S32K311 SPI communication sample project
1,546 次查看
gayathri123
can anyone support SPI_DMA configuration in s32k311 for tx and rx data
3 回复数
1,515 次查看
VaneB
Hi @gayathri123
Refer to the example code below. It should help as guidance for the implementation you intend to achieve.
Example S32K31 SPI multiple packet Transmit & Receive : solution for DMA Cache issue
BR, VaneB
1,467 次查看
gayathri123
but in your example code Enable Cache support is enabled under cache driver configuration not in MCL cache configuration like 2nd image
1,458 次查看
gayathri123
gayathri123_1-1765993708929.pnggayathri123_2-1765993719097.pnggayathri123_3-1765993725725.pnggayathri123_4-1765993733762.pnggayathri123_5-1765993740308.pnggayathri123_6-1765993749270.pnggayathri123_7-1765993756562.pnggayathri123_8-1765993765588.png
* ExternalMemory.c
* Created on: Dec 13, 2025
* Author: Ajay Gupta
#include "ExternalMemory.h"
#include "Siul2_Port_Ip.h"
#include "Siul2_Dio_Ip.h"
#include "Cache_Ip.h"
#include "Lpspi_Ip.h"
#include "CDD_Rm.h"
#include "Dma_Ip.h"
#include <string.h>
volatile bool g_spiTransferComplete = false;
volatile uint32_t g_W25Q_ID = 0;
#ifdef USE_NON_CHACHABLE_REGION
/* Allocated in non-cacheable RAM: No manual cache cleaning needed */
#pragma GCC section bss ".mcal_bss_no_cacheable"
__attribute__(( aligned(32) )) uint8_t RxBuffer[BCC_MSG_SIZE];
#pragma GCC section data ".mcal_data_no_cacheable"
__attribute__(( aligned(32) )) uint8_t TxBuffer[BCC_MSG_SIZE] = {0};
#else
/* Allocated in cacheable RAM: Requires Cache_Ip_Clean/Invalidate */
__attribute__(( aligned(32) )) uint8_t TxBuffer[BCC_MSG_SIZE];
#endif
* winbond W25Q16JV - 16 megabits in size.
W25Q16 pins Spi pins in Mcu
Cs pin connected to Fcs(SPI2)
Data out connected to Miso(SPI2)
Data in connected to Mosi(SPI2)
Clock connected to clock(SPI2)
Standard(single)SPI has 4 pins: Clk, CS, Din, Dout.
this 16 megabits variant has the memory distributed among the 8192 programmable pages, each page being 256 bytes in size.
We can program 256 bytes at once.
we can't erase a single page but we can erase a grp of 16 pages which is called a sector and is 4kb in size that can be erased.
we can also erase a block which is a group of 128 pages(32Kb)or 256 pages(64Kb)
block diagram of memory:
for ex: we have 1 block which has 16 sectors, each sector is 4 kb in size and contains 16 pages. 1 block =16sector x 16 pages =256 pages.
in w25q16jv we have 32 blocks in total 256 pages for 1 block x 32 block=8192 pages.
void lpspi_callback_dma(uint8 Instance, Lpspi_Ip_EventType Event)
if(Event == LPSPI_IP_EVENT_END_TRANSFER)
/* If cacheable, Invalidate ensures we fetch the fresh DMA data from main memory */
#ifndef USE_NON_CHACHABLE_REGION
Cache_Ip_InvalidateByAddr(CACHE_IP_CORE, CACHE_IP_DATA, (uint32)&RxBuffer[0U], BCC_MSG_SIZE);
#endif
g_spiTransferComplete = true;
else if (Event == LPSPI_IP_EVENT_FAULT)
* Function Name: W25Q_Reset
* Description: Before starting a new session with the chip we should reset it.
* This would terminate any on going operation and the device will return to its default power-on state.
* It will lose all the current volatile settings, such as Volatile Status Register bits, Write Enable Latch (WEL) status, Program/Erase Suspend status, Read parameter setting (P7-P0) and Wrap Bit setting (W6-W4).
* To avoid the accidental Reset, a Reset command is made of 2 instructions. these Instructions, “Enable Reset (66h)” and “Reset (99h)” must be issues in a sequence. Once the Reset command is accepted by the device, the device will take approximately 30us to reset. During this period, no command will be accepted.
