S32K344 chip, failed to download using bootloader after adding eMCEM_1 module in spd
900 次查看
XPW
Sort out the logic and rewrite: As the title suggests, when I enabled eMCEM_1 in the app code, downloading the app using the official bootloader failed. If I didn't erase the chip, I couldn't enter the boot again, and even after powering it back on, it wouldn't solve the problem. I suspect that after powering it back on, the boot jumped to the app, but the app didn't run. When I disable eMCEM_1, this issue does not occur. How can I use boot to flash the app when eMCEM_1 is enabled
6 回复数
878 次查看
danielmartynek
Hi @XPW,
The problem description is not entirely clear.
If the application is being programmed through the bootloader, the eMCEM_1 configuration contained in the application should not affect the programming process itself, since the application is not executed during download, it is just a binary.
Only after the bootloader transfers execution to the application would eMCEM/FCCU-related configuration become relevant, and at that point, it would be useful to check:
  • FCCU status registers
  • DCM flags, MC_RGM flags.
  • Or whether the application actually reaches main()
Based on the current description, it is unclear whether the programming operation fails, or whether programming succeeds and the issue occurs later when the application starts executing.
Could you clarify the exact sequence of events?
820 次查看
XPW
After my investigation, I found that some global variables were not initialized as defined when<eMCEM_1>was enabled。
Select a portion for explanation:
Firstly, when I haven't enabled the target
Clock_ip. c under RTD file
Power_ip. c under RTD file
Can initialize correctly。
However, when I activated it:
Global variable initialization failed。
May I ask if there is a better solution?
796 次查看
danielmartynek
Hi @XPW,
Based on what I see in the screenshots, the variables are initialized correctly at first. However, after the eMCEM initialization, Clock_Ip_pfkNotificationsCallback contains an invalid pointer.
eMCEM does not magically change the pointer value. This looks much more like one of the following issues:
  • Startup initialization (.data copy / .bss initialization) is not completed correctly.
  • RAM corruption occurs before main().
  • Linker sections overlap.
  • Stack corruption.
Can you test it with the linker file from the SPD demo project?
BR, Daniel
665 次查看
XPW
What is the cause of this phenomenon and how should I investigate and solve it.
706 次查看
XPW
The link file has been modified for the following.
I have defined three global variables:
I found that when<eMCEM_1>is not enabled, after executing init_data-bss,
It seems to be aligned with 4 bytes and assigned correctly.
But when I enable<eMCEM_1>, after executing init_data-bss
It doesn't seem to be aligned.
630 次查看
danielmartynek
HI @XPW,
Based on the screenshots, I am not convinced there is actually a problem with the variable initialization itself. variable_a is an 8-bit variable, and enabling eMCEM will introduce additional variables, which can change the layout of the .data section. Therefore, seeing the variables at different offsets is expected and does not by itself indicate corruption.
I think the key question is whether the issue occurs when the application is run standalone, or only when it is programmed and started through the bootloader.
Can you reproduce the issue when programming the application directly with the debugger and running it without the bootloader? If the problem only occurs after loading the application through the bootloader, then the investigation should focus on the bootloader programming process, image layout, or bootloader handover rather than the application itself.
