S32K358 multicore single elf project
liyongfeng
I using S32K358 dual-core setup to generate single ELF file via Make, a download error occurs for Core2 code in TRACE32. This analysis aims to identify whether the root cause lies in the code, linker script (LD file), or TRACE32 script (CMM file).
RTD :SW32K3_S32M27x_RTD_R21-11_6.0.0_QLP04
Julián_AragónM
Hi @liyongfeng,
I do not see the initialization for the second core inside the project for core0. Can you share it? It should look something like this:
void Start_Core(void)
    IP_MC_ME->PRTN0_CORE4_PCONF &= ~(1 << MC_ME_PRTN0_CORE4_PCONF_CCE_SHIFT);
    IP_MC_ME->PRTN0_CORE4_PUPD = 1;
    IP_MC_ME->CTL_KEY = 0x5AF0;
    IP_MC_ME->CTL_KEY = 0xA50F;
    while ((IP_MC_ME->PRTN0_CORE4_STAT & MC_ME_PRTN0_CORE4_STAT_CCS_MASK) == 1)
    IP_MC_ME->PRTN0_CORE4_ADDR = (uint32)&__CORE2_VTOR;
    IP_MC_ME->PRTN0_CORE4_PCONF |= (1 << MC_ME_PRTN0_CORE4_PCONF_CCE_SHIFT);
    while ((IP_MC_ME->PRTN0_CORE4_STAT & MC_ME_PRTN0_CORE4_STAT_CCS_MASK) == 0)
Do you have CM7_1_ENABLE symbol inside project settings?
I've also sent you a private message for an example routine and training presentation for multicore debugging and single elf.
Julián
Julián_AragónM
Hi @liyongfeng,
Julián
%3CLINGO-SUB%20id%3D%22lingo-sub-2327885%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K358%20multicore%20single%20elf%20project%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2327885%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20using%20S32K358%20dual-core%20setup%20to%20generate%20single%20ELF%20file%20via%20Make%2C%20a%20download%20error%20occurs%20for%20Core2%20code%20in%20TRACE32.%20This%20analysis%20aims%20to%20identify%20whether%20the%20root%20cause%20lies%20in%20the%20code%2C%20linker%20script%20(LD%20file)%2C%20or%20TRACE32%20script%20(CMM%20file).%3C%2FP%3E%3CP%3ERTD%20%EF%BC%9ASW32K3_S32M27x_RTD_R21-11_6.0.0_QLP04%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2328131%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K358%20multicore%20single%20elf%20project%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2328131%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F184101%22%20target%3D%22_blank%22%3E%40liyongfeng%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EI%20do%20not%20see%20the%20initialization%20for%20the%20second%20core%20inside%20the%20project%20for%20core0.%20Can%20you%20share%20it%3F%20It%20should%20look%20something%20like%20this%3A%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%3Evoid%20Start_Core(void)%0A%7B%0A%20%20%20%20IP_MC_ME-%26gt%3BPRTN0_CORE4_PCONF%20%26amp%3B%3D%20~(1%20%26lt%3B%26lt%3B%20MC_ME_PRTN0_CORE4_PCONF_CCE_SHIFT)%3B%0A%20%20%20%20IP_MC_ME-%26gt%3BPRTN0_CORE4_PUPD%20%3D%201%3B%0A%20%20%20%20IP_MC_ME-%26gt%3BCTL_KEY%20%3D%200x5AF0%3B%0A%20%20%20%20IP_MC_ME-%26gt%3BCTL_KEY%20%3D%200xA50F%3B%0A%20%20%20%20while%20((IP_MC_ME-%26gt%3BPRTN0_CORE4_STAT%20%26amp%3B%20MC_ME_PRTN0_CORE4_STAT_CCS_MASK)%20%3D%3D%201)%0A%20%20%20%20%20%20%20%20%3B%0A%20%20%20%20IP_MC_ME-%26gt%3BPRTN0_CORE4_ADDR%20%3D%20(uint32)%26amp%3B__CORE2_VTOR%3B%0A%20%20%20%20IP_MC_ME-%26gt%3BPRTN0_CORE4_PCONF%20%7C%3D%20(1%20%26lt%3B%26lt%3B%20MC_ME_PRTN0_CORE4_PCONF_CCE_SHIFT)%3B%0A%20%20%20%20IP_MC_ME-%26gt%3BPRTN0_CORE4_PUPD%20%3D%201%3B%0A%20%20%20%20IP_MC_ME-%26gt%3BCTL_KEY%20%3D%200x5AF0%3B%0A%20%20%20%20IP_MC_ME-%26gt%3BCTL_KEY%20%3D%200xA50F%3B%0A%20%20%20%20while%20((IP_MC_ME-%26gt%3BPRTN0_CORE4_STAT%20%26amp%3B%20MC_ME_PRTN0_CORE4_STAT_CCS_MASK)%20%3D%3D%200)%0A%20%20%20%20%20%20%20%20%3B%0A%7D%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3EDo%20you%20have%20%3CSTRONG%3ECM7_1_ENABLE%3C%2FSTRONG%3E%20symbol%20inside%20project%20settings%3F%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22CM7_1_ENABLE.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CM7_1_ENABLE.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F378606i340290C27EE7FAF0%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22CM7_1_ENABLE.png%22%20alt%3D%22CM7_1_ENABLE.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EI've%20also%20sent%20you%20a%20private%20message%20for%20an%20example%20routine%20and%20training%20presentation%20for%20multicore%20debugging%20and%20single%20elf.%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3CBR%20%2F%3EJuli%C3%A1n%3C%2FP%3E%3C%2FLINGO-BODY%3E