Lpspi_Ip_StatusType W25Q_Reset(void)
Lpspi_Ip_StatusType status;
/* Enable Reset (0x66) */
memset(TxBuffer, 0, BCC_MSG_SIZE);
TxBuffer[0] = 0x66;
Cache_Ip_CleanByAddr(CACHE_IP_CORE, CACHE_IP_DATA, TRUE, (uint32)&TxBuffer[0U], 1);
#endif
status = Lpspi_Ip_AsyncTransmit(&MASTER_EXTERNAL_DEVICE, TxBuffer, NULL, 1, lpspi_callback_dma);
if (status != LPSPI_IP_STATUS_SUCCESS) return status;
while(g_spiTransferComplete == false);
/* Reset (0x99) */
TxBuffer[0] = 0x99;
#endif
for (volatile uint32 i = 0; i < 5000; i++);
return LPSPI_IP_STATUS_SUCCESS;
Lpspi_Ip_StatusType W25Q_ReadID(void)
memset(RxBuffer, 0, BCC_MSG_SIZE);
TxBuffer[0] = 0x9F;
Cache_Ip_CleanByAddr(CACHE_IP_CORE, CACHE_IP_DATA, TRUE, (uint32)&TxBuffer[0U], 4);
#endif
/* Send 1 cmd byte and receive 3 ID bytes */
status = Lpspi_Ip_AsyncTransmit(&MASTER_EXTERNAL_DEVICE, TxBuffer, RxBuffer, 4, lpspi_callback_dma);
g_W25Q_ID = ((uint32_t)RxBuffer[1] << 16) | ((uint32_t)RxBuffer[2] << | (uint32_t)RxBuffer[3];
* ExternalMemory.h
#ifndef EXTERNALMEMORY_EXTERNALMEMORY_H_
#define EXTERNALMEMORY_EXTERNALMEMORY_H_
#include <stdint.h>
#include <stdbool.h>
#include "CDD_Rm.h"
#include "Dma_Ip.h"
#define USE_NON_CHACHABLE_REGION 1
#define No_of_Blocks 32
#define BCC_MSG_SIZE 12U
#define MASTER_EXTERNAL_DEVICE Lpspi_Ip_DeviceAttributes_SpiExternalDevice_0_Instance_2
extern Lpspi_Ip_StatusType lpspi_status;
extern Lpspi_Ip_HwStatusType lpspi_hw_status;
extern volatile bool g_spiTransferComplete;
void lpspi_callback_dma(uint8 Instance, Lpspi_Ip_EventType Event);
Lpspi_Ip_StatusType W25Q_Reset (void);
Lpspi_Ip_StatusType W25Q_ReadID (void);
#endif /* EXTERNALMEMORY_EXTERNALMEMORY_H_ */
void SPI_DMA_Init(void)
    /* Initialize Dma */
    Dma_Ip_Init(&Dma_Ip_xDmaInitPB);
    /* Initialize Rm driver for using DmaMux*/
    Rm_Init(&Rm_Config);
    IntCtrl_Ip_EnableIrq(DMATCD0_IRQn);
    IntCtrl_Ip_EnableIrq(DMATCD1_IRQn);
    /* Initialise the LPSPI module*/
    lpspi_status = Lpspi_Ip_Init(&Lpspi_Ip_PhyUnitConfig_SpiPhyUnit_1_Instance_2);
    Lpspi_Ip_UpdateTransferMode(MASTER_EXTERNAL_DEVICE.Instance, LPSPI_IP_INTERRUPT);
clock and pin initialization also i have done can anyone check whether this configuration is correct
%3CLINGO-SUB%20id%3D%22lingo-sub-2263871%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K311%20SPI%20%E9%80%9A%E4%BF%A1%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2263871%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%98%AF%E5%90%A6%E6%9C%89%E4%BA%BA%E6%94%AF%E6%8C%81%E5%9C%A8%20s32k311%20%E4%B8%AD%E4%B8%BA%E5%8F%91%E9%80%81%E5%92%8C%E6%8E%A5%E6%94%B6%E6%95%B0%E6%8D%AE%E9%85%8D%E7%BD%AE%20SPI_DMA%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2264146%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K311%20SPI%20communication%20sample%20project%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2264146%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F256645%22%20target%3D%22_blank%22%3E%40gayathri123%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E5%8F%82%E8%80%83%E4%B8%8B%E9%9D%A2%E7%9A%84%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%E3%80%82%E5%AE%83%E5%BA%94%E6%9C%89%E5%8A%A9%E4%BA%8E%E4%B8%BA%E6%82%A8%E6%89%93