S32K314-SAI TMD mode
1,877 次查看
ellie
How to use SAI1 to config TDM mode? I use following setting but not waveform from oscilloscope.
Can SAI1 TDM mode produce to 8 channels base on S32K314? Do you have any sample code or manual?
1,829 次查看
danielmartynek
Hi @ellie,
Please find the attached example.
BR, Daniel
1,830 次查看
danielmartynek
Hi @ellie,
BR, Daniel
