S32K312 uart AsyncReceive callback event is always error when SPI DMA transfer mass data
gan89557
S32K312 S32DS3.5 RTD4.0.0 project, SPI0 and SPI1 work with DMA mode, and UART1 work with Interrupt mode.
UART1 work well when sync send or async receive a frame  of 12 bytes.
But uart AsyncReceive callback event is always error when SPI DMA transfer mass data.
Any suggestion?
gan89557
Yes, It is the Interrupt Priority Issue, Uart1 works after Raising it's Priority.
Thanks so much!
PetrS
there can be below possible reasons for UART Async Receive Errors during SPI DMA bursts:
1. Interrupt Priority Issue
- UART RX interrupt is not serviced quickly because DMA completion or other ISRs have equal or higher priority.
- Result: UART RX FIFO overflows → overrun or framing error.
Ensure LPUART1_IRQn has higher priority (numerically lower) than all DMA-related IRQs (e.g., DMATCDx_IRQn). Confirm interrupt grouping allows preemption.
2. Bus Occupation by DMA
- eDMA channels for SPI can saturate the AXBS crossbar during large bursts.
- CPU and peripheral register accesses (including UART RX handling) are delayed, increasing ISR latency.
Configure SPI DMA channels to allow eDMA engine stalls (BWC setting)
BR, Petr
%3CLINGO-SUB%20id%3D%22lingo-sub-2261799%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K312%20%20uart%20AsyncReceive%20callback%20event%20is%20always%20error%20when%20SPI%20DMA%20transfer%20mass%20data%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2261799%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%26nbsp%3B%3C%2FP%3E%3CP%3ES32K312%20S32DS3.5%20RTD4.0.0%20project%2C%20SPI0%20and%20SPI1%20work%20with%20DMA%20mode%2C%20and%20UART1%20work%20with%20Interrupt%20mode.%3C%2FP%3E%3CP%3EUART1%20work%20well%20when%20sync%20send%20or%20async%20receive%20a%20frame%26nbsp%3B%20of%2012%20bytes.%3C%2FP%3E%3CP%3EBut%20uart%20AsyncReceive%20callback%20event%20is%20always%20error%20when%20SPI%20DMA%20transfer%20mass%20data.%3C%2FP%3E%3CP%3EAny%20suggestion%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2262730%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K312%20%20uart%20AsyncReceive%20callback%20event%20is%20always%20error%20when%20SPI%20DMA%20transfer%20mass%20data%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2262730%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CDIV%3E%0A%3CP%3Ethere%20can%20be%20below%20possible%20reasons%20for%20UART%20Async%20Receive%20Errors%20during%20SPI%20DMA%20bursts%3A%3C%2FP%3E%0A%3CP%3E1.%20Interrupt%20Priority%20Issue%3C%2FP%3E%0A%3CP%3E-%20UART%20RX%20interrupt%20is%20not%20serviced%20quickly%20because%20DMA%20completion%20or%20other%20ISRs%20have%20equal%20or%20higher%20priority.%3CBR%20%2F%3E%3CSPAN%3E-%20Result%3A%20UART%20RX%20FIFO%20overflows%20%E2%86%92%20overrun%20or%20framing%20error.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EEnsure%20LPUART1_IRQn%20has%20higher%20priority%20(numerically%20lower)%20than%20all%20DMA-related%20IRQs%20(e.g.%2C%20DMATCDx_IRQn).%26nbsp%3BConfirm%20interrupt%20grouping%20allows%20preemption.%3C%2FP%3E%0A%3CP%3E2.%20Bus%20Occupation%20by%20DMA%3C%2FP%3E%0A%3CP%3E-%20eDMA%20channels%20for%20SPI%20can%20saturate%20the%20AXBS%20crossbar%20during%20large%20bursts.%3CBR%20%2F%3E-%20CPU%20and%20peripheral%20register%20accesses%20(including%20UART%20RX%20handling)%20are%20delayed%2C%20increasing%20ISR%20latency.%3C%2FP%3E%0A%3CDIV%3EConfigure%20SPI%20DMA%20channels%20to%20allow%26nbsp%3BeDMA%20engine%20stalls%20(BWC%20setting)%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3EBR%2C%20Petr%3C%2FDIV%3E%0A%3CBR%20%2F%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2262870%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K312%20%20uart%20AsyncReceive%20callback%20event%20is%20always%20error%20when%20SPI%20DMA%20transfer%20mass%20data%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2262870%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EYes%2C%20It%20is%20the%20Interrupt%20Priority%20Issue%2C%20Uart1%20works%20after%20Raising%20it's%20Priority.%3C%2FP%3E%3CP%3EThanks%20so%20much!%3C%2FP%3E%3C%2FLINGO-BODY%3E
