S32K358: eDMA Trigger via GMAC PPS Module for Media Clock Generation
910 次查看
sathishkumar_sunmugavel
Hi Everyone,
I'm working on media clock generation using the GMAC PPS module and plan to use eDMA to update the target time (seconds and nanoseconds) dynamically. Here's a summary of my approach:
Implementation Overview:
  1. The GMAC PTP reference clock is configured at 125 MHz, which starts the system time.
  2. The Target Time Seconds and Nanoseconds registers are updated to generate a pulse every second.
  3. PPS is configured in Media Clock Generation (MCGR) mode, which should assert the mcgr_dma_req_o signal.
  4. I selected DMAMUX source 28 – “IEEE 1588 PTP timer ch[0]”, assuming it maps to mcgr_dma_req_o[0] and thus triggers an eDMA peripheral request.
  5. The TCD is set up to copy the next target time when triggered.
Observed Behavior:
  • When the system time reaches or exceeds the configured target time, the TSTARGT0 bit in the MAC_Timestamp_Status register is correctly set — indicating that mcgr_dma_req_o[0] is asserted.
  • However, no DMA transfer is triggered; the current iteration count remains unchanged.
Questions:
  1. Is this method valid for generating periodic clock pulses using the PPS module and eDMA?
  2. Is the DMAMUX configuration (source 28: IEEE 1588 PTP timer ch[0]) correct for this scenario?
  3. Does the assertion of mcgr_dma_req_o actually trigger an eDMA peripheral request?
  4. The naming conventions seem inconsistent across resources:
    • DMAMUX sheet: IEEE 1588 PTP timer ch[i]
    • Reference Manual: mcgr_dma_req_o[i]
    • SDK Code: DMA_MUX_1_GMAC_0_PTP_TIMER_CH[i]
Conclusion:
I would like to confirm: when the system time meets the configured target time, the mcgr_dma_req_o signal is asserted — is this signal routed to eDMA as a valid peripheral request?
I have attached the sample main.c file for reference. Please have a look and let me know what is going wrong.
Any insights would be greatly appreciated.
Sathish.
标记 (1)
1 回复
874 次查看
lukaszadrapa
Hi @sathishkumar_sunmugavel
I recommend to discuss this directly with NXP FAE assigned to Harman. Or you can create new case here:
https://support.nxp.com/s/?language=en_US
... and the case will be forwarded to local FAE team.
Thanks for understanding.
Lukas
%3CLINGO-SUB%20id%3D%22lingo-sub-2143410%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K358%EF%BC%9A%E9%80%9A%E8%BF%87%20GMAC%20PPS%20%E6%A8%A1%E5%9D%97%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%E7%94%A8%E4%BA%8E%E5%AA%92%E4%BD%93%E6%97%B6%E9%92%9F%E7%94%9F%E6%88%90%20eDMA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2143410%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20GMAC%20PPS%20%E6%A8%A1%E5%9D%97%E7%94%9F%E6%88%90%E5%AA%92%E4%BD%93%E6%97%B6%E9%92%9F%EF%BC%8C%E5%B9%B6%E8%AE%A1%E5%88%92%E4%BD%BF%E7%94%A8%20eDMA%20%E5%8A%A8%E6%80%81%E6%9B%B4%E6%96%B0%E7%9B%AE%E6%A0%87%E6%97%B6%E9%97%B4%EF%BC%88%E7%A7%92%E5%92%8C%E7%BA%B3%E7%A7%92%EF%BC%89%E3%80%82%E4%BB%A5%E4%B8%8B%E6%98%AF%E6%88%91%E7%9A%84%E6%96%B9%E6%B3%95%E6%91%98%E8%A6%81%EF%BC%9A%3C%2FP%3E%3CHR%20%2F%3E%3CH3%20id%3D%22toc-hId-1972840566%22%20id%3D%22toc-hId-1999746777%22%3E%3CSTRONG%3E%E5%AE%9E%E6%96%BD%E6%A6%82%E8%BF%B0%EF%BC%9A%3C%2FSTRONG%3E%3C%2FH3%3E%3COL%3E%3CLI%3E%3CP%3EGMAC%20PTP%20%E5%8F%82%E8%80%83%E6%97%B6%E9%92%9F%E9%85%8D%E7%BD%AE%E4%B8%BA%20%3CSTRONG%3E125%20MHz%3C%2FSTRONG%3E%EF%BC%8C%E8%BF%99%E4%BC%9A%E5%BC%80%E5%A