S32K312 MCU clock setting config not add
guochuan
hi all
When debugging VLPS mode, you cannot create a new clock setting. When configuring the clock in run mode, you need to configure the clock in VLPS mode. When you create McuClockSettingConfig in s32ds tool, the message repeated is displayed, indicating that no new clock can be created. Where is this change clock name configuration?
Can you share a routine from RUN mode to VLPS mode.
thanks
Guochuan Li
Senlent
Senlent
guochuan
HI @Senlent
thank you reply.
