S32K3
S32K3
ye_jiawei
Now I am using the Ethernet of S32K344, and I need mac-to-MAC. I need TO ask NXP technical support for the connection of hardware. Could you please give me a mac-to-MAC case of K3?Thank you so much!!
lukaszadrapa
You can take a look at this board:
https://www.nxp.com/design/software/development-software/evaluation-and-development-board-for-genera...
There’s either 100BASE-TX PHY DP83848C with RJ45 connector or it is possible to connect external board with PHY like https://www.nxp.com/design/development-boards/analog-toolbox/tja1101-automotive-ethernet-adapter-for...
… which is automotive 100BASE-T1.
 So, you can use it as a reference.
 In case of this board:
https://www.nxp.com/design/development-boards/automotive-development-platforms/s32k-mcu-platforms/fu...
… there’s connector for external PHY only.
 Also see the hardware design guidelines, there are some comments about ethernet interface:
https://www.nxp.com/webapp/Download?colCode=S32K3_HW-DesignPackage
Lukas
ye_jiawei
Thank you. I took care of it!