BR, Daniel
%3CLINGO-SUB%20id%3D%22lingo-sub-2390216%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K344%E8%8A%AF%E7%89%87%EF%BC%8C%E5%9C%A8SPD%E4%B8%AD%E6%B7%BB%E5%8A%A0eMCEM_1%E6%A8%A1%E5%9D%97%E5%90%8E%EF%BC%8C%E4%BD%BF%E7%94%A8%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E4%B8%8B%E8%BD%BD%E5%A4%B1%E8%B4%A5%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2390216%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%90%86%E6%B8%85%E9%80%BB%E8%BE%91%E5%B9%B6%E9%87%8D%E5%86%99%EF%BC%9A%E6%AD%A3%E5%A6%82%E6%A0%87%E9%A2%98%E6%89%80%E7%A4%BA%EF%BC%8C%E5%BD%93%E6%88%91%E5%9C%A8%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E4%BB%A3%E7%A0%81%E4%B8%AD%E5%90%AF%E7%94%A8%20eMCEM_1%20%E6%97%B6%EF%BC%8C%E4%BD%BF%E7%94%A8%E5%AE%98%E6%96%B9%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E4%B8%8B%E8%BD%BD%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%A4%B1%E8%B4%A5%E3%80%82%E5%A6%82%E6%9E%9C%E6%88%91%E4%B8%8D%E6%93%A6%E9%99%A4%E8%8A%AF%E7%89%87%EF%BC%8C%E6%88%91%E5%B0%B1%E6%97%A0%E6%B3%95%E5%86%8D%E6%AC%A1%E8%BF%9B%E5%85%A5%E5%90%AF%E5%8A%A8%E7%8A%B6%E6%80%81%EF%BC%8C%E5%8D%B3%E4%BD%BF%E9%87%8D%E6%96%B0%E5%90%AF%E5%8A%A8%E4%B9%9F%E6%97%A0%E6%B3%95%E8%A7%A3%E5%86%B3%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E6%80%80%E7%96%91%E9%87%8D%E6%96%B0%E5%90%AF%E5%8A%A8%E5%90%8E%EF%BC%8C%E5%90%AF%E5%8A%A8%E7%A8%8B%E5%BA%8F%E8%B7%B3%E8%BD%AC%E5%88%B0%E4%BA%86%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E4%BD%86%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E6%B2%A1%E6%9C%89%E8%BF%90%E8%A1%8C%E3%80%82%E7%A6%81%E7%94%A8%20eMCEM_1%20%E5%90%8E%EF%BC%8C%E6%AD%A4%E9%97%AE%E9%A2%98%E4%B8%8D%E4%BC%9A%E5%87%BA%E7%8E%B0%E3%80%82%E5%90%AF%E7%94%A8%20eMCEM_1%20%E5%90%8E%EF%BC%8C%E5%A6%82%E4%BD%95%E4%BD%BF%E7%94%A8%E5%90%AF%E5%8A%A8%20%E6%9D%A5%E5%88%B7%E5%86%99%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2390369%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20chip%2C%20failed%20to%20download%20using%20bootloader%20after%20adding%20eMCEM_1%20module%20in%20spd%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2390369%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F253799%22%20target%3D%22_blank%22%3E%40XPW%3C%2FA%3E%20%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E9%97%AE%E9%A2%98%E6%8F%8F%E8%BF%B0%E4%B8%8D%E5%A4%9F%E6%B8%85%E6%99%B0%E3%80%82%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E6%98%AF%E9%80%9A%E8%BF%87%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E8%BF%9B%E8%A1%8C%E7%BC%96%E7%A8%8B%E7%9A%84%EF%BC%8C%E5%88%99%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E4%B8%AD%E5%8C%85%E5%90%AB%E7%9A%84%20eMCEM_1%20%E9%85%8D%E7%BD%AE%E4%B8%8D%E5%BA%94%E5%BD%B1%E5%93%8D%E7%BC%96%E7%A8%8B%E8%BF%87%E7%A8%8B%E6%9C%AC%E8%BA%AB%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%9C%A8%E4%B8%8B%E8%BD%BD%E6%9C%9F%E9%97%B4%E4%B8%8D%E4%BC%9A%E6%89%A7%E8%A1%8C%EF%BC%8C%E5%AE%83%E5%8F%AA%E6%98%AF%E4%B8%80%E4%B8%AA%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E3%80%82%3CBR%20%2F%3E%E5%8F%AA%E6%9C%89%E5%9C%A8%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E5%B0%86%E6%89%A7%E8%A1%8C%E6%9D%83%E7%A7%BB%E4%BA%A4%E7%BB%99%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E4%B9%8B%E5%90%8E%EF%BC%8C%E4%B8%8E%20eMCEM%2FFCCU%20%E7%9B%B8%E5%85%B3%E7%9A%84%E9%85%8D%E7%BD%AE%E6%89%8D%E4%BC%9A%E5%8F%98%E5%BE%97%E9%87%8D%E8%A6%81%EF%BC%8C%E6%AD%A4%E6%97%B6%E6%A3%80%E6%9F%A5%E4%BB%A5%E4%B8%8B%E5%86%85%E5%AE%B9%E4%BC%9A%E5%BE%88%E6%9C%89%E5%B8%AE%E5%8A%A9%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3EFCCU%E7%8A%B6%E6%80%81%E7%99%BB%E8%AE%B0%E5%86%8C%3C%2FLI%3E%0A%3CLI%3EDCM%20%E6%A0%87%E5%BF%97%EF%BC%8CMC_RGM%20%E6%A0%87%E5%BF%97%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E6%88%96%E8%80%85%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E6%98%AF%E5%90%A6%E7%9C%9F%E7%9A%84%E6%89%A7%E8%A1%8C%E5%88%B0%E4%BA%86%20main()%20%E5%87%BD%E6%95%B0%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