%E7%AE%97%E5%AE%9E%E7%8E%B0%E7%9A%84%E5%AE%9E%E6%96%BD%E5%B7%A5%E4%BD%9C%E6%8F%90%E4%BE%9B%E6%8C%87%E5%AF%BC%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FExample-S32K31-SPI-multiple-packet-Transmit-amp-Receive-solution%2Fta-p%2F2130091%22%20target%3D%22_blank%22%3E%E7%A4%BA%E4%BE%8B%20S32K31%20SPI%20%E5%A4%9A%E4%B8%AA%E6%95%B0%E6%8D%AE%E5%8C%85%E5%8F%91%E9%80%81%26amp%3B%20%E6%8E%A5%E6%94%B6%EF%BC%9ADMA%20%E7%BC%93%E5%AD%98%E9%97%AE%E9%A2%98%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%E3%80%81VaneB%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2265178%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K311%20SPI%20communication%20sample%20project%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2265178%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22gayathri123_0-1765988285652.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22gayathri123_0-1765988285652.png%22%20style%3D%22width%3A%20374px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22gayathri123_0-1765988285652.png%22%20style%3D%22width%3A%20374px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F370469iBF76D8F91071F893%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22gayathri123_0-1765988285652.png%22%20alt%3D%22gayathri123_0-1765988285652.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22gayathri123_1-1765988292018.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22gayathri123_1-1765988292018.png%22%20style%3D%22width%3A%20322px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22gayathri123_1-1765988292018.png%22%20style%3D%22width%3A%20322px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F370470iE43B14B993412770%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22gayathri123_1-1765988292018.png%22%20alt%3D%22gayathri123_1-1765988292018.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%BD%86%E5%9C%A8%E6%82%A8%E7%9A%84%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%E4%B8%AD%EF%BC%8C%E5%90%AF%E7%94%A8%E7%BC%93%E5%AD%98%E6%94%AF%E6%8C%81%E6%98%AF%E5%9C%A8%E7%BC%93%E5%AD%98%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E9%85%8D%E7%BD%AE%E4%B8%8B%E5%90%AF%E7%94%A8%E7%9A%84%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%E5%9C%A8%20MCL%20%E7%BC%93%E5%AD%98%E9%85%8D%E7%BD%AE%E4%B8%8B%E5%90%AF%E7%94%A8%E7%9A%84%EF%BC%8C%E5%A6%82%E7%AC%AC%E4%BA%8C%E5%BC%A0%E5%9B%BE%E7%89%87%E6%89%80%E7%A4%BA%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2265244%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K311%20SPI%20communication%20sample%20project%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2265244%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22gayathri123_1-1765993708929.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22gayathri123_1-1765993708929.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F370488i8E636331513493CD%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22gayathri123_1-1765993708929.png%22%20alt%3D%22gayathri123_1-1765993708929.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22gayathri123_2-1765993719097.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22gayathri123_2-1765993719097.