S32K358 - GMAC Clock Configuration
已解决
跳至解决方案
2,896 次查看
sathishkumar_sunmugavel
Hi Everyone,
I have a few questions regarding the GMAC clocking configuration.
In my setup, PTB3 is configured as an output pin for RGMII_TXCLK, and PTC16 is configured as an input pin for RGMII_RXCLK. This configuration is confirmed from the attached Excel sheet.
According to the pin descriptions:
  • PTB3 can function as either an input or output for GMAC0_MII_RMII_RGMII_TX_CLK
  • PTC16 can function as an input for GMAC0_MII_RGMII_RX_CLK.
I am using the RGMII interface, which requires a 125 MHz clock input for both EMAC_CLK_RX and EMAC_CLK_TX. From my understanding, only EMAC_MII_RMII_TX_CLK can be used as the clock input.
If this understanding is incorrect, please clarify how these two clocks should be provided.
  • EMAC_MII_RMII_TX_CLK → MC_CGM_MUX7 → EMAC_CLK_RX
  • EMAC_MII_RMII_TX_CLK → MC_CGM_MUX8 → EMAC_CLK_TX
Up to this point, everything is clear. However, the table below is a bit confusing as it lists the source, destination clock, and port details.
  1. The IBE bit is set for all the listed ports — could you please explain what this indicates?
  2. PTC16 appears to be used between GMAC_MII_RGMII_RX_CLK and GMAC_TS_CLK but I used PTC16 as RGMII Rx clock pin — could you clarify this connection?
  3. Based on my understanding, PTB3 and PTC16 can be used as the RGMII Tx/Rx clock pins connected to the PHY. Additionally, the clock source EMAC_MII_RMII_TX_CLK is internally connected to EMAC_CLK_RX and EMAC_CLK_TX through MUX7 and MUX8, respectively. However, the information in the table seems inconsistent with this understanding — could you please clarify?
Sathish.
标记 (3)
1 解答
2,846 次查看
PavelL
Hello @sathishkumar_sunmugavel ,
Please find answers to your questions below. FYI, you use S32K3 RM Rev 6, the latest one is Rev. 11.
I run successfully RGMII 100Mbps on S32K358EVB-Q289, with external TJA1103 on SABRE connector.
1. Here's screenshot of Pins:
2. Clocks can be tricky a little bit. RGMII TX_CLK shall be an output, RGMII RX_CLK shall be an input. There's an internal divider 2, so TX_CLK need to be doubled.
For GMAC 1Gbps change the clocks accordingly: 25MHz -> 125MHz ; 50MHz -> 250MHz
3. And the last point, it's necessary to set up clock muxes also in your code, before gmac init. I do it usually as the very first rows in the code:
I do not use Table 116 (in RM Rev 6).
Pavel
在原帖中查看解决方案
5 回复数
2,847 次查看
PavelL
Pavel
2,825 次查看
Hi @PavelL
Thank you so much for the valuable inputs. The issue is resolved after adding the below line.
IP_DCM_GPR->DCMRWF1|=DCM_GPR_DCMRWF1_MAC_CONF_SEL(0x01) |DCM_GPR_DCMRWF1_MAC_TX_RMII_CLK_LPBCK_EN_MASK;
But could you please confirm why this tx clock loop back is required?
Sathish.
2,820 次查看
PavelL
This is related to the GMAC IP from Synopsys.
This bit allows the MAC to internally loop back its own TX clock as the input clock - which is necessary to initialize MAC in RGMII mode.
Pavel
2,623 次查看
Hi @PavelL
Got it. Thanks!!!
2,878 次查看
There is no PHY in my setup. It's MAC-MAC connection.
1. In that case, Do I need to consider this PHY_INTF_SEL signal input to GMAC module?
2. Can I use PLL_AUX_CLK with 125MHz for both CLK_TX_I and CLK_RX_I?
3. CLK_TX_I and CLK_RX_I are connected by internal muxing, and PTB3 should be configured as output from GMAC for RGMII TX_CLK and PTC16 should be configured as input to GMAC RGMII RX_CLK. Is this understanding, correct?
