S32K312 Mini-EVB - Unable to enter debug mode, GDB Server connection failure
673件の閲覧回数
autouser
Problem Description:
The S32K312 Mini-EVB was previously debugging correctly, but now it fails to enter debug mode. The GDB Server is
unable to establish a connection to the target processor.
Error Message:
"Launching PortSciNet Debug_FLASH has encountered a problem - Error in services launch sequence"
"The GDB Server was not able to establish a connection to the target processor. Please check your connections and
power, verify that the launch configuration settings including the Debug Configuration are accurate."
Troubleshooting Steps Already Attempted:
1. Checked PEmicro Connection Assistant:
- Board is detected: Multilink Universal Rev A on USB1
- Selected "Auto" connection speed
- Enabled "Delay after Reset and before communicating to target"
- Build completes successfully with 0 errors, 0 warnings
2. Attempted Firmware Update using Universal Multilink Firmware Update Utility (v9.90.00.00):
- Hardware Type: Multilink Universal - Low cost Debug Interface
- Device: Multilink Universal Rev C (PEM647663) (ARM Configuration)
- Architecture: ARM
- Firmware File: usbmlfsufarmens.1152 (Automatic selection)
- Result: Last Result = Success (Firmware update completed successfully)
3. Used PEmicro JTAG/ARM Recovery Utility (within S32DS):
- Detected interface hardware with old firmware:
- Required Firmware: 200.240
- Original Firmware: 7.95
- Update Firmware: 9.10
- Existing INCT Firmware "option" block...
- Result: Flash Erase Failed, Result > 5000: Firmware update failed. Retry?
4. Used P&E Kinetis Recovery Utility (v0.02):
- Interface Libraries Version: 1.06.00.00
- Detected: USB1: Multilink Universal Rev C (PEM647663)
- Communication: SWD
- Cable Version: 341
- Status: "Continuously attempting to halt processor. Please try power cycling your board until this operation is
successful"
- Power cycling the board did not resolve the issue
Observations:
- The debugger hardware (Multilink Universal) is detected by the PC
- Build process completes without errors
- Firmware update via P&E Utility shows "Success" but the recovery utility shows firmware mismatch (Required:
200.240 vs Original: 7.95)
- The processor cannot be halted even after multiple power cycles
- The board was working correctly before this issue started
Questions:
1. Why is the Kinetis Recovery Utility unable to halt the processor despite successful firmware updates?
2. Is there a specific sequence to recover the S32K312 MCU when it's in this state?
3. Could there be a firmware version conflict between the Multilink debugger and S32K312 target?
4. Are there any additional recovery procedures or tools recommended for this situation?
562件の閲覧回数
davidtosenovjan
%3CLINGO-SUB%20id%3D%22lingo-sub-2349359%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K312%20Mini-EVB%20-%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E5%85%A5%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81GDB%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%B8%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2349359%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%95%8F%E9%A1%8C%E3%81%AE%E8%AA%AC%E6%98%8E%EF%BC%9A%3C%2FP%3E%3CP%3ES32K312%20Mini-EVB%E3%81%AF%E4%BB%A5%E5%89%8D%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%A7%E3%81%8D%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E7%8F%BE%E5%9C%A8%E3%81%AF%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E5%85%A5%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82GDB%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AF%3CBR%20%2F%3E%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%B8%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%82%92%E7%A2%BA%E7%AB%8B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%3A%3CBR%20%2F%3E%20%E3%80%8CPortSciNet%20Debug_FLASH%E3%81%AE%E8%B5%B7%E5%8B%95%E4%B8%AD%E3%81%AB%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20%E3%82%B5%E3%83%BC%E3%83%93%E3%82%B9%E8%B5%B7%E5%8B%95%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E3%81%A7%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%8D%3C%2FP%3E%3CP%3EGDB%E3%82%B5%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AF%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%B8%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%82%92%E7%A2%BA%E7%AB%8B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E6%8E%A5%E7%B6%9A%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%E9%9B%BB%E6%BA%90%E3%82%92%E5%85%A5%E3%82%8C%E3%80%81%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E6%A7%8B%E6%88%90%E3%82%92%E5%90%AB%E3%82%80%E8%B5%B7%E5%8B%95%E6%A7%8B%E6%88%90%E8%A8%AD%E5%AE%9A%E3%81%8C%E6%AD%A3%E7%A2%BA%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E---%3CBR%20%2F%3E%E6%97%A2%E3%81%AB%E8%A9%A6%E3%81%97%E3%81%9F%E3%83%88%E3%83%A9%E3%83%96%E3%83%AB%E3%82%B7%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E6%89%8B%E9%A0%86%EF%BC%9A%3C%2FP%3E%3CP%3E1.