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F370489i32A2B23A8E6774E2%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22gayathri123_2-1765993719097.png%22%20alt%3D%22gayathri123_2-1765993719097.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22gayathri123_3-1765993725725.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22gayathri123_3-1765993725725.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F370491iE237EF885B6C656F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22gayathri123_3-1765993725725.png%22%20alt%3D%22gayathri123_3-1765993725725.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22gayathri123_4-1765993733762.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22gayathri123_4-1765993733762.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F370492i93B1DECD1C1F9433%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22gayathri123_4-1765993733762.png%22%20alt%3D%22gayathri123_4-1765993733762.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22gayathri123_5-1765993740308.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22gayathri123_5-1765993740308.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F370493i0163E7D2C3AA9F92%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22gayathri123_5-1765993740308.png%22%20alt%3D%22gayathri123_5-1765993740308.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22gayathri123_6-1765993749270.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22gayathri123_6-1765993749270.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F370494i10182F0D8C68B96D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22gayathri123_6-1765993749270.png%22%20alt%3D%22gayathri123_6-1765993749270.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22gayathri123_7-1765993756562.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22gayathri123_7-1765993756562.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F370495i62B1B86217DAEC2D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22gayathri123_7-1765993756562.png%22%20alt%3D%22gayathri123_7-1765993756562.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22gayathri123_8-1765993765588.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22gayathri123_8-1765993765588.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F370496i95DB70F970576F22%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22gayathri123_8-1765993765588.png%22%20alt%3D%22gayathri123_8-1765993765588.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%2F*%3CBR%20%2F%3E*%20ExternalMemory.c%3CBR%20%2F%3E*%3CBR%20%2F%3E*%20%E5%88%9B%E5%BB%BA%E6%97%A5%E6%9C%9F%EF%BC%9ADec%2013%2C%202025%3CBR%20%2F%3E*%20Author%EF%BC%9AAjay%20Gupta%3CBR%20%2F%3E*%2F%3CBR%20%2F%3E%23include%22ExternalMemory.h%22%3CBR%20%2F%3E%20%23include%22Siul2_Port_Ip.h%22%3CBR%20%2F%3E%20%23include%22Siul2_Dio_Ip.h%22%3CBR%20%2F%3E%23include%22Cache_Ip.h%22%3CBR%20%2F%3E%23include%22Lpspi_Ip.h%22%3CBR%20%2F%3E%23include%22CDD_Rm.h%22%3CBR%20%2F%3E%23include%22Dma_Ip.h%22%3CBR%20%2F%3E%23include%3CSTRING.H%3E%3CBR%20%2F%3Evolatile%20bool%20g_spiTransferComplete%20%3D%20false%3B%3CBR%20%2F%3Evolatile%20uint32_t%20g_W25Q_ID%20%3D%200%3B%3CBR%20%2F%3E%23ifdef%20USE_NON_CHACHABLE_REGION%3CBR