%3CLINGO-SUB%20id%3D%22lingo-sub-2184368%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K358%20-%20GMAC%20%E6%97%B6%E9%92%9F%E9%85%8D%E7%BD%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2184368%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%3CBR%20%2F%3E%3CBR%20%2F%3E%EF%BC%8C%E6%88%91%E6%9C%89%E5%87%A0%E4%B8%AA%E5%85%B3%E4%BA%8E%20GMAC%20%E6%97%B6%E9%92%9F%E9%85%8D%E7%BD%AE%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%E6%88%91%E7%9A%84%E8%AE%BE%E7%BD%AE%E4%B8%AD%EF%BC%8C%3CSTRONG%3EPTB3%3C%2FSTRONG%3E%E8%A2%AB%E9%85%8D%E7%BD%AE%E4%B8%BA%3CSTRONG%3ERGMII_TXCLK%3C%2FSTRONG%3E%20%E7%9A%84%3CSTRONG%3E%E8%BE%93%E5%87%BA%E5%BC%95%E8%84%9A%3C%2FSTRONG%3E%EF%BC%8C%3CSTRONG%3EPTC16%3C%2FSTRONG%3E%E8%A2%AB%E9%85%8D%E7%BD%AE%E4%B8%BA%3CSTRONG%3ERGMII_RXCLK%3C%2FSTRONG%3E%20%E7%9A%84%3CSTRONG%3E%E8%BE%93%E5%85%A5%E5%BC%95%E8%84%9A%3C%2FSTRONG%3E%E3%80%82%E8%AF%A5%E9%85%8D%E7%BD%AE%E5%8F%AF%E4%BB%8E%E6%89%80%E9%99%84%20Excel%20%E8%A1%A8%E4%B8%AD%E7%A1%AE%E8%AE%A4%E3%80%82%3C%2FP%3E%3CP%3E%E6%A0%B9%E6%8D%AE%E5%BC%95%E8%84%9A%E8%AF%B4%E6%98%8E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%3CSTRONG%3EPTB3%3C%2FSTRONG%3E%E6%97%A2%E5%8F%AF%E4%BB%A5%E4%BD%9C%E4%B8%BA%3CSTRONG%3EGMAC0_MII_RMII_RGMII_TX_CLK%3C%2FSTRONG%3E%E7%9A%84%3CSTRONG%3E%E8%BE%93%E5%85%A5%EF%BC%8C%3C%2FSTRONG%3E%E4%B9%9F%E5%8F%AF%E4%BB%A5%E4%BD%9C%E4%B8%BAGMAC0_MII_RMII_RGMII_TX_CLK%E7%9A%84%E8%BE%93%E5%87%BA%E3%80%82%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22sathishkumar_sunmugavel_0-1760251864899.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sathishkumar_sunmugavel_0-1760251864899.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360377i3A61F8898F5380B3%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22sathishkumar_sunmugavel_0-1760251864899.png%22%20alt%3D%22sathishkumar_sunmugavel_0-1760251864899.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSTRONG%3EPTC16%3C%2FSTRONG%3E%E5%8F%AF%E4%BD%9C%E4%B8%BA%3CSTRONG%3EGMAC0_MII_RGMII_RX_CLK%3C%2FSTRONG%3E%20%E7%9A%84%3CSTRONG%3E%E8%BE%93%E5%85%A5%3C%2FSTRONG%3E%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22sathishkumar_sunmugavel_1-1760251936647.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sathishkumar_sunmugavel_1-1760251936647.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360378i1E01BB4DDC027BCB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22sathishkumar_sunmugavel_1-1760251936647.png%22%20alt%3D%22sathishkumar_sunmugavel_1-1760251936647.