S32K312's SRAM is overflow
2,745 次查看
shiqi_seventeen
S32K3_Project_1004_A_CANFD_V5.elf section `.heap' will not fit in region `int_sram' region `int_sram' overflowed by 176 bytes
2,729 次查看
Senlent
Hi@shiqi_seventeen
Similar problems are as follows, you can try to modify the link file to solve this problem.
https://community.nxp.com/t5/S32K/can-t-increase-heap-size-in-s32/td-p/1574647
2,723 次查看
shiqi_seventeen
Hello,@ Senlent. there is a question ,what level of code optimization does S32DS generally use?
2,730 次查看
Senlent
Hi@shiqi_seventeen