%20PEmicro%E6%8E%A5%E7%B6%9A%E3%82%A2%E3%82%B7%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%88%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%20-%20%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%20USB1%20%E4%B8%8A%E3%81%AE%20Multilink%20Universal%20Rev%20A%3CBR%20%2F%3E%20-%20%E6%8E%A5%E7%B6%9A%E9%80%9F%E5%BA%A6%E3%82%92%E3%80%8C%E8%87%AA%E5%8B%95%E3%80%8D%E3%81%AB%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E-%20%E3%80%8C%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E5%BE%8C%E3%80%81%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%B8%E3%81%AE%E9%80%9A%E4%BF%A1%E5%89%8D%E3%81%AB%E9%81%85%E5%BB%B6%E3%82%92%E8%A8%AD%E3%81%91%E3%82%8B%E3%80%8D%E3%82%92%E6%9C%89%E5%8A%B9%E5%8C%96%3CBR%20%2F%3E%E3%83%93%E3%83%AB%E3%83%89%E3%81%AF%E3%82%A8%E3%83%A9%E3%83%BC0%E4%BB%B6%E3%80%81%E8%AD%A6%E5%91%8A0%E4%BB%B6%E3%81%A7%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E2.%20Universal%20Multilink%20Firmware%20Update%20Utility%20(v9.90.00.00)%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%E3%81%AE%E8%A9%A6%E8%A1%8C%3A%3CBR%20%2F%3E%20-%20%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%BF%E3%82%A4%E3%83%97%EF%BC%9A%E3%83%9E%E3%83%AB%E3%83%81%E3%83%AA%E3%83%B3%E3%82%AF%E3%83%A6%E3%83%8B%E3%83%90%E3%83%BC%E3%82%B5%E3%83%AB%20-%20%E4%BD%8E%E3%82%B3%E3%82%B9%E3%83%88%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%3CBR%20%2F%3E-%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3A%20Multilink%20Universal%20Rev%20C%20(PEM647663)%20(ARM%E6%A7%8B%E6%88%90)%3CBR%20%2F%3E%20-%20%E3%82%A2%E3%83%BC%E3%82%AD%E3%83%86%E3%82%AF%E3%83%81%E3%83%A3%3A%20ARM%3CBR%20%2F%3E%20-%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%EF%BC%9Ausbmlfsufarmens.1152%EF%BC%88%E8%87%AA%E5%8B%95%E9%81%B8%E6%8A%9E%EF%BC%89%3CBR%20%2F%3E%E7%B5%90%E6%9E%9C%EF%BC%9A%E6%9C%80%E7%B5%82%E7%B5%90%E6%9E%9C%EF%BC%9D%E6%88%90%E5%8A%9F%EF%BC%88%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%89%3C%2FP%3E%3CP%3E3.%20PEmicro%20JTAG%2FARM%E3%83%AA%E3%82%AB%E3%83%90%E3%83%AA%E3%83%A6%E3%83%BC%E3%83%86%E3%82%A3%E3%83%AA%E3%83%86%E3%82%A3%EF%BC%88S32DS%E5%86%85%EF%BC%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%20-%20%E5%8F%A4%E3%81%84%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E6%A4%9C%E5%87%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%20-%20%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%3A%20200.240%3CBR%20%2F%3E%20-%20%E3%82%AA%E3%83%AA%E3%82%B8%E3%83%8A%E3%83%AB%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%3A%207.95%3CBR%20%2F%3E%20-%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%3A%209.10%3CBR%20%2F%3E%20-%20%E6%97%A2%E5%AD%98%E3%81%AEINCT%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%80%8C%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%80%8D%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF...%3CBR%20%2F%3E%20-%20%E7%B5%90%E6%9E%9C%3A%20%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E6%B6%88%E5%8E%BB%E5%A4%B1%E6%95%97%E3%80%81%E7%B5%90%E6%9E%9C%20%26gt%3B%205000%3A%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%E5%A4%B1%E6%95%97%E3%80%82%E3%83%AA%E3%83%88%E3%83%A9%E3%82%A4%EF%BC%9F%3C%2FP%3E%3CP%3E4.