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%3CSTRONG%3ERGMII%20%E6%8E%A5%E5%8F%A3%3C%2FSTRONG%3E%EF%BC%8C%E5%AE%83%E9%9C%80%E8%A6%81%E4%B8%BA%3CSTRONG%3EEMAC_CLK_RX%3C%2FSTRONG%3E%E5%92%8C%3CSTRONG%3EEMAC_CLK_TX%3C%2FSTRONG%3E%20%E6%8F%90%E4%BE%9B%3CSTRONG%3E125%20MHz%20%E7%9A%84%E6%97%B6%E9%92%9F%E8%BE%93%E5%85%A5%3C%2FSTRONG%3E%E3%80%82%20%E6%8D%AE%E6%88%91%E6%89%80%E7%9F%A5%EF%BC%8C%E5%8F%AA%E6%9C%89%3CSTRONG%3EEMAC_MII_RMII_TX_CLK%3C%2FSTRONG%3E%E5%8F%AF%E4%BB%A5%E7%94%A8%E4%BD%9C%E6%97%B6%E9%92%9F%E8%BE%93%E5%85%A5%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E7%90%86%E8%A7%A3%E6%9C%89%E8%AF%AF%EF%BC%8C%E8%AF%B7%E8%AF%B4%E6%98%8E%E5%BA%94%E5%A6%82%E4%BD%95%E6%8F%90%E4%BE%9B%E8%BF%99%E4%B8%A4%E4%B8%AA%E6%97%B6%E9%92%9F%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3E%3CP%3E%3CSTRONG%3Eemac_mii_rmii_tx_clk%20%E2%86%92%20mc_cgm_mux7%20%E2%86%92%20emac_clk_rx%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3Eemac_mii_rmii_tx_clk%20%E2%86%92%20mc_cgm_mux8%20%E2%86%92%20emac_clk_tx%3C%2FSTRONG%3E%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22sathishkumar_sunmugavel_2-1760252344261.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sathishkumar_sunmugavel_2-1760252344261.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360379iFCBDDEE7982F76C5%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22sathishkumar_sunmugavel_2-1760252344261.png%22%20alt%3D%22sathishkumar_sunmugavel_2-1760252344261.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%88%B0%E6%AD%A4%E4%B8%BA%E6%AD%A2%EF%BC%8C%E4%B8%80%E5%88%87%E9%83%BD%E6%B8%85%E6%A5%9A%E4%BA%86%E3%80%82%E4%B8%8D%E8%BF%87%EF%BC%8C%E4%B8%8B%E8%A1%A8%E5%88%97%E5%87%BA%E7%9A%84%E6%BA%90%E6%97%B6%E9%92%9F%E3%80%81%E7%9B%AE%E6%A0%87%E6%97%B6%E9%92%9F%E5%92%8C%E7%AB%AF%E5%8F%A3%E8%AF%A6%E7%BB%86%E4%BF%A1%E6%81%AF%E6%9C%89%E7%82%B9%E6%B7%B7%E4%B9%B1%E3%80%82%3C%2FP%3E%3COL%3E%3CLI%3E%3CP%3E%E6%89%80%E6%9C%89%E5%88%97%E5%87%BA%E7%9A%84%E7%AB%AF%E5%8F%A3%E7%9A%84%3CSTRONG%3EIBE%20%E4%BD%8D%3C%2FSTRONG%3E%E9%83%BD%E5%B7%B2%E8%AE%BE%E7%BD%AE%20-%20%E8%83%BD%E5%90%A6%E8%A7%A3%E9%87%8A%E4%B8%80%E4%B8%8B%E8%BF%99%E6%98%AF%E4%BB%80%E4%B9%88%E6%84%8F%E6%80%9D%EF%BC%9F%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%3CSTRONG%3EPTC16%3C%2FSTRONG%3E%E4%BC%BC%E4%B9%8E%E7%94%A8%E4%BA%8E%3CSTRONG%3EGMAC_MII_RGMII_RX_CLK%3C%2FSTRONG%3E%E5%92%8C%3CSTRONG%3EGMAC_TS_CLK%20%3C%2FSTRONG%3E%EF%BC%8C%E4%BD%86%E6%88%91%E5%B0%86%20PTC16%20%E7%94%A8%E4%BD%9C%20RGMII%20Rx%20%E6%97%B6%E9%92%9F%E5%BC%95%E8%84%9A%3CSPAN%3E-%20%E8%83%BD%E5%90%A6%E8%AF%B4%E6%98%8E%E8%BF%99%E7%A7%8D%E8%BF%9E%E6%8E%A5%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3CLI%3E%3CP%3E%E6%A0%B9%E6%8D%AE%E6%88%91%E7%9A%84%E7%90%86%E8%A7%A3%EF%BC%8C%3CSTRONG%3EPTB3%3C%2FSTRONG%3E%E5%92%8C%3CSTRONG%3EPTC16%3C%2FSTRONG%3E%E5%8F%AF%E7%94%A8%E4%BD%9C%E8%BF%9E%E6%8E%A5%E5%88%B0%20PHY%3CSTRONG%3E%E7%9A%84%20RGMII%20Tx%2FRx%20%E6%97%B6%E9%92%9F%E5%BC%95%E8%84%9A%3C%2FSTRONG%3E%E3%80%82%20%E6%AD%A4%E5%A4%96%EF%BC%8C%E6%97%B6%E9%92%9F%E6%BA%90%3CSTRONG%3EEMAC_MII_RMII_TX_CLK%3C%2FSTRONG%3E%E9%80%9A%E8%BF%87%3CSTRONG%3EMUX7%3C%2FSTRONG%3E%E5%92%8C%3CSTRONG%3EMUX8%3C%2FSTRONG%3E%20%E5%88%86%E5%88%AB%E4%B8%8E%3CSTRONG%3EEMAC_CLK_RX%3C%2FSTRONG%3E%E