E6%A0%B9%E6%8D%AE%E7%9B%AE%E5%89%8D%E7%9A%84%E6%8F%8F%E8%BF%B0%EF%BC%8C%E5%B0%9A%E4%B8%8D%E6%B8%85%E6%A5%9A%E6%98%AF%E7%BC%96%E7%A8%8B%E6%93%8D%E4%BD%9C%E5%A4%B1%E8%B4%A5%EF%BC%8C%E8%BF%98%E6%98%AF%E7%BC%96%E7%A8%8B%E6%88%90%E5%8A%9F%E4%BD%86%E9%97%AE%E9%A2%98%E5%9C%A8%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%BC%80%E5%A7%8B%E6%89%A7%E8%A1%8C%E5%90%8E%E6%89%8D%E5%87%BA%E7%8E%B0%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E8%83%BD%E8%AF%A6%E7%BB%86%E8%AF%B4%E6%98%8E%E4%B8%80%E4%B8%8B%E4%BA%8B%E4%BB%B6%E7%9A%84%E5%85%B7%E4%BD%93%E9%A1%BA%E5%BA%8F%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E4%B8%B9%E5%B0%BC%E5%B0%94%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2392055%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20chip%2C%20failed%20to%20download%20using%20bootloader%20after%20adding%20eMCEM_1%20module%20in%20spd%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2392055%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E7%BB%8F%E8%BF%87%E8%B0%83%E6%9F%A5%EF%BC%8C%E6%88%91%E5%8F%91%E7%8E%B0%E5%90%AF%E7%94%A8%3CEMCEM_1%3E%E6%97%B6%EF%BC%8C%E4%B8%80%E4%BA%9B%E5%85%A8%E5%B1%80%E5%8F%98%E9%87%8F%E6%B2%A1%E6%9C%89%E6%8C%89%E5%AE%9A%E4%B9%89%E8%BF%9B%E8%A1%8C%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FEMCEM_1%3E%3C%2FSPAN%3E%E3%80%82%3CBR%20%2F%3E%3CSPAN%3E%E8%AF%B7%E9%80%89%E6%8B%A9%E9%83%A8%E5%88%86%E8%BF%9B%E8%A1%8C%E8%A7%A3%E9%87%8A%3C%2FSPAN%3E%EF%BC%9A%3CBR%20%2F%3E%E9%A6%96%E5%85%88%EF%BC%8C%E5%BD%93%E6%88%91%E6%B2%A1%E6%9C%89%E5%90%AF%E7%94%A8%E7%9B%AE%E6%A0%87%E6%97%B6%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22XPW_0-1783494597992.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_0-1783494597992.png%22%20style%3D%22width%3A%20353px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_0-1783494597992.png%22%20style%3D%22width%3A%20353px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_0-1783494597992.png%22%20style%3D%22width%3A%20353px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_0-1783494597992.png%22%20style%3D%22width%3A%20353px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_0-1783494597992.png%22%20style%3D%22width%3A%20353px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F391563iEAE400BA10914D5C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22XPW_0-1783494597992.png%22%20alt%3D%22XPW_0-1783494597992.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3ERTD%20%E6%96%87%E4%BB%B6%E4%B8%AD%E7%9A%84%20Clock_ip.c%20%E6%96%87%E4%BB%B6%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22XPW_1-1783494731850.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_1-1783494731850.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_1-1783494731850.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_1-1783494731850.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_1-1783494731850.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_1-1783494731850.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F391564iF08282965F8D8F5B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22XPW_1-1783494731850.png%22%20alt%3D%22XPW_1-1783494731850.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22XPW_2-1783494792174.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_2-1783494792174.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_2-1783494792174.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_2-1783494792174.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_2-1783494792174.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_2-1783494792174.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F391565i5A50275B4FC653F5%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22XPW_2-1783494792174.png%22%20alt%3D%22XPW_2-1783494792174.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E7%94%B5%E6%BA%90IP%E3%80%82c%20%E5%9C%A8%20RTD%20%E6%96%87%E4%BB%B6%E4%B8%8B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22XPW_3-1783494883662.