S32K