5%92%8C%3CSTRONG%3EEMAC_CLK_TX%3C%2FSTRONG%3E%E5%86%85%E9%83%A8%E7%9B%B8%E8%BF%9E%E3%80%82%20%E7%84%B6%E8%80%8C%EF%BC%8C%E8%A1%A8%E6%A0%BC%E4%B8%AD%E7%9A%84%E4%BF%A1%E6%81%AF%E4%BC%BC%E4%B9%8E%E4%B8%8E%E8%BF%99%E4%B8%80%E7%90%86%E8%A7%A3%E4%B8%8D%E4%B8%80%E8%87%B4--%E8%83%BD%E5%90%A6%E8%AF%B7%E6%82%A8%E6%BE%84%E6%B8%85%E4%B8%80%E4%B8%8B%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22sathishkumar_sunmugavel_3-1760253362178.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sathishkumar_sunmugavel_3-1760253362178.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360380i83E483A9736F5D2D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22sathishkumar_sunmugavel_3-1760253362178.png%22%20alt%3D%22sathishkumar_sunmugavel_3-1760253362178.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%E6%95%AC%E4%B8%8A%EF%BC%8C%3CBR%20%2F%3ESathish%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2197202%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K358%20-%20GMAC%20Clock%20Configuration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2197202%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F233505%22%20target%3D%22_blank%22%3E%40PavelL%3C%2FA%3E%20%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%98%8E%E7%99%BD%E4%BA%86%E3%80%82%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2185378%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K358%20-%20GMAC%20Clock%20Configuration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2185378%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F248322%22%20target%3D%22_blank%22%3E%40sathishkumar_sunmugavel%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E4%B8%8E%20Synopsys%20%E7%9A%84%20GMAC%20IP%20%E6%9C%89%E5%85%B3%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%AF%A5%E4%BD%8D%E5%85%81%E8%AE%B8%20MAC%20%E5%B0%86%E5%85%B6%E8%87%AA%E8%BA%AB%E7%9A%84%20TX%20%E6%97%B6%E9%92%9F%E4%BD%9C%E4%B8%BA%E8%BE%93%E5%85%A5%E6%97%B6%E9%92%9F%E8%BF%9B%E8%A1%8C%E5%86%85%E9%83%A8%E5%9B%9E%E7%8E%AF%EF%BC%8C%E8%BF%99%E5%AF%B9%E4%BA%8E%E5%9C%A8%20RGMII%20%E6%A8%A1%E5%BC%8F%E4%B8%8B%E5%88%9D%E5%A7%8B%E5%8C%96%20MAC%20%E5%8D%81%E5%88%86%E5%BF%85%E8%A6%81%E3%80%82%3C%2FP%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E5%B8%95%E7%BB%B4%E5%B0%94%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2185319%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K358%20-%20GMAC%20Clock%20Configuration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2185319%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F233505%22%20target%3D%22_blank%22%3E%40PavelL%3C%2FA%3E%20%3CBR%20%2F%3E%3CBR%20%2F%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E4%BD%A0%E7%9A%84%E5%AE%9D%E8%B4%B5%E6%84%8F%E8%A7%81%E3%80%82%E6%B7%BB%E5%8A%A0%E4%B8%8B%E9%9D%A2%E4%B8%80%E8%A1%8C%E5%90%8E%EF%BC%8C%E9%97%AE%E9%A2%98%E5%B0%B1%E8%A7%A3%E5%86%B3%E4%BA%86%E3%80%82%20%