S32K344 Platform Module Related Issues
3,322 次查看
chuanlin
Platform -> Generic Interrupt Settings ->INT0_ What is the interrupt ISR name for the IRQn ->Handler option filled in but not found.
3,298 次查看
chuanlin
Received . Thank you !   INT0 in Platform Module_ How to define the handler of IRQn!
5 回复数
3,300 次查看
Senlent
Hi@chuanlin
I sent you a private message, this demo is based on an old version of the SDK, but it is not complicated, just for your reference.
3,299 次查看
chuanlin
3,280 次查看
chuanlin
Thank you. I thought the issue with this interrupt was not defined, but now I have turned it off and the dual core communication has been successful
3,292 次查看
Senlent
Hi@chuanlin
I don't familiar with the configuration of EB,but this module has no interrupts ,so i think you don't have to define the handle here.
3,284 次查看
chuanlin
If there is no interruption, did I use this module when triggering interruption communication between my dual cores