7%8B%E7%B3%BB%E7%BB%9F%E6%97%B6%E9%97%B4%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3E%3C%2FSTRONG%3E%E7%9B%AE%E6%A0%87%E6%97%B6%E9%97%B4%E7%A7%92%E5%92%8C%3CSTRONG%3E%20%E7%BA%B3%E7%A7%92%3C%2FSTRONG%3E%20%E5%AF%84%E5%AD%98%E5%99%A8%E6%9B%B4%E6%96%B0%E4%B8%BA%E6%AF%8F%E7%A7%92%E7%94%9F%E6%88%90%E4%B8%80%E4%B8%AA%E8%84%89%E5%86%B2%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3EPPS%20%E9%85%8D%E7%BD%AE%E4%B8%BA%3CSTRONG%3E%E5%AA%92%E4%BD%93%E6%97%B6%E9%92%9F%E7%94%9F%E6%88%90%20(MCGR)%20%E6%A8%A1%E5%BC%8F%3C%2FSTRONG%3E%EF%BC%8C%E5%BA%94%E6%96%AD%E8%A8%80%20mcgr_dma_req_o%20%E4%BF%A1%E5%8F%B7%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E6%88%91%E9%80%89%E6%8B%A9%E4%BA%86%20%3CSTRONG%3EDMAMUX%20%E6%9D%A5%E6%BA%90%2028%20%E2%80%94%E2%80%94%20%E2%80%9CIEEE%201588%20PTP%20%E8%AE%A1%E6%97%B6%E5%99%A8%20ch%20%5B0%5D%E2%80%9D%3C%2FSTRONG%3E%EF%BC%8C%E5%81%87%E8%AE%BE%E5%AE%83%E6%98%A0%E5%B0%84%E5%88%B0%20mcgr_dma_req_o%20%5B0%5D%EF%BC%8C%E4%BB%8E%E8%80%8C%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%20eDMA%20%E5%A4%96%E5%9B%B4%E8%AE%BE%E5%A4%87%E8%AF%B7%E6%B1%82%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3ETCD%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%E5%9C%A8%E8%A7%A6%E5%8F%91%E6%97%B6%E5%A4%8D%E5%88%B6%E4%B8%8B%E4%B8%80%E4%B8%AA%E7%9B%AE%E6%A0%87%E6%97%B6%E9%97%B4%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FOL%3E%3CHR%20%2F%3E%3CH3%20id%3D%22toc-hId-165386103%22%20id%3D%22toc-hId-192292314%22%3E%3CSTRONG%3E%E8%A7%82%E5%AF%9F%E5%88%B0%E7%9A%84%E8%A1%8C%E4%B8%BA%3C%2FSTRONG%3E%3C%2FH3%3E%3CUL%3E%3CLI%3E%3CP%3E%E5%BD%93%E7%B3%BB%E7%BB%9F%E6%97%B6%E9%97%B4%E8%BE%BE%E5%88%B0%E6%88%96%E8%B6%85%E8%BF%87%E9%85%8D%E7%BD%AE%E7%9A%84%E7%9B%AE%E6%A0%87%E6%97%B6%E9%97%B4%E6%97%B6%EF%BC%8Cmac_Timestamp_Status%20%E5%AF%84%E5%AD%98%E5%99%A8%E4%B8%AD%E7%9A%84%20%3CSTRONG%3ETSTARGT0%3C%2FSTRONG%3E%20%E4%BD%8D%E8%AE%BE%E7%BD%AE%E6%AD%A3%E7%A1%AE%EF%BC%8C%E8%BF%99%E8%A1%A8%E6%98%8E%20mcgr_dma_req_o%5B0%5D%20%E5%B7%B2%E9%92%B3%E4%BD%8D%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22sathishkumar_sunmugavel_0-1753867248257.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sathishkumar_sunmugavel_0-1753867248257.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F350215i805DE16B41600D34%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22sathishkumar_sunmugavel_0-1753867248257.png%22%20alt%3D%22sathishkumar_sunmugavel_0-1753867248257.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E4%B8%8D%E4%BC%9A%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%20DMA%20%E4%BC%A0%E8%BE%93%EF%BC%9B%E5%BD%93%E5%89%8D%E7%9A%84%E8%BF%AD%E4%BB%A3%E6%AC%A1%E6%95%B0%E4%BF%9D%E6%8C%81%E4%B8%8D%E5%8F%98%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CHR%20%2F%3E%3CH3%20id%3D%22toc-hId--1642068360%22%20id%3D%22toc-hId--1615162149%22%3E%3CSTRONG%3E%E9%97%AE%E9%A2%98%3C%2FSTRONG%3E%3C%2FH3%3E%3COL%3E%3CLI%3E%3CP%3E%E8%BF%99%E7%A7%8D%E6%96%B9%E6%B3%95%E5%AF%B9%E4%BA%8E%E4%BD%BF%E7%94%A8%20PPS%20%E6%A8%A1%E5%9D%97%E5%92%8C%20eDMA%20%E7%94%9F%E6%88%90%E5%91%A8%E6%9C%9F%E6%80%A7%E6%97%B6%E9%92%9F%E8%84%89%E5%86%B2%E6%98%AF%E5%90%A6%E6%9C%89%E6%95%88%EF%BC%9F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E5%9C%A8%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8CDMAMUX%20%E9%85%8D%E7%BD%AE%EF%BC%88%E6%BA%90%2028%EF%BC%9AIEEE%201588%20PTP%20%E5%AE%9A%E6%97%B6%E5%99%A8%20ch%5B0%5D%EF%BC%89%E6%98%AF%E5%90%A6%E6%