S32K322 FLEXCAN THROUGH DMA
4,050件の閲覧回数
vignesh3
ERFCR[ERFEN] this register is not precent in S32K322 controller.
an one more thing and can anyone give me step by step example code for can through dma.
4,007件の閲覧回数
Senlent
Hi@vignesh3
This part is described in detail in the data sheet.
S32K3xx Reference Manual, Rev. 9, 07/2024:
10 返答(返信)
3,962件の閲覧回数
vignesh3
If message buffer is received a CAN message will it request DMA channel or Is it only legacy fifo is requesting the DMA ?
3,968件の閲覧回数
vignesh3
How can I know that if peripherals are requesting to the DMA channel or not ?
3,998件の閲覧回数
vignesh3
I have one more doubt also, can you tell me when to use Message buffers , Mail boxes and RXFIO(legacy fifo and enhanced fifo)?
3,994件の閲覧回数
Senlent
Hi@vignesh3
The message buffers and mail boxes you mentioned should be the same concept.
1. When sending, you must use MB.
2. Receiving can be MB or FIFO.
3. Legacy FIFO and Enhanced FIFO cannot be enabled at the same time. The difference is that Enhanced FIFO can be used for CAN FD, while Legacy FIFO cannot support CAN FD.
2,612件の閲覧回数
vigneshv1
Hi @Senlent ,
According to above picture it looks like RxFIFO and mailbox are same is it correct?
3,848件の閲覧回数
vignesh3
Hi @Senlent ,
So can I use message buffers for receiving and transmitting through DMA instead of using legacy RX FIFO.
an Is the message buffer address is present in the SRAM area because I have studied that we can use non configured message buffers as SRAM in the application notes ?
3,832件の閲覧回数
Senlent
Hi@vignesh3
Create a new topic for your new question, this original topic is closed.
4,024件の閲覧回数
vignesh3
we are receiving all the CAN messages in this Flexcan_Ip_StateType FlexCAN_BOARD_InitPeripherals_State0; global variable.
the message buffers are implemented in this structure. can anyone tell me how RAM space is assigned as CAN message buffers.
4,008件の閲覧回数
Senlent
Hi@vignesh3
4,038件の閲覧回数
Senlent
Hi@vignesh3
As you can see that the FlexCAN 0 of S32K322 do supports Enhanced Fido
S32K3xx Referernce Manual, Rev9.9/07/2024, the Table 488.
For FlexCAN with DMA used , you may refer to this post by Petr,
https://community.nxp.com/t5/S32K-Knowledge-Base/Example-S32K344-FlexCAN-Ip-TX-RX-EnhanceRXFIFO-DMA-...
%3CLINGO-SUB%20id%3D%22lingo-sub-2063492%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EDMA%E3%81%AB%E3%82%88%E3%82%8BFLEXCAN%20S32K322%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2063492%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EERFCR%5BERFEN%5D%20%E3%81%93%E3%81%AE%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AF%E3%80%81S32K322%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%A7%E3%81%AF%20precent%20%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%82%E3%81%861%E3%81%A4%E3%80%81DMA%E3%82%92%E9%80%9A%E3%81%98%E3%81%A6CAN%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%83%90%E3%82%A4%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%AE%E4%BE%8B%E3%82%92%E3%81%A9%E3%81%AA%E3%81%9F%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2069137%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3ADMA%E3%81%AB%E3%82%88%E3%82%8BFLEXCAN%E3%81%AES32K322%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2069137%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%40%3CSPAN%3Evignesh3%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%96%B0%E3%81%97%E3%81%84%E8%B3%AA%E5%95%8F%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%E3%83%88%E3%83%94%E3%83%83%E3%82%AF%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%81%93%E3%81%AE%E5%85%83%E3%81%AE%E3%83%88%E3%83%94%E3%83%83%E3%82%AF%E3%81%AF%E9%96%89%E3%81%98%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2068755%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3ADMA%E3%81%AB%E3%82%88%E3%82%8BFLEXCAN%E3%81%AES32K322%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2068755%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F188029%22%20target%3D%22_blank%22%3E%40Senlent%3C%2FA%3E%20%E3%80%81%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%9D%E3%81%AE%E3%81%9F%E3%82%81%E3%80%81%E5%BE%93%E6%9D%A5%E3%81%AE%20RX%20FIFO%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%E3%80%81DMA%20%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%E5%8F%97%E4%BF%A1%E3%81%8A%E3%82%88%E3%81%B3%E9%80%81%E4%BF%A1%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%20%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3Ean%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%83%BB%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%BB%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%81%8CSRAM%E9%A0%98%E5%9F%9F%E3%81%AB%E5%AD%98%E5%9C%A8%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AF%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%BB%E3%83%8E%E3%83%BC%E3%83%88%E3%81%A7%E6%9C%AA%E6%A7%8B%E6%88%90%E3%81%AE%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%83%BB%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%92SRAM%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E5%AD%A6%E7%BF%92%E3%81%97%E3%81%9F%E3%81%9F%E3%82%81%E3%81%A7%E3%81%99%E3%81%8B%