%20P%26amp%3BE%20Kinetis%20Recovery%20Utility%20(v0.02)%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%20-%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%201.06.00.00%3CBR%20%2F%3E%20-%20%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%20USB1%3A%20%E3%83%9E%E3%83%AB%E3%83%81%E3%83%AA%E3%83%B3%E3%82%AF%E3%83%A6%E3%83%8B%E3%83%90%E3%83%BC%E3%82%B5%E3%83%AB%20Rev%20C%20(PEM647663)%3CBR%20%2F%3E%20-%20%E3%82%B3%E3%83%9F%E3%83%A5%E3%83%8B%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%3A%20SWD%3CBR%20%2F%3E%20-%20%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%20341%3CBR%20%2F%3E%20-%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%3A%20%E3%80%8C%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%AE%E5%81%9C%E6%AD%A2%E3%82%92%E7%B6%99%E7%B6%9A%E7%9A%84%E3%81%AB%E8%A9%A6%E3%81%BF%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%80%8D%E3%81%93%E3%81%AE%E6%93%8D%E4%BD%9C%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%99%E3%82%8B%E3%81%BE%E3%81%A7%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E9%9B%BB%E6%BA%90%E3%82%92%E5%85%A5%E3%82%8C%E7%9B%B4%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CBR%20%2F%3E%E6%88%90%E5%8A%9F%22%3CBR%20%2F%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E9%9B%BB%E6%BA%90%E3%82%92%E5%85%A5%E3%82%8C%E7%9B%B4%E3%81%97%E3%81%A6%E3%82%82%E5%95%8F%E9%A1%8C%E3%81%AF%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E---%3CBR%20%2F%3E%E8%A6%B3%E5%AF%9F%E7%B5%90%E6%9E%9C%EF%BC%9A%3C%2FP%3E%3CP%3E-%20%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%EF%BC%88%E3%83%9E%E3%83%AB%E3%83%81%E3%83%AA%E3%83%B3%E3%82%AF%E3%83%A6%E3%83%8B%E3%83%90%E3%83%BC%E3%82%B5%E3%83%AB%EF%BC%89%E3%81%8CPC%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3CBR%20%2F%3E%E3%83%93%E3%83%AB%E3%83%89%E3%83%97%E3%83%AD%E3%82%BB%E3%82%B9%E3%81%AF%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AA%E3%81%8F%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%20-%20P%26amp%3BE%20Utility%20%E3%81%AB%E3%82%88%E3%82%8B%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E6%9B%B4%E6%96%B0%E3%81%A7%E3%81%AF%E3%80%8C%E6%88%90%E5%8A%9F%E3%80%8D%E3%81%A8%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%83%AA%E3%82%AB%E3%83%90%E3%83%AA%E3%83%A6%E3%83%BC%E3%83%86%E3%82%A3%E3%83%AA%E3%83%86%E3%82%A3%E3%81%A7%E3%81%AF%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E4%B8%8D%E4%B8%80%E8%87%B4%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%20(%E5%BF%85%E9%A0%88%3A%3CBR%20%2F%3E%20200.240%20vs%20%E3%82%AA%E3%83%AA%E3%82%B8%E3%83%8A%E3%83%AB%3A%207.95)%3CBR%20%2F%3E%20-%20%E8%A4%87%E6%95%B0%E5%9B%9E%E3%81%AE%E9%9B%BB%E6%BA%90%E6%8A%95%E5%85%A5%E5%BE%8C%E3%82%82%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%95%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%3CBR%20%2F%3E-%20%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E5%89%8D%E3%81%AF%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E---%3CBR%20%2F%3E%E8%B3%AA%E5%95%8F%3A%3C%2FP%3E%3CP%3E1.%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%9F%E3%81%AB%E3%82%82%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%81Kinetis%20Recovery%20Utility%E3%81%8C%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%AE%E3%81%AF%E3%81%AA%E3%81%9C%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3CBR%20%2F%3E%202.%20S32K312%20MCU%E3%81%8C%E3%81%93%E3%81%AE%E7%8A%B6%E6%85%8B%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%E5%BE%A9%E6%97%A7%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E7%89%B9%E5%AE%9A%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3CBR%20%2F%3E3.%20Multilink%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%E3%83%BC%E3%81%A8S32K312%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AE%E9%96%93%E3%81%A7%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E7%AB%B6%E5%90%88%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3CBR%20%2F%3E%204.%20%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E7%8A%B6%E6%B3%81%E3%81%AB%E3%81%8A%E3%81%84%E3%81%A6%E3%80%81%E4%BB%96%E3%81%AB%E6%8E%A8%E5%A5%A8%E3%81%95%E3%82%8C%E3%82%8B%E5%BE%A9%E6%97%A7%E6%89%8B%E9%A0%86%E3%82%84%E3%83%84%E3%83%BC%E3%83%AB%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2350595%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K312%20Mini-EVB%20-%20Unable%20to%20enter%20debug%20mode%2C%20GDB%20Server%20connection%20failure%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2350595%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%93%E3%81%93%E3%81%A7%E5%9B%9E%E7%AD%94%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%90%8C%E3%81%98%E3%83%88%E3%83%94%E3%83%83%E3%82%AF%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K%2FS32K312MINI-EVB-Unable-to-enter-debug-mode-Cannot-halt-processor%2Fm-p%2F2349362%2Fhighlight%2Ffalse%23M57862%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K%2FS32K312MINI-EVB-Unable-to-enter-debug-mode-Cannot-halt-processor%2Fmp%2F2349362%2Fhighlight%2Ffalse%23M57862%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
