S32K3 RTD4.0.0 C40_IP
已解决
跳至解决方案
1,097 次查看
Neo1096
After I created the code, I only added the C40_IP module. If no code is added to the main program, the compilation will report an error version issue. How can this be solved?Neo1096_0-1749101212091.png
1 解答
987 次查看
Neo1096
2 回复数
1,077 次查看
Senlent
Hi@Neo1096
You can find "C40_Ip_Example_S32K344" in S32 DS. This example tests the C40 component.
Please compare it with this example.
If you still have the problem, please provide the test project.
988 次查看
Neo1096
