S32K344 SPI+DMA send data error
2,375件の閲覧回数
_tian_10
Hi all!
      Recently also read our forum posts, RTD configuration also refer to part of the post configuration, but the use of DMA asynchronous sending mode, the sent data is not correct, the first data is often all 0, and the data sent after is often the content of the previous data. However, the function of cache is not opened, I do not know why this situation exists. The attachment provides a project for configuring SPI and DMA, please help to check whether there is any problem with the configuration.
Best Regards
tian
2,344件の閲覧回数
danielmartynek
Hi Tian,
I just checked the linker file and system.c, and the cache is enabled on the SRAM where you have the buffers.
Have you tried placing it into .mcal_bss_no_cacheable?
https://community.nxp.com/t5/S32K/S32K344-UART-DMA-example/td-p/1583510
3 返答(返信)
2,345件の閲覧回数
danielmartynek
Hi Tian,
2,304件の閲覧回数
_tian_10
Thank you very much! It can work normally!
2,326件の閲覧回数
_tian_10
Thank you very much! It can work normally.To be honest, there is no research on memory allocation. Thank you again for your prompt reply!
%3CLINGO-SUB%20id%3D%22lingo-sub-1868744%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K344%20SPI%2BDMA%20%E9%80%81%E4%BF%A1%E3%83%87%E3%83%BC%E3%82%BF%20%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1868744%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%9A%86%E3%81%95%E3%82%93%E3%80%81%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%EF%BC%81%3C%2FP%3E%3CP%3E%E6%9C%80%E8%BF%91%E3%80%81%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A9%E3%83%A0%E3%81%AE%E6%8A%95%E7%A8%BF%E3%82%82%E8%AA%AD%E3%82%93%E3%81%A7%E3%80%81RTD%E6%A7%8B%E6%88%90%E3%82%82%E6%8A%95%E7%A8%BF%E6%A7%8B%E6%88%90%E3%81%AE%E4%B8%80%E9%83%A8%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81DMA%E9%9D%9E%E5%90%8C%E6%9C%9F%E9%80%81%E4%BF%A1%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%9F%E3%83%87%E3%83%BC%E3%82%BF%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%AA%E3%81%8F%E3%80%81%E6%9C%80%E5%88%9D%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AF%E3%81%99%E3%81%B9%E3%81%A60%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E5%A4%9A%E3%81%8F%E3%80%81%E5%BE%8C%E3%81%AB%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%82%8B%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AF%E5%89%8D%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E5%86%85%E5%AE%B9%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%88%E3%81%8F%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E6%A9%9F%E8%83%BD%E3%81%8C%E9%96%8B%E3%81%8B%E3%81%9A%E3%80%81%E3%81%AA%E3%81%9C%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E7%8A%B6%E6%B3%81%E3%81%8C%E5%AD%98%E5%9C%A8%E3%81%99%E3%82%8B%E3%81%AE%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E6%B7%BB%E4%BB%98%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%81%AF%E3%80%81SPI%E3%81%8A%E3%82%88%E3%81%B3DMA%E3%82%92%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%8C%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81%E6%A7%8B%E6%88%90%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E5%BD%B9%E7%AB%8B%E3%81%A6%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%86%E3%82%A3%E3%82%A2%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1869265%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AS32K344%20SPI%20%2B%20DMA%E9%80%81%E4%BF%A1%E3%83%87%E3%83%BC%E3%82%BF%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1869265%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%81%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99!%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1869263%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AS32K344%20SPI%20%2B%20DMA%E9%80%81%E4%BF%A1%E3%83%87%E3%83%BC%E3%82%BF%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1869263%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%81%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%AD%A3%E7%9B%B4%E3%81%AA%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%E3%83%A1%E3%83%A2%E3%83%AA%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E7%A0%94%E7%A9%B6%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E8%BF%85%E9%80%9F%E3%81%AA%E8%BF%94%E4%BF%A1%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F!%3C%2FLINGO-BODY%3E
