S32K312 Wakeup using RTC timer
Akhil1
Hello
I am working on S32K312 and I want to make S32K312 to go to standby mode and need to wakeup using RTC timer for 5 sec.
after going to standby mode...need to wakeup after 5 sec automatically.
can you please help me regarding this and share any project examples.
Akhil
Senlent
Hi@Akhil1
Here is some demo you can refer to:
https://community.nxp.com/t5/S32K-Knowledge-Base/S32K3-Low-Power-Management-AN-and-demos/ta-p/152772...
be note, these demo based on RTD 2.0.0 and S32 DS V3.4
Akhil1
Hi @Senlent ,
Can you send me the RTD 3.0.0 version of S32K312 with RTC wakeup timer.
Senlent
Hi@Akhil1
Sorry, that's all we have, you can port it to new RTD version by yourself.
Akhil1
Hi @Senlent ,
I am trying to port into 3.0.0....but I am not getting the output.
Controller is going to sleep mode, but it is not wakeup after 5 sec.
I cannot share the project file because of some reasons. can you please help me.
Akhil
Senlent
Hi@Akhil1
The demo in the linker which i provided to you is working or not?
There is no big difference in RTD 2.0.0 vs RTD 3.0.0, It must a problem that something wrong with your porting.
Akhil1
Hi @Senlent ,
I have made all the configurations...but what is the mistake...i cant find it
Controller is going to sleep mode...but it is not getting wakeup.
Can you please help me.
Senlent
Hi@Akhil1
test RTC is working as expected or not,
If yes, check is RTC have set as wake up source or not.
Akhil1
Hi @Senlent ,
How can I check it?
Senlent
Hi@Akhil1
use debuger tool to see the RTC interrupt or other behavior is expected or not.