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_3-1783494883662.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_3-1783494883662.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_3-1783494883662.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_3-1783494883662.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_3-1783494883662.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F391566iA0831F9CD390D725%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22XPW_3-1783494883662.png%22%20alt%3D%22XPW_3-1783494883662.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22XPW_4-1783494909192.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_4-1783494909192.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_4-1783494909192.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_4-1783494909192.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_4-1783494909192.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_4-1783494909192.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F391567iAD0FE3B3FCB44E13%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22XPW_4-1783494909192.png%22%20alt%3D%22XPW_4-1783494909192.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%E5%8F%AF%E4%BB%A5%E6%AD%A3%E7%A1%AE%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FSPAN%3E%E3%80%82%3CBR%20%2F%3E%3CSPAN%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E5%BD%93%E6%88%91%E6%BF%80%E6%B4%BB%E5%AE%83%E6%97%B6%3C%2FSPAN%3E%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22XPW_5-1783495188492.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_5-1783495188492.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_5-1783495188492.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_5-1783495188492.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_5-1783495188492.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_5-1783495188492.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F391569iA978B72E4041C63C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22XPW_5-1783495188492.png%22%20alt%3D%22XPW_5-1783495188492.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22XPW_6-1783495223242.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_6-1783495223242.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_6-1783495223242.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_6-1783495223242.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_6-1783495223242.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_6-1783495223242.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F391570iF0E1A0C442E84DB2%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22XPW_6-1783495223242.png%22%20alt%3D%22XPW_6-1783495223242.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%20%3CSPAN%3ERTD%20%E6%96%87%E4%BB%B6%E4%B8%AD%E7%9A%84%20Clock_ip.c%20%E6%96%87%E4%BB%B6%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22XPW_7-1783495794585.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_7-1783495794585.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_7-1783495794585.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_7-1783495794585.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_7-1783495794585.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_7-1783495794585.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F391571i73E5F02C55858197%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22XPW_7-1783495794585.png%22%20alt%3D%22XPW_7-1783495794585.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22XPW_8-1783495823066.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_8-1783495823066.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_8-1783495823066.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_8-1783495823066.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_8-1783495823066.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_8-1783495823066.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F391572iE2556137C0DA4F19%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22XPW_8-1783495823066.png%22%20alt%3D%22XPW_8-1783495823066.