S32K322 CMP DAC
S32K322 CMP DAC
jichengyou
hello there:
    I would like to know if, in the S32K322, I can use its CMP's DAC to simulate a Sin wave form?
    If possible, could you please help me find an example routine and provide a brief explanation?
    If it doesn't work, are there any other feasible solutions?
thanks.
_Leo_
Thank you for your interest in our products and for contributing to our community.
The DAC of LPCMP module is for internal reference. There is no way to route such signal to an external pin.
What you can do is to emulate a DAC signal converting a PWM signal into an analog voltage by averaging the signal's pulse duty cycle using a low-pass filter.
I hope this information is helpful.
%3CLINGO-SUB%20id%3D%22lingo-sub-2157467%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K322%20CMP%20DAC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2157467%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehello%20there%3A%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%26nbsp%3BI%20would%20like%20to%20know%20if%2C%20in%20the%20S32K322%2C%20I%20can%20use%20its%20CMP's%20DAC%20to%20simulate%20a%20Sin%20wave%20form%3F%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20If%20possible%2C%20could%20you%20please%20help%20me%20find%20an%20example%20routine%20and%20provide%20a%20brief%20explanation%3F%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20If%20it%20doesn't%20work%2C%20are%20there%20any%20other%20feasible%20solutions%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Ethanks.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2157832%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K322%20CMP%20DAC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2157832%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you%20for%20your%20interest%20in%20our%20products%20and%20for%20contributing%20to%20our%20community.%3C%2FP%3E%0A%3CP%3EThe%20DAC%20of%20LPCMP%20module%20is%20for%20internal%20reference.%20There%20is%20no%20way%20to%20route%20such%20signal%20to%20an%20external%20pin.%3C%2FP%3E%0A%3CP%3EWhat%20you%20can%20do%20is%20to%20emulate%20a%20DAC%20signal%20converting%20a%20PWM%20signal%20into%20an%20analog%20voltage%20by%20averaging%20the%20signal's%20pulse%20duty%20cycle%20using%20a%20low-pass%20filter.%3C%2FP%3E%0A%3CP%3EI%20hope%20this%20information%20is%20helpful.%3C%2FP%3E%3C%2FLINGO-BODY%3E
