Hi NXP team,
Currently we have
S32K344 can use CAN to communicate with arduino and reapberry pi.
s32g399ardb3 can use CAN to communicate with arduino, raspberry pi and our design board
Our design board can use CAN to communicate with arduino, raspberry pi and s32g399ardb3
But s32k344 can not communicate with s32g399ardb3 and our design board.
Our s32k344 CAN related source code was reference s32k MCAL CAN example code
Hi PetrS,
We set the CAN bitrate as 500k/125k and sample point as 0.75 for s32k
Both FIRC and PLL_PHI0 clock are we tested
as I wrote, to analyze possible issue, check FlexCAN module MCR/ECR/ESR1 registers within debugger to know status and what errors are detected. Also measuring CAN bus line MCU TXD/RXD lines with scope/analyzer can help.
Share CAN PE clock and bitrate setting and content of relevant registers.
BR, petr
