S32K358 PIT not work
已解决
跳至解决方案
3,793 次查看
DouDou1
Why doesn't my program enter the Pit1Notification function
1 解答
3,713 次查看
Senlent
Hi@DouDou1
I created a project from scratch according to your configuration, you can refer to it
Senlent_0-1748512834062.png(The
(The project you provided does have problems, but I don’t know what you modified, just refer to the project I provided)
在原帖中查看解决方案
9 回复数
3,781 次查看
Senlent
Hi@DouDou1
Please refer to the demo we provided in S32 DS.
3,779 次查看
DouDou1
Could you help me check if there are any problems with my program
3,758 次查看
Senlent
Hi@DouDou1
Please try unchecking this option and testing again.
3,738 次查看
DouDou1
I adopted your suggestion and set a breakpoint in the Pit1Notification function. However, it still didn't work. Could you please tell me what the reason is?
3,710 次查看
Senlent
Hi@DouDou1
Aslo, update to new RTD version, these is no reason to waste time on the older RTD version if you're developing a new project.
3,714 次查看
Senlent
Hi@DouDou1
3,226 次查看
ddddddd
hello Senlent,Could you please clarify whether all interrupts are ignored or only the PIT interrupt is ignored? I have encountered a similar issue where all interrupts are not processed.
3,422 次查看
DouDou1
Sorry for replying to you so late. I have tested it using the code you provided and it is possible to enter the interruption. Thank you very much.
3,227 次查看
ddddddd
hello DouDoul,Could you please clarify whether all interrupts are ignored or only the PIT interrupt is ignored? I have encountered a similar issue where all interrupts are not processed.