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%20%3CSPAN%3ERTD%20%E6%96%87%E4%BB%B6%E4%B8%AD%E7%9A%84%20Power_ip.c%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22XPW_9-1783495866324.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_9-1783495866324.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_9-1783495866324.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_9-1783495866324.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_9-1783495866324.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_9-1783495866324.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F391573iFBCE7557A1EF23FB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22XPW_9-1783495866324.png%22%20alt%3D%22XPW_9-1783495866324.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22XPW_10-1783495886502.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_10-1783495886502.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_10-1783495886502.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_10-1783495886502.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_10-1783495886502.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_10-1783495886502.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F391574i26C32A0342D82D24%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22XPW_10-1783495886502.png%22%20alt%3D%22XPW_10-1783495886502.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%85%A8%E5%B1%80%E5%8F%98%E9%87%8F%E5%88%9D%E5%A7%8B%E5%8C%96%E5%A4%B1%E8%B4%A5%3C%2FSPAN%3E%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%E8%AF%B7%E9%97%AE%E6%98%AF%E5%90%A6%E6%9C%89%E6%9B%B4%E5%A5%BD%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2392837%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20chip%2C%20failed%20to%20download%20using%20bootloader%20after%20adding%20eMCEM_1%20module%20in%20spd%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2392837%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F253799%22%20target%3D%22_blank%22%3E%40XPW%3C%2FA%3E%20%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E6%A0%B9%E6%8D%AE%E6%88%AA%E5%9B%BE%E6%9D%A5%E7%9C%8B%EF%BC%8C%E5%8F%98%E9%87%8F%E6%9C%80%E5%88%9D%E5%88%9D%E5%A7%8B%E5%8C%96%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8C%E5%9C%A8%20eMCEM%20%E5%88%9D%E5%A7%8B%E5%8C%96%E4%B9%8B%E5%90%8E%EF%BC%8CClock_Ip_pfkNotificationsCallback%20%E5%8C%85%E5%90%AB%E4%B8%80%E4%B8%AA%E6%97%A0%E6%95%88%E6%8C%87%E9%92%88%E3%80%82%3CBR%20%2F%3EeMCEM%20%E5%B9%B6%E4%B8%8D%E4%BC%9A%E7%A5%9E%E5%A5%87%E5%9C%B0%E6%94%B9%E5%8F%98%E6%8C%87%E9%92%88%E5%80%BC%E3%80%82%E8%BF%99%E7%9C%8B%E8%B5%B7%E6%9D%A5%E6%9B%B4%E5%83%8F%E6%98%AF%E4%BB%A5%E4%B8%8B%E5%87%A0%E7%A7%8D%E9%97%AE%E9%A2%98%E4%B9%8B%E4%B8%80%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E5%90%AF%E5%8A%A8%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%88.data%20%E5%89%AF%E6%9C%AC%20%2F%20.bss%EF%BC%89%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%89%E6%9C%AA%E6%AD%A3%E7%A1%AE%E5%AE%8C%E6%88%90%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E5%9C%A8%20main()%20%E5%87%BD%E6%95%B0%E4%B9%8B%E5%89%8D%E5%8F%91%E7%94%9F%20RAM%20%E6%8D%9F%E5%9D%8F%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E8%BF%9E%E6%8E%A5%E6%AE%B5%E9%87%8D%E5%8F%A0%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E5%A0%86%E6%A0%88%E6%8D%9F%E5%9D%8F%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CP%3E%E6%82%A8%E8%83%BD%E5%90%A6%E4%BD%BF%E7%94%A8%20SPD%20%E6%BC%94%E7%A4%BA%E9%A1%B9%E7%9B%AE%E4%B8%AD%E7%9A%84%E9%93%BE%E6%8E%A5%E5%99%A8%E6%96%87%E4%BB%B6%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%EF%BC%8C%E4%B8%B9%E5%B0%BC%E5%B0%94%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2394590%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20chip%2C%20failed%20to%20download%20using%20bootloader%20after%20adding%20eMCEM_1%20module%20in%20spd%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2394590%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E9%93%BE%E6%8E%A5%E6%96%87%E4%BB%B6%E5%B7%B2%E4%BF%AE%E6%94%B9%E5%A6%82%E4%B8%8B%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22XPW_0-1783992772039.