%20%2F%3E%2F*%20%E5%9C%A8%E4%B8%8D%E5%8F%AF%E7%BC%93%E5%AD%98%20RAM%20%E4%B8%AD%E5%88%86%E9%85%8D%EF%BC%9A%E6%97%A0%E9%9C%80%E6%89%8B%E5%8A%A8%E6%B8%85%E7%90%86%E7%BC%93%E5%AD%98%20*%2F%3CBR%20%2F%3E%23pragma%20GCC%20section%20bss%22.mcal_bss_no_cacheable%22%3CBR%20%2F%3E__attribute__((%20aligned(32)%20))%20uint8_t%20RxBuffer%5BBCC_MSG_SIZE%5D%3B%3CBR%20%2F%3E%23pragma%20GCC%20section%20bss%3C%2FSTRING.H%3E%3C%2FP%3E%3CP%3E%23pragma%20GCC%20section%20data%22.mcal_data_no_cacheable%22%3CBR%20%2F%3E__attribute__((%20aligned(32)%20))%20uint8_t%20TxBuffer%5BBCC_MSG_SIZE%5D%20%3D%20%7B0%7D%3B%3CBR%20%2F%3E%23pragma%20GCC%20section%20data%3CBR%20%2F%3E%23else%3CBR%20%2F%3E%2F*%20%E5%9C%A8%E5%8F%AF%E7%BC%93%E5%AD%98%20RAM%20%E4%B8%AD%E5%88%86%E9%85%8D%EF%BC%9A%E9%9C%80%E8%A6%81%20Cache_Ip_Clean%2FInvalidate%20*%2F%3CBR%20%2F%3E__attribute__%20((%20aligned(32)%20))%20uint8_t%20RxBuffer%5BBCC_MSG_SIZE%5D%3B%3CBR%20%2F%3E__attribute__%20((%20aligned(32)%20))%20uint8_t%20TxBuffer%5BBCC_MSG_SIZE%5D%3B%3CBR%20%2F%3E%23endif%3CBR%20%2F%3E%2F*%3CBR%20%2F%3E*%20winbond%20W25Q16JV%20-%2016%20%E5%85%86%E5%AD%97%E8%8A%82%E5%A4%A7%E5%B0%8F%E3%80%82%3C%2FP%3E%3CP%3EW25Q16%20%E5%BC%95%E8%84%9A%20Mcu%20%E4%B8%AD%E7%9A%84%20Spi%20%E5%BC%95%E8%84%9A%3CBR%20%2F%3ECs%20%E5%BC%95%E8%84%9A%E8%BF%9E%E6%8E%A5%E5%88%B0%20Fcs(SPI2)%3CBR%20%2F%3E%E6%95%B0%E6%8D%AE%E8%BE%93%E5%87%BA%E8%BF%9E%E6%8E%A5%E5%88%B0%20Miso(SPI2)%3CBR%20%2F%3E%E6%95%B0%E6%8D%AE%E8%BE%93%E5%85%A5%E8%BF%9E%E6%8E%A5%E5%88%B0%20Mosi(SPI2)%3CBR%20%2F%3E%E6%97%B6%E9%92%9F%E8%BF%9E%E6%8E%A5%E5%88%B0%20clock(SPI2)%3C%2FP%3E%3CP%3E%E6%A0%87%E5%87%86%EF%BC%88%E5%8D%95%EF%BC%89SPI%20%E6%9C%89%204%20%E4%B8%AA%E5%BC%95%E8%84%9A%EF%BC%9AClk%E3%80%81CS%E3%80%81Din%E3%80%81Dout%E3%80%82%3CBR%20%2F%3E%E8%BF%99%E4%B8%AA%2016%20%E5%85%86%E4%BD%8D%E5%8F%98%E4%BD%93%E7%9A%84%E5%86%85%E5%AD%98%E5%88%86%E5%B8%83%E5%9C%A8%208192%20%E4%B8%AA%E5%8F%AF%E7%BC%96%E7%A8%8B%E9%A1%B5%E9%9D%A2%E4%B8%AD%EF%BC%8C%E6%AF%8F%E4%B8%AA%E9%A1%B5%E9%9D%A2%E7%9A%84%E5%A4%A7%E5%B0%8F%E4%B8%BA%20256%20%E5%AD%97%E8%8A%82%E3%80%82%3CBR%20%2F%3E%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E4%B8%80%E6%AC%A1%E7%BC%96%E7%A8%8B%20256%20%E5%AD%97%E8%8A%82%E3%80%82%3CBR%20%2F%3E%E6%88%91%E4%BB%AC%E6%97%A0%E6%B3%95%E6%93%A6%E9%99%A4%E5%8D%95%E4%B8%AA%E9%A1%B5%E9%9D%A2%EF%BC%8C%E4%BD%86%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E6%93%A6%E9%99%A4%2016%20%E9%A1%B5%E7%9A%84%20grp%EF%BC%8C%E8%BF%99%E7%A7%B0%E4%B8%BA%E6%89%87%E5%8C%BA%EF%BC%8C%E5%A4%A7%E5%B0%8F%E4%B8%BA%204kb%EF%BC%8C%E5%8F%AF%E4%BB%A5%E6%93%A6%E9%99%A4%E3%80%82%3CBR%20%2F%3E%E6%88%91%E4%BB%AC%E8%BF%98%E5%8F%AF%E4%BB%A5%E6%93%A6%E9%99%A4%E7%94%B1%20128%20%E4%B8%AA%E9%A1%B5%E9%9D%A2%EF%BC%8832Kb%EF%BC%89%E6%88%96%20256%20%E4%B8%AA%E9%A1%B5%E9%9D%A2%EF%BC%8864Kb%EF%BC%89%E7%BB%84%E6%88%90%E7%9A%84%E6%95%B0%E6%8D%AE%E5%9D%97%E3%80%82%3C%2FP%3E%3CP%3E%E5%86%85%E5%AD%98%E6%A1%86%E5%9B%BE%EF%BC%9A%3CBR%20%2F%3E%E4%BE%8B%E5%A6%82%EF%BC%9A%E6%88%91%E4%BB%AC%E6%9C%89%201%20%E4%B8%AA%E5%9D%97%EF%BC%8C%E5%85%B6%E4%B8%AD%E6%9C%89%2016%20%E4%B8%AA%E6%89%87%E5%8C%BA%EF%BC%8C%E6%AF%8F%E4%B8%AA%E6%89%87%E5%8C%BA%E5%A4%A7%E5%B0%8F%E4%B8%BA%204%20kb%EF%BC%8C%E5%8C%85%E