S32K358 PIT not work
3,795件の閲覧回数
DouDou1
Why doesn't my program enter the Pit1Notification function
3,715件の閲覧回数
Senlent
Hi@DouDou1
I created a project from scratch according to your configuration, you can refer to it
Senlent_0-1748512834062.png(The
(The project you provided does have problems, but I don’t know what you modified, just refer to the project I provided)
9 返答(返信)
3,783件の閲覧回数
Senlent
Hi@DouDou1
Please refer to the demo we provided in S32 DS.
3,781件の閲覧回数
DouDou1
Could you help me check if there are any problems with my program
3,760件の閲覧回数
Senlent
Hi@DouDou1
Please try unchecking this option and testing again.
3,740件の閲覧回数
DouDou1
I adopted your suggestion and set a breakpoint in the Pit1Notification function. However, it still didn't work. Could you please tell me what the reason is?
3,712件の閲覧回数
Senlent
Hi@DouDou1
Aslo, update to new RTD version, these is no reason to waste time on the older RTD version if you're developing a new project.
3,716件の閲覧回数
Senlent
Hi@DouDou1
3,228件の閲覧回数
ddddddd
hello Senlent,Could you please clarify whether all interrupts are ignored or only the PIT interrupt is ignored? I have encountered a similar issue where all interrupts are not processed.
3,424件の閲覧回数
DouDou1
Sorry for replying to you so late. I have tested it using the code you provided and it is possible to enter the interruption. Thank you very much.
3,229件の閲覧回数
ddddddd
hello DouDoul,Could you please clarify whether all interrupts are ignored or only the PIT interrupt is ignored? I have encountered a similar issue where all interrupts are not processed.
