20assigned%20as%20well.%3C%2FP%3E%0A%3CP%3EI%20shared%20with%20you%20an%20example%20for%20S32K312%20within%20a%20Case%20you%20submitted%2C%20so%20you%20can%20refer%20to%20it.%3C%2FP%3E%0A%3CP%3EBR%2C%20Petr%3C%2FP%3E%3C%2FLINGO-BODY%3E