5%90%AB%2016%20%E4%B8%AA%E9%A1%B5%E9%9D%A2%E3%80%821%20%E4%B8%AA%E5%8C%BA%E5%9D%97%20%3D16%20%E4%B8%AA%E6%89%87%E5%8C%BA%20x%2016%20%E9%A1%B5%20%3D256%20%E9%A1%B5%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%20w25q16jv%20%E4%B8%AD%EF%BC%8C%E6%88%91%E4%BB%AC%E6%9C%89%2032%20%E4%B8%AA%E5%8C%BA%E5%9D%97%EF%BC%8C%E5%85%B1%20256%20%E9%A1%B5%EF%BC%8C1%20%E4%B8%AA%E5%8C%BA%E5%9D%97%20x%2032%20%E4%B8%AA%E5%8C%BA%E5%9D%97%3D8192%20%E9%A1%B5%E3%80%82%3CBR%20%2F%3E*%2F%3C%2FP%3E%3CP%3Evoid%20lpspi_callback_dma(uint8%20Instance%2C%20Lpspi_Ip_EventType%20Event)%3CBR%20%2F%3E%7B%3CBR%20%2F%3Eif(Event%20%3D%3D%20LPSPI_IP_EVENT_END_TRANSFER)%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%2F*%20%E5%A6%82%E6%9E%9C%E5%8F%AF%E7%BC%93%E5%AD%98%E3%80%81%E6%97%A0%E6%95%88%E5%8F%AF%E7%A1%AE%E4%BF%9D%E6%88%91%E4%BB%AC%E4%BB%8E%E4%B8%BB%E5%86%85%E5%AD%98%E4%B8%AD%E8%8E%B7%E5%8F%96%E6%96%B0%E7%9A%84%20DMA%20%E6%95%B0%E6%8D%AE%20*%2F%3CBR%20%2F%3E%23ifndef%20USE_NON_CHACHABLE_REGION%3CBR%20%2F%3ECache_Ip_InvalidateByAddr(CACHE_IP_CORE%2C%20CACHE_IP_DATA%2C%20(uint32)%26amp%3BRxBuffer%5B0U%5D%2C%20BCC_MSG_SIZE)%EF%BC%9B%3CBR%20%2F%3E%23endif%3C%2FP%3E%3CP%3Eg_spiTransferComplete%20%3D%20true%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3Eelse%20if%20(Event%20%3D%3D%20LPSPI_IP_EVENT_FAULT)%3CBR%20%2F%3E%7B%3CBR%20%2F%3Eg_spiTransferComplete%20%3D%20true%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%7D%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%2F*%20%3CBR%20%2F%3E%20*%20%E5%87%BD%E6%95%B0%E5%90%8D%E7%A7%B0%EF%BC%9AW25Q_Reset%20%3CBR%20%2F%3E%20*%20%E6%8F%8F%E8%BF%B0%EF%BC%9A%E5%9C%A8%E5%BC%80%E5%A7%8B%E4%BD%BF%E7%94%A8%E8%8A%AF%E7%89%87%E7%9A%84%E6%96%B0%E4%BC%9A%E8%AF%9D%E4%B9%8B%E5%89%8D%EF%BC%8C%E6%88%91%E4%BB%AC%E5%BA%94%E8%AF%A5%E5%B0%86%E5%85%B6RESET%E3%80%82%3CBR%20%2F%3E*%20%E8%BF%99%E5%B0%86%E7%BB%88%E6%AD%A2%E4%BB%BB%E4%BD%95%E6%AD%A3%E5%9C%A8%E8%BF%9B%E8%A1%8C%E7%9A%84%E6%93%8D%E4%BD%9C%EF%BC%8C%E8%AE%BE%E5%A4%87%E5%B0%86%E6%81%A2%E5%A4%8D%E5%88%B0%E5%85%B6%E9%BB%98%E8%AE%A4%E5%BC%80%E6%9C%BA%E7%8A%B6%E6%80%81%E3%80%82%3CBR%20%2F%3E*%20%E5%B0%86%E4%B8%A2%E5%A4%B1%E6%89%80%E6%9C%89%E5%BD%93%E5%89%8D%E6%98%93%E5%A4%B1%E6%80%A7%E8%AE%BE%E7%BD%AE%EF%BC%8C%E5%A6%82%E6%98%93%E5%A4%B1%E6%80%A7%E7%8A%B6%E6%80%81%E5%AF%84%E5%AD%98%E5%99%A8%E4%BD%8D%E3%80%81%E5%86%99%E4%BD%BF%E8%83%BD%E9%94%81%E5%AD%98%EF%BC%88WEL%EF%BC%89%E7%8A%B6%E6%80%81%E3%80%81%E7%BC%96%E7%A8%8B%2F%E6%93%A6%E9%99%A4%E6%9A%82%E5%81%9C%E7%8A%B6%E6%80%81%E3%80%81%E8%AF%BB%E5%8F%96%E5%8F%82%E6%95%B0%E8%AE%BE%E7%BD%AE%EF%BC%88P7-P0%EF%BC%89%E5%92%8C%E5%8C%85%E4%BD%8D%E8%AE%BE%E7%BD%AE%EF%BC%88W6-W4%EF%BC%89%E3%80%82%3CBR%20%2F%3E*%20%E4%B8%BA%E9%81%BF%E5%85%8D%E6%84%8F%E5%A4%96%20RESET%EF%BC%8CRESET%20%E5%91%BD%E4%BB%A4%E7%94%B1%202%20%E6%9D%A1%E6%8C%87%E4%BB%A4%E7%BB%84%E6%88%90%E3%80%82%E8%BF%99%E4%BA%9B%20%E2%80%9C%E5%90%AF%E7%94%A8%20RESET%20(66h)%E2%80%9D%20%E5%92%8C%20%E2%80%9CRESET%20(99h)%E2%80%9D%20%E6%8C%87%E4%BB%A4%E5%BF%85%E9%A1%BB%E6%8C%89%E9%A1%BA%E5%BA%8F%E5%87%BA%E5%8F%B0%E3%80%82%E8%AE%BE%E5%A4%87%E6%8E%A5%E5%8F%97%20RESET%20%E5%91%BD%E4%BB%A4%E5%90%8E%EF%BC%8C%E8%AE%BE%E5%A4%87%E5%B0%86%E8%8A%B1%E8%B4%B9%E5%A4%A7%E7%BA%A