After I created the code, I only added the C40_IP module. If no code is added to the main program, the compilation will report an error version issue. How can this be solved?
Solved! Go to Solution.
Hi@Neo1096
You can find "C40_Ip_Example_S32K344" in S32 DS. This example tests the C40 component.
Please compare it with this example.
If you still have the problem, please provide the test project.