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_0-1783992772039.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_0-1783992772039.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_0-1783992772039.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392155i1C471094F4695BBC%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22XPW_0-1783992772039.png%22%20alt%3D%22XPW_0-1783992772039.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22XPW_1-1783993101988.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_1-1783993101988.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_1-1783993101988.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_1-1783993101988.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392157iCC50024C7BCA4988%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22XPW_1-1783993101988.png%22%20alt%3D%22XPW_1-1783993101988.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%AE%9A%E4%B9%89%E4%BA%86%E4%B8%89%E4%B8%AA%E5%85%A8%E5%B1%80%E5%8F%98%E9%87%8F%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22XPW_2-1783993317537.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_2-1783993317537.png%22%20style%3D%22width%3A%20349px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_2-1783993317537.png%22%20style%3D%22width%3A%20349px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_2-1783993317537.png%22%20style%3D%22width%3A%20349px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392158iB5E2C998B6F1978F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22XPW_2-1783993317537.png%22%20alt%3D%22XPW_2-1783993317537.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%8F%91%E7%8E%B0%E5%BD%93%E6%9C%AA%E5%90%AF%E7%94%A8%3CEMCEM_1%3E%E6%97%B6%EF%BC%8C%E6%89%A7%E8%A1%8Cinit_data-bss%E5%90%8E%EF%BC%8C%3C%2FEMCEM_1%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22XPW_3-1783993342206.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_3-1783993342206.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_3-1783993342206.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_3-1783993342206.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392159i7865EDD92BD3FF80%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22XPW_3-1783993342206.png%22%20alt%3D%22XPW_3-1783993342206.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22XPW_4-1783993406406.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_4-1783993406406.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_4-1783993406406.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_4-1783993406406.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392160i9787895A31F61605%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22XPW_4-1783993406406.png%22%20alt%3D%22XPW_4-1783993406406.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%AE%83%E4%BC%BC%E4%B9%8E%E5%B7%B2%E6%8C%89%204%20%E5%AD%97%E8%8A%82%E5%AF%B9%E9%BD%90%E5%B9%B6%E6%AD%A3%E7%A1%AE%E8%B5%8B%E5%80%BC%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%E5%BD%93%E6%88%91%E5%90%AF%E7%94%A8%3CEMCEM_1%3E%E5%90%8E%EF%BC%8C%E6%89%A7%E8%A1%8Cinit_data-bss%E5%90%8E%3C%2FEMCEM_1%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22XPW_5-1783994068084.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_5-1783994068084.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_5-1783994068084.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_5-1783994068084.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392161i4F54F1D19129E3DA%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22XPW_5-1783994068084.png%22%20alt%3D%22XPW_5-1783994068084.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22XPW_6-1783994226472.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_6-1783994226472.