AD%A3%E7%A1%AE%EF%BC%9F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E6%96%AD%E8%A8%80%20mcgr_dma_req_o%20%E7%9C%9F%E7%9A%84%E4%BC%9A%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%20eDMA%20%E5%A4%96%E5%9B%B4%E8%AE%BE%E5%A4%87%E8%AF%B7%E6%B1%82%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E4%B8%8D%E5%90%8C%E8%B5%84%E6%BA%90%E7%9A%84%E5%91%BD%E5%90%8D%E8%A7%84%E5%88%99%E4%BC%BC%E4%B9%8E%E4%B8%8D%E4%B8%80%E8%87%B4%EF%BC%9A%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3EDMAMUX%20%E7%BA%B8%E5%BC%A0%EF%BC%9AIEEE%201588%20PTP%20%E5%AE%9A%E6%97%B6%E5%99%A8%20ch%5Bi%5D%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%EF%BC%9Amcgr_dma_req_o%20%5Bi%5D%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3ESDK%20%E4%BB%A3%E7%A0%81%EF%BC%9ADMA_MUX_1_GMAC_0_PTP_TIMER_CH%5Bi%5D%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3C%2FLI%3E%3C%2FOL%3E%3CHR%20%2F%3E%3CH3%20id%3D%22toc-hId-845444473%22%20id%3D%22toc-hId-872350684%22%3E%3CSTRONG%3E%E7%BB%93%E8%AE%BA%3C%2FSTRONG%3E%3C%2FH3%3E%3CP%3E%E6%88%91%E6%83%B3%E7%A1%AE%E8%AE%A4%E4%B8%80%E4%B8%8B%EF%BC%9A%3CSTRONG%3E%E5%BD%93%E7%B3%BB%E7%BB%9F%E6%97%B6%E9%97%B4%E6%BB%A1%E8%B6%B3%E9%85%8D%E7%BD%AE%E7%9A%84%E7%9B%AE%E6%A0%87%E6%97%B6%E9%97%B4%E6%97%B6%EF%BC%8C%E5%B0%86%E9%92%B3%E4%BD%8D%20mcgr_dma_req_o%20%E4%BF%A1%E5%8F%B7%E2%80%94%E2%80%94%E8%AF%A5%E4%BF%A1%E5%8F%B7%E6%98%AF%E5%90%A6%E4%BD%9C%E4%B8%BA%E6%9C%89%E6%95%88%E7%9A%84%E5%A4%96%E5%9B%B4%E8%AE%BE%E5%A4%87%E8%AF%B7%E6%B1%82%E8%B7%AF%E7%94%B1%E5%88%B0%20eDMA%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSTRONG%3E%E6%88%91%E9%99%84%E4%B8%8A%E4%BA%86%20main.c%20%E7%A4%BA%E4%BE%8B%E6%96%87%E4%BB%B6%E4%BE%9B%E5%8F%82%E8%80%83%E3%80%82%E8%AF%B7%E7%9C%8B%E4%B8%80%E7%9C%8B%EF%BC%8C%E5%B9%B6%E5%91%8A%E8%AF%89%E6%88%91%E5%93%AA%E9%87%8C%E5%87%BA%E4%BA%86%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9C%89%E4%BB%BB%E4%BD%95%E8%A7%81%E8%A7%A3%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B0%86%E4%B8%8D%E8%83%9C%E6%84%9F%E6%BF%80%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%95%AC%E4%B8%8A%EF%BC%8C%3CBR%20%2F%3ESathish%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2144128%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K358%3A%20eDMA%20Trigger%20via%20GMAC%20PPS%20Module%20for%20Media%20Clock%20Generation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2144128%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F248322%22%20target%3D%22_blank%22%3E%40sathishkumar_sunmugavel%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%BB%BA%E8%AE%AE%E7%9B%B4%E6%8E%A5%E4%B8%8E%E5%88%86%E9%85%8D%E7%BB%99%E5%93%88%E6%9B%BC%E7%9A%84%E6%81%A9%E6%99%BA%E6%B5%A6%20FAE%20%E8%AE%A8%E8%AE%BA%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%E6%88%96%E8%80%85%E6%82%A8%E4%B9%9F%E5%8F%AF%E4%BB%A5%E5%9C%A8%E6%AD%A4%E5%88%9B%E5%BB%BA%E6%96%B0%E6%A1%88%E4%BE%8B%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fsupport.nxp.com%2Fs%2F%3Flanguage%3Den_US%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fsupport.nxp.com%2Fs%2F%3Flanguage%3Den_US%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E......%E5%B9%B6%E5%B0%86%E6%A1%88%E4%BB%B6%E8%BD%AC%E4%BA%A4%E5%BD%93%E5%9C%B0%20FAE%20%E5%B0%8F%E7%BB%84%E3%80%82%20%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E7%90%86%E8%A7%A3%E3%80%82%20%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%0A%3CP%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E