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CEM%3EIP_DCM_GPR-%26gt%3BDCMRWF1%7C%3DDCM_GPR_DCMRWF1_MAC_CONF_SEL(0x01)%20%7CDCM_GPR_DCMRWF1_MAC_TX_RMII_CLK_LPBCK_EN_MASK%EF%BC%9B%3C%2FEM%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E4%BD%86%E8%83%BD%E5%90%A6%E8%AF%B7%E6%82%A8%E7%A1%AE%E8%AE%A4%E4%B8%80%E4%B8%8B%EF%BC%8C%E4%B8%BA%E4%BB%80%E4%B9%88%E9%9C%80%E8%A6%81%E5%8F%91%E9%80%81%E6%97%B6%E9%92%9F%E5%9B%9E%E7%8E%AF%EF%BC%9F%3CEM%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FEM%3E%E6%95%AC%E4%B8%8A%EF%BC%8C%3CBR%20%2F%3ESathish%E3%80%82%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2184820%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K358%20-%20GMAC%20Clock%20Configuration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2184820%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F248322%22%20target%3D%22_blank%22%3E%40sathishkumar_sunmugavel%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E5%9C%A8%E4%B8%8B%E9%9D%A2%E6%89%BE%E5%88%B0%E6%82%A8%E9%97%AE%E9%A2%98%E7%9A%84%E7%AD%94%E6%A1%88%E3%80%82%E9%A1%BA%E4%BE%BF%E6%8F%90%E4%B8%80%E4%B8%8B%EF%BC%8C%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20S32K3%20RM%20Rev%206%EF%BC%8C%E6%9C%80%E6%96%B0%E7%89%88%E6%9C%AC%E6%98%AF%20Rev.11%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%9C%A8%20S32K358EVB-Q289%20%E4%B8%8A%E6%88%90%E5%8A%9F%E8%BF%90%E8%A1%8C%E4%BA%86%20RGMII%20100Mbps%EF%BC%8CSABRE%20%E8%BF%9E%E6%8E%A5%E5%99%A8%E4%B8%8A%E6%9C%89%E5%A4%96%E9%83%A8%20TJA1103%E3%80%82%3C%2FP%3E%0A%3CP%3E1.%E4%B8%8B%E9%9D%A2%E6%98%AF%E5%9B%BE%E9%92%89%E7%9A%84%E6%88%AA%E5%9B%BE%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22PavelL_0-1760353715569.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PavelL_0-1760353715569.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360468i5449985CA62CB5CF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22PavelL_0-1760353715569.png%22%20alt%3D%22PavelL_0-1760353715569.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E2.%E9%92%9F%E8%A1%A8%E5%8F%AF%E8%83%BD%E6%9C%89%E7%82%B9%E9%BA%BB%E7%83%A6%E3%80%82RGMII%20TX_CLK%20%E5%BA%94%E4%B8%BA%E8%BE%93%E5%87%BA%EF%BC%8CRGMII%20RX_CLK%20%E5%BA%94%E4%B8%BA%E8%BE%93%E5%85%A5%E3%80%82%20%E6%9C%89%E4%B8%80%E4%B8%AA%E5%86%85%E9%83%A8%E5%88%86%E9%A2%91%E5%99%A8%202%EF%BC%8C%E5%9B%A0%E6%AD%A4%20TX_CLK%20%E9%9C%80%E8%A6%81%E5%8A%A0%E5%80%8D%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22PavelL_1-1760353859390.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PavelL_1-1760353859390.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360470iEB29310FB9DAF58E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22PavelL_1-1760353859390.png%22%20alt%3D%22PavelL_1-1760353859390.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%98%AF%20GMAC%201Gbps%EF%BC%8C%E5%88%99%E7%9B%B8%E5%BA%94%E6%9B%B4%E6%94%B9%E6%97%B6%E9%92%9F%EF%BC%9A25MHz%20-%26gt%3B%20125MHz%20%3B%2050MHz%20-%26gt%3B%20250MHz%3C%2FP%3E%0A%3CP%3E3.