Hello
Is there any sample program for watchdog and detailed instructions?
BestRegards,
Simon
解決済! 解決策の投稿を見る。
This may be a problem with the IDE, you can try the following methods, maybe this problem will disappear
try to remove the “compatibility.xml” located at “C:\NXP\S32DS.3.4\eclipse\mcu_data\configuration”
you can find reference demo code in S32 DS like picture below.
for more detail, you need to read datasheet.
Hello @Senlent
Thank you for your reply.
I have used S32DS to generate samples before, but some errors were reported so the code cannot be generated (the tool did not report errors when I generated other samples before). Can you give me your project for reference?
BestRegards,
Simon
please tell me the RTD version you're using and you can try to click Update Code button, this issue maybe will disappear
Hello @Senlent
Thank you for the attachment you provided.
I deleted the file "compatibility.xml" but the problem still exists.
BestRegards,
Simon