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2065493%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3ADMA%E3%81%AB%E3%82%88%E3%82%8BFLEXCAN%E3%81%AES32K322%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2065493%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%8CCAN%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81DMA%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%82%92%E8%A6%81%E6%B1%82%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E5%BE%93%E6%9D%A5%E3%81%AEfifo%E3%81%AE%E3%81%BF%E3%81%8CDMA%E3%82%92%E8%A6%81%E6%B1%82%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2065481%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3ADMA%E3%81%AB%E3%82%88%E3%82%8BFLEXCAN%E3%81%AES32K322%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2065481%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%81%8CDMA%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB%E3%81%AB%E8%A6%81%E6%B1%82%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%AF%E3%80%81%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2064395%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3ADMA%E3%81%AB%E3%82%88%E3%82%8BFLEXCAN%E3%81%AES32K322%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2064395%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22mailto%3AHi%40vignesh3%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EHi%40vignesh3%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E8%A8%80%E5%8F%8A%E3%81%97%E3%81%9F%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%A8%E3%83%A1%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%81%AF%E5%90%8C%E3%81%98%E6%A6%82%E5%BF%B5%E3%81%A7%E3%81%82%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E1.%E9%80%81%E4%BF%A1%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AF%E3%80%81MB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E2.%20%E5%8F%97%E4%BF%A1%E3%81%AFMB%E3%81%BE%E3%81%9F%E3%81%AFFIFO%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E3.%20%E3%83%AC%E3%82%AC%E3%82%B7%E3%83%BC%20FIFO%20%E3%81%A8%E6%8B%A1%E5%BC%B5%20FIFO%20%E3%82%92%E5%90%8C%E6%99%82%E3%81%AB%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E9%81%95%E3%81%84%E3%81%AF%E3%80%81%E6%8B%A1%E5%BC%B5%20FIFO%20%E3%81%AF%20CAN%20FD%20%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%AE%E3%81%AB%E5%AF%BE%E3%81%97%E3%80%81%E5%BE%93%E6%9D%A5%E3%81%AE%20FIFO%20%E3%81%AF%20CAN%20FD%20%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2064392%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3ADMA%E3%81%AB%E3%82%88%E3%82%8BFLEXCAN%E3%81%AES32K322%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2064392%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%82%82%E3%81%861%E3%81%A4%E7%96%91%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%80%81%E3%83%A1%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%80%81RXFIO(%E3%83%AC%E3%82%AC%E3%82%B7%E3%83%BCFIFO%E3%81%8A%E3%82%88%E3%81%B3%E6%8B%A1%E5%BC%B5FIFO)%E3%82%92%E3%81%84%E3%81%A4%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2063764%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3ADMA%E3%81%AB%E3%82%88%E3%82%8BFLEXCAN%E3%81%AES32K322%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2063764%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%81%AEFlexcan_Ip_StateType%20FlexCAN_BOARD_InitPeripherals_State0%E3%81%A7%E3%81%AF%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AECAN%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%B0%E3%83%AD%E3%83%BC%E3%83%90%E3%83%AB%E5%A4%89%E6%95%B0%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%83%BB%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E6%A7%8B%E9%80%A0%E4%BD%93%E3%81%AB%E3%82%A4%E3%83%B3%E3%83%97%E3%83%AA%E3%83%A1%E3%83%B3%E3%83%88%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82RAM%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%8CCAN%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%81%A8%E3%81%97%E3%81%A6%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%80%81%E3%81%A9%E3%81%AA%E3%81%9F%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2197469%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K322%20FLEXCAN%20THROUGH%20DMA%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2197469%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22vigneshv1_0-1762166837382.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22vigneshv1_0-1762166837382.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F363713i0ADBDF85D303CE95%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22vigneshv1_0-1762166837382.png%22%20alt%3D%22vigneshv1_0-1762166837382.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F188029%22%20target%3D%22_blank%22%3E%40Senlent%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%3CP%3E%E4%B8%8A%E3%81%AE%E5%9B%B3%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81RxFIFO%20%E3%81%A8%E3%83%A1%E3%83%BC%E3%83%AB%E3%83%9C%E3%83%83%E3%82%AF%E3%82%B9%E3%81%AF%E5%90%8C%E3%81%98%E3%82%88%E3%81%86%E3%81%AB%E8%A6%8B%E3%81%88%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E6%AD%A3%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E