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_6-1783994226472.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22XPW_6-1783994226472.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F392162iD074AEBACB368A41%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22XPW_6-1783994226472.png%22%20alt%3D%22XPW_6-1783994226472.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%AE%83%E4%BC%BC%E4%B9%8E%E6%B2%A1%E6%9C%89%E5%AF%B9%E9%BD%90%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2395687%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20chip%2C%20failed%20to%20download%20using%20bootloader%20after%20adding%20eMCEM_1%20module%20in%20spd%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2395687%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%BF%99%E7%A7%8D%E7%8E%B0%E8%B1%A1%E7%9A%84%E5%8E%9F%E5%9B%A0%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%E6%88%91%E5%BA%94%E8%AF%A5%E5%A6%82%E4%BD%95%E8%B0%83%E6%9F%A5%E5%92%8C%E8%A7%A3%E5%86%B3%E5%AE%83%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2396432%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K344%20chip%2C%20failed%20to%20download%20using%20bootloader%20after%20adding%20eMCEM_1%20module%20in%20spd%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2396432%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F253799%22%20target%3D%22_blank%22%3E%40XPW%3C%2FA%3E%20%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E6%A0%B9%E6%8D%AE%E6%88%AA%E5%9B%BE%E6%9D%A5%E7%9C%8B%EF%BC%8C%E6%88%91%E5%B9%B6%E4%B8%8D%E8%AE%A4%E4%B8%BA%E5%8F%98%E9%87%8F%E5%88%9D%E5%A7%8B%E5%8C%96%E6%9C%AC%E8%BA%AB%E5%AD%98%E5%9C%A8%E9%97%AE%E9%A2%98%E3%80%82variable_a%20%E6%98%AF%E4%B8%80%E4%B8%AA%208%20%E4%BD%8D%E5%8F%98%E9%87%8F%EF%BC%8C%E5%90%AF%E7%94%A8%20eMCEM%20%E4%BC%9A%E5%BC%95%E5%85%A5%E5%85%B6%E4%BB%96%E5%8F%98%E9%87%8F%EF%BC%8C%E8%BF%99%E5%8F%AF%E8%83%BD%E4%BC%9A%E6%94%B9%E5%8F%98%20.data%20%E7%9A%84%E5%B8%83%E5%B1%80%E3%80%82%E9%83%A8%E5%88%86%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E7%9C%8B%E5%88%B0%E5%8F%98%E9%87%8F%E5%A4%84%E4%BA%8E%E4%B8%8D%E5%90%8C%E7%9A%84%E5%81%8F%E7%A7%BB%E9%87%8F%E6%98%AF%E6%AD%A3%E5%B8%B8%E7%9A%84%EF%BC%8C%E8%BF%99%E6%9C%AC%E8%BA%AB%E5%B9%B6%E4%B8%8D%E8%A1%A8%E7%A4%BA%E5%AD%98%E5%9C%A8%E6%95%B0%E6%8D%AE%E6%8D%9F%E5%9D%8F%E3%80%82%3CBR%20%2F%3E%E6%88%91%E8%AE%A4%E4%B8%BA%E5%85%B3%E9%94%AE%E9%97%AE%E9%A2%98%E6%98%AF%EF%BC%8C%E5%BD%93%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E7%8B%AC%E7%AB%8B%E7%BB%84%E7%BD%91%20%5C%5C(SA%5C%5C)%E6%97%B6%E4%BC%9A%E5%87%BA%E7%8E%B0%E6%AD%A4%E9%97%AE%E9%A2%98%EF%BC%8C%E8%BF%98%E6%98%AF%E5%8F%AA%E6%9C%89%E5%9C%A8%E9%80%9A%E8%BF%87%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E7%BC%96%E7%A8%8B%E5%92%8C%E5%90%AF%E5%8A%A8%E6%97%B6%E6%89%8D%E4%BC%9A%E5%87%BA%E7%8E%B0%E6%AD%A4%E9%97%AE%E9%A2%98%E3%80%82%3CBR%20%2F%3E%E8%83%BD%E5%90%A6%E5%9C%A8%E4%B8%8D%E4%BD%BF%E7%94%A8%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E7%9B%B4%E6%8E%A5%E4%BD%BF%E7%94%A8%E8%B0%83%E8%AF%95%E5%99%A8%E5%AF%B9%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E8%BF%9B%E8%A1%8C%E7%BC%96%E7%A8%8B%E5%B9%B6%E8%BF%90%E8%A1%8C%E8%AF%A5%E7%A8%8B%E5%BA%8F%EF%BC%8C%E4%BB%8E%E8%80%8C%E9%87%8D%E7%8E%B0%E8%AF%A5%E9%97%AE%E9%A2%98%EF%BC%9F%E5%A6%82%E6%9E%9C%E9%97%AE%E9%A2%98%E4%BB%85%E5%9C%A8%E9%80%9A%E8%BF%87%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E5%8A%A0%E8%BD%BD%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%90%8E%E5%87%BA%E7%8E%B0%EF%BC%8C%E5%88%99%E8%B0%83%E6%9F%A5%E5%BA%94%E9%9B%86%E4%B8%AD%E5%9C%A8%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E7%BC%96%E7%A8%8B%E8%BF%87%E7%A8%8B%E3%80%81%E6%98%A0%E5%83%8F%E5%B8%83%E5%B1%80%E6%88%96%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E4%BA%A4%E6%8E%A5%E4%B8%8A%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E6%9C%AC%E8%BA%AB%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%EF%BC%8C%E4%B8%B9%E5%B0%BC%E5%B0%94%3C%2FP%3E%3C%2FLINGO-BODY%3E
