S32K344 Disabling CAN Overload frames
1,062件の閲覧回数
dane_vs10
Hello, as part of our requirements we cannot use a CAN controller that outputs overload frames. I see in section 74.3.10.5 of the S32K3XX Reference Manual that the FlexCAN module is programmed to transmit overload frames. Is there an option to disable this feature?
Thank you.
タグ(2)
1,024件の閲覧回数
Senlent
Hi@dane_vs10
The user cannot enable or disable the overload frame.
This is managed by the CAN controller according to the specification protocol.