6%2030us%20%E6%9D%A5%E5%AE%8C%E6%88%90%20RESET%E3%80%82%E5%9C%A8%E6%AD%A4%E6%9C%9F%E9%97%B4%EF%BC%8C%E4%B8%8D%E6%8E%A5%E5%8F%97%E4%BB%BB%E4%BD%95%E6%8C%87%E4%BB%A4%E3%80%82%3CBR%20%2F%3E*%2F%3CBR%20%2F%3ELpspi_Ip_StatusType%20W25Q_Reset(void)%3CBR%20%2F%3E%7B%3CBR%20%2F%3ELpspi_Ip_StatusType%20status%EF%BC%9B%3C%2FP%3E%3CP%3E%2F*%20%E5%90%AF%E7%94%A8%20RESET%20(0x66)%20*%2F%3CBR%20%2F%3Ememset(TxBuffer%2C%200%2C%20BCC_MSG_SIZE)%3B%3CBR%20%2F%3ETxBuffer%5B0%5D%20%3D%200x66%3B%3CBR%20%2F%3Eg_spiTransferComplete%20%3D%20false%3B%3C%2FP%3E%3CP%3E%23ifndef%20USE_NON_CHACHABLE_REGION%3CBR%20%2F%3ECache_Ip_CleanByAddr(CACHE_IP_CORE%2C%20CACHE_IP_DATA%2C%20TRUE%2C%20(uint32)%26amp%3BTxBuffer%5B0U%5D%2C%201)%3B%3CBR%20%2F%3E%23endif%3C%2FP%3E%3CP%3Estatus%20%3D%20Lpspi_Ip_AsyncTransmit(%26amp%3BMASTER_EXTERNAL_DEVICE%2C%20TxBuffer%2C%20NULL%2C%201%2C%20lpspi_callback_dma)%3B%3CBR%20%2F%3Eif%20(status%20!%3D%20LPSPI_IP_STATUS_SUCCESS)%20return%20status%3B%3CBR%20%2F%3Ewhile(g_spiTransferComplete%20%3D%3D%20false)%EF%BC%9B%3C%2FP%3E%3CP%3E%2F*%20RESET%20(0x99)%20*%2F%3CBR%20%2F%3ETxBuffer%5B0%5D%20%3D%200x99%3B%3CBR%20%2F%3Eg_spiTransferComplete%20%3D%20false%3B%3C%2FP%3E%3CP%3E%23ifndef%20USE_NON_CHACHABLE_REGION%3CBR%20%2F%3ECache_Ip_CleanByAddr(CACHE_IP_CORE%2C%20CACHE_IP_DATA%2C%20TRUE%2C%20(uint32)%26amp%3BTxBuffer%5B0U%5D%2C%201)%3B%3CBR%20%2F%3E%23endif%3C%2FP%3E%3CP%3Estatus%20%3D%20Lpspi_Ip_AsyncTransmit(%26amp%3BMASTER_EXTERNAL_DEVICE%2C%20TxBuffer%2C%20NULL%2C%201%2C%20lpspi_callback_dma)%3B%3CBR%20%2F%3Eif%20(status%20!%3D%20LPSPI_IP_STATUS_SUCCESS)%20return%20status%3B%3CBR%20%2F%3Ewhile(g_spiTransferComplete%20%3D%3D%20false)%EF%BC%9B%3C%2FP%3E%3CP%3Efor%20(volatile%20uint32%20i%20%3D%200%3B%20i%26lt%3B%205000%3B%20i%2B%2B)%EF%BC%9B%3C%2FP%3E%3CP%3Ereturn%20LPSPI_IP_STATUS_SUCCESS%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3ELpspi_Ip_StatusType%20W25Q_ReadID(void)%3CBR%20%2F%3E%7B%3CBR%20%2F%3ELpspi_Ip_StatusType%20status%EF%BC%9B%3C%2FP%3E%3CP%3Ememset(TxBuffer%2C%200%2C%20BCC_MSG_SIZE)%3B%3CBR%20%2F%3Ememset(RxBuffer%2C%200%2C%20BCC_MSG_SIZE)%3B%3CBR%20%2F%3ETxBuffer%5B0%5D%20%3D%200x9F%3B%3CBR%20%2F%3Eg_spiTransferComplete%20%3D%20false%EF%BC%9B%3C%2FP%3E%3CP%3E%23ifndef%20USE_NON_CHACHABLE_REGION%3CBR%20%2F%3ECache_Ip_CleanByAddr(CACHE_IP_CORE%2C%20CACHE_IP_DATA%2C%20TRUE%2C%20(uint32)%26amp%3BTxBuffer%5B0U%5D%2C%204)%3B%3CBR%20%2F%3E%23endif%3C%2FP%3E%3CP%3E%2F*%20%E5%8F%91%E9%80%81%201%20%E4%B8%AA%20cmd%20%E5%AD%97%E8%8A%82%E5%B9%B6%E6%8E%A5%E6%94%B6%203%20%E4%B8%AA%20ID%20%E5%AD%97%E8%8A%82%20*%2F%20%3CBR%20%2F%3E%20%E7%8A%B6%E6%80%81%20%3D%20lpspi_IP_AsyncTransmit%EF%BC%88%26amp%3B%20MASTER_EXTERNAL_DEVICE%E3%80%81TxBuffer%E3%80%81rxBuffer%E3%80%814%E3%80%81lpspi_callback_dma%EF%BC%89%EF%BC%9Bif%EF%BC%88%E7%8A%B6%E6%80%81%EF%BC%81%3CBR%20%2F%3E%3D%20LPSI_IP_STATUS_SUCCESS)%20%E8%BF%94%E5%9B%9E%E7%8A%B6%E6%80%81%EF%BC%9B%3C%2FP%3E%3CP%3Ewhile(g_spiTransferComplete%20%3D%3D%20false)%EF%BC%9B%3C%2FP%3E%3CP%3E%3CBR%20%2F%3Eg_W25Q_ID%20%3D%20((uint32_t)RxBuffer%5B1%5D%26lt%3B%26lt%3B%2016)%7C%20((uint32_t)RxBuffer%5B2%5D)%26lt%3B%26lt%3B%20%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-sunglasses