S32K344-Application debug authorization mode
Simon-Liu
Contributor V
Hello
I see in RM that in the table [Feature configuration in CUST_DEL Device Life Cycle] there are settings as shown in the figure below. When modifying the debugging mode through HSE, is the debugging of the Application software?
The default state is Password-based approach, but I can debug directly using S32DS without using HSE, without a password.
Or does the debugging here refer to debugging HSE?
BestRegards,
Simon
lukaszadrapa
Hi @Simon-Liu
"Table 194. Feature configuration in CUST_DEL Device Life Cycle" shows what should be configured in CUST_DEL life cycle. It does not say that these features take effect in CUST_DEL life cycle.
Debuging of HSE core is not allowed for users at all.
Application debug port is open in CUST_DEL life cycle. After advancing to OEM_PROD or to IN_FIELD, it is mandatory to use ADKP (password or key).
If you don't use HSE, you can follow this article:
https://community.nxp.com/t5/S32K-Knowledge-Base/S32K3-Restrict-the-debug-access-with-a-password-whe...
If you use HSE, the ADKP configuration should be done by HSE services. You can find an example in this package:
https://www.nxp.com/webapp/Download?colCode=S32K3_HSE_DemoExamples
The example is:
c:\NXP\S32K3_HSE_DemoExamples_1_0_0\S32K3_HSE_DemoExamples\Device_Configuration\S32K344_CQC_DEMO\
Lukas
lukaszadrapa
Hi @Simon-Liu
The example is:
Lukas
Simon-Liu
Contributor V
Hi, @lukaszadrapa
Thank you for your answer.
I understand that whether a password is required for debugging is related to the life cycle.
BestRegards,
Simon
%3CLINGO-SUB%20id%3D%22lingo-sub-2014871%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K344-Application%20debug%20authorization%20mode%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2014871%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%3C%2FP%3E%3CP%3EI%20see%20in%20RM%20that%20in%20the%20table%20%5BFeature%20configuration%20in%20CUST_DEL%20Device%20Life%20Cycle%5D%20there%20are%20settings%20as%20shown%20in%20the%20figure%20below.%20When%20modifying%20the%20debugging%20mode%20through%20HSE%2C%20is%20the%20debugging%20of%20the%20Application%20software%3F%3CBR%20%2F%3EThe%20default%20state%20is%20Password-based%20approach%2C%20but%20I%20can%20debug%20directly%20using%20S32DS%20without%20using%20HSE%2C%20without%20a%20password.%3CBR%20%2F%3EOr%20does%20the%20debugging%20here%20refer%20to%20debugging%20HSE%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBestRegards%2C%3C%2FP%3E%3CP%3ESimon%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2015880%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32K344-Application%20debug%20authorization%20mode%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2015880%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F37795%22%20target%3D%22_blank%22%3E%40lukaszadrapa%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3EThank%20you%20for%20your%20answer.%3CBR%20%2F%3EI%20understand%20that%20whether%20a%20password%20is%20required%20for%20debugging%20is%20related%20to%20the%20life%20cycle.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBestRegards%2C%3C%2FP%3E%3CP%3ESimon%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2015877%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32K344-Application%20debug%20authorization%20mode%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2015877%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F218611%22%20target%3D%22_blank%22%3E%40Simon-Liu%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%22Table%20194.%20Feature%20configuration%20in%20CUST_DEL%20Device%20Life%20Cycle%22%20shows%20what%20should%20be%20configured%20in%20CUST_DEL%20life%20cycle.%20It%20does%20not%20say%20that%20these%20features%20take%20effect%20in%20CUST_DEL%20life%20cycle.%3C%2FP%3E%0A%3CP%3EDebuging%20of%20HSE%20core%20is%20not%20allowed%20for%20users%20at%20all.%20%3CBR%20%2F%3EApplication%20debug%20port%20is%20open%20in%20CUST_DEL%20life%20cycle.%20After%20advancing%20to%20OEM_PROD%20or%20to%20IN_FIELD%2C%20it%20is%20mandatory%20to%20use%20ADKP%20(password%20or%20key).%3C%2FP%3E%0A%3CP%3EIf%20you%20don't%20use%20HSE%2C%20you%20can%20follow%20this%20article%3A%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FS32K3-Restrict-the-debug-access-with-a-password-when-HSE-is-not%2Fta-p%2F1735073%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FS32K3-Restrict-the-debug-access-with-a-password-when-HSE-is-not%2Fta-p%2F1735073%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EIf%20you%20use%20HSE%2C%20the%20ADKP%20configuration%20should%20be%20done%20by%20HSE%20services.%20You%20can%20find%20an%20example%20in%20this%20package%3A%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DS32K3_HSE_DemoExamples%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DS32K3_HSE_DemoExamples%3C%2FA%3E%3CBR%20%2F%3EThe%20example%20is%3A%3CBR%20%2F%3Ec%3A%5CNXP%5CS32K3_HSE_DemoExamples_1_0_0%5CS32K3_HSE_DemoExamples%5CDevice_Configuration%5CS32K344_CQC_DEMO%5C%3C%2FP%3E%0A%3CP%3ERegards%2C%3CBR%20%2F%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E