%E6%9C%80%E5%90%8E%E4%B8%80%E7%82%B9%EF%BC%8C%E5%9C%A8%20gmac%20%E5%88%9D%E5%A7%8B%E5%8C%96%E4%B9%8B%E5%89%8D%EF%BC%8C%E8%BF%98%E9%9C%80%E8%A6%81%E5%9C%A8%E4%BB%A3%E7%A0%81%E4%B8%AD%E5%AE%89%E8%A3%85%E6%97%B6%E9%92%9F%E5%A4%9A%E8%B7%AF%E5%A4%8D%E7%94%A8%E5%99%A8%E3%80%82%E6%88%91%E9%80%9A%E5%B8%B8%E6%98%AF%E5%9C%A8%E4%BB%A3%E7%A0%81%E7%9A%84%E7%AC%AC%E4%B8%80%E8%A1%8C%E8%BF%99%E6%A0%B7%E5%81%9A%E7%9A%84%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22PavelL_2-1760354079287.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22PavelL_2-1760354079287.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360471iA68264F3D32428BC%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22PavelL_2-1760354079287.png%22%20alt%3D%22PavelL_2-1760354079287.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%B8%8D%E4%BD%BF%E7%94%A8%E8%A1%A8%20116%EF%BC%88RM%20%E4%BF%AE%E8%AE%A2%E7%89%88%206%EF%BC%89%E3%80%82%3C%2FP%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E5%B8%95%E7%BB%B4%E5%B0%94%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2184375%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K358%20-%20GMAC%20Clock%20Configuration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2184375%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E7%9A%84%E8%AE%BE%E7%BD%AE%E4%B8%AD%E6%B2%A1%E6%9C%89%20PHY%E3%80%82%E8%BF%99%E6%98%AF%20MAC-MAC%20%E8%BF%9E%E6%8E%A5%E3%80%82%20%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22sathishkumar_sunmugavel_0-1760258913178.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22sathishkumar_sunmugavel_0-1760258913178.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360382i3D022D8CA9324A73%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22sathishkumar_sunmugavel_0-1760258913178.png%22%20alt%3D%22sathishkumar_sunmugavel_0-1760258913178.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E1.%E5%9C%A8%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E6%88%91%E6%98%AF%E5%90%A6%E9%9C%80%E8%A6%81%E5%B0%86%E6%AD%A4%20PHY_INTF_SEL%20%E4%BF%A1%E5%8F%B7%E4%BD%9C%E4%B8%BA%20GMAC%20%E6%A8%A1%E5%9D%97%E7%9A%84%E8%BE%93%E5%85%A5%EF%BC%9F%3CBR%20%2F%3E2.%20%E6%88%91%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E5%B0%86%20125MHz%20%E7%9A%84%20PLL_AUX_CLK%20%E7%94%A8%E4%BA%8E%20CLK_TX_I%20%E5%92%8C%20CLK_RX_I%EF%BC%9F%3CBR%20%2F%3E3.%20CLK_TX_I%20%E5%92%8C%20CLK_RX_I%20%E9%80%9A%E8%BF%87%E5%86%85%E9%83%A8%E5%A4%8D%E7%94%A8%E8%BF%9E%E6%8E%A5%EF%BC%8CPTB3%20%E5%BA%94%E9%85%8D%E7%BD%AE%E4%B8%BA%20GMAC%20%E7%9A%84%20RGMII%20TX_CLK%20%E8%BE%93%E5%87%BA%EF%BC%8CPTC16%20%E5%BA%94%E9%85%8D%E7%BD%AE%E4%B8%BA%20GMAC%20RGMII%20RX_CLK%20%E7%9A%84%E8%BE%93%E5%85%A5%E3%80%82%E8%BF%99%E7%A7%8D%E7%90%86%E8%A7%A3%E5%AF%B9%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E