%22%20title%3D%22%3Asmiling_face_with_sunglasses%3A%22%3E%3C%2FLI-EMOJI%3E%20%7C%20(uint32_t)RxBuffer%5B3%5D%EF%BC%9B%3C%2FP%3E%3CP%3Ereturn%20LPSPI_IP_STATUS_SUCCESS%3B%3CBR%20%2F%3E%7D%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%2F*%3CBR%20%2F%3E*%20ExternalMemory.h%3CBR%20%2F%3E*%3CBR%20%2F%3E*%20%E5%88%9B%E5%BB%BA%E6%97%A5%E6%9C%9F%EF%BC%9A2025%20%E5%B9%B4%2012%20%E6%9C%88%2013%20%E6%97%A5%3CBR%20%2F%3E*%20%E4%BD%9C%E8%80%85%EF%BC%9AAjay%20Gupta%3CBR%20%2F%3E*%2F%3C%2FP%3E%3CP%3E%23ifndef%20EXTERNALMEMORY_EXTERNALMEMORY_H_%3CBR%20%2F%3E%23define%20EXTERNALMEMORY_EXTERNALMEMORY_H_%3C%2FP%3E%3CP%3E%23include%3CSTDINT.H%3E%3CBR%20%2F%3E%23include%3CSTDBOOL.H%3E%3CBR%20%2F%3E%23include%22Cache_Ip.h%22%3CBR%20%2F%3E%23include%22Lpspi_Ip.h%22%3CBR%20%2F%3E%23include%22CDD_Rm.h%22%3CBR%20%2F%3E%23include%22Dma_Ip.h%22%3C%2FSTDBOOL.H%3E%3C%2FSTDINT.H%3E%3C%2FP%3E%3CP%3E%23define%20USE_NON_CHACHABLE_REGION%201%3CBR%20%2F%3E%23define%20No_of_Blocks%2032%3CBR%20%2F%3E%23define%20BCC_MSG_SIZE%2012U%3CBR%20%2F%3E%23define%20MASTER_EXTERNAL_DEVICE%20Lpspi_Ip_DeviceAttributes_SpiExternalDevice_0_Instance_2%3CBR%20%2F%3Eextern%20Lpspi_Ip_StatusType%20lpspi_status%EF%BC%9B%3CBR%20%2F%3Eextern%20Lpspi_Ip_HwStatusType%20lpspi_hw_status%3B%3CBR%20%2F%3Eextern%20volatile%20bool%20g_spiTransferComplete%3B%3CBR%20%2F%3Evoid%20lpspi_callback_dma(uint8%20Instance%2C%20Lpspi_Ip_EventType%20Event)%EF%BC%9B%3C%2FP%3E%3CP%3E%3CBR%20%2F%3ELpspi_Ip_StatusType%20W25Q_Reset%20(void)%3B%3CBR%20%2F%3ELpspi_Ip_StatusType%20W25Q_ReadID%20(void)%3B%3CBR%20%2F%3E%23endif%20%2F*%20EXTERNALMEMORY_EXTERNALMEMORY_H_%20*%2F%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CDIV%3Evoid%20SPI_DMA_Init(void)%3C%2FDIV%3E%3CDIV%3E%7B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%2F*%20%E5%88%9D%E5%A7%8B%E5%8C%96%20Dma%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20Dma_Ip_Init(%26amp%3BDma_Ip_xDmaInitPB)%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%2F*%20%E5%88%9D%E5%A7%8B%E5%8C%96%E4%BD%BF%E7%94%A8%20DmaMux%20%E7%9A%84%20Rm%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20Rm_Init(%26amp%3BRm_Config)%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20IntCtrl_Ip_EnableIrq%EF%BC%88DMATCD0_IRQn%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20IntCtrl_Ip_EnableIrq%EF%BC%88DMATCD1_IRQn%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20%2F*%20%E5%88%9D%E5%A7%8B%E5%8C%96%20LPSPI%20%E6%A8%A1%E5%9D%97*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20lpspi_status%20%3D%20Lpspi_Ip_Init(%26amp%3BLpspi_Ip_PhyUnitConfig_SpiPhyUnit_1_Instance_2)%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%20%20%20%20Lpspi_Ip_UpdateTransferMode(MASTER_EXTERNAL_DEVICE.Instance%2C%20LPSPI_IP_INTERRUPT)%EF%BC%9B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%7D%3C%2FDIV%3E%3CP%3E%E6%88%91%E8%BF%98%E5%AE%8C%E6%88%90%E4%BA%86%E6%97%B6%E9%92%9F%E5%92%8C%E5%BC%95%E8%84%9A%E7%9A%84%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%8C%E8%B0%81%E8%83%BD%E6%A3%80%E6%9F%A5%E4%B8%80%E4%B8%8B%E8%BF%99%E6%A0%B7%E7%9A%84%E9%85%8D%E7%BD%AE%E6%98%AF%E5%90%A6%E6%AD%A3%E7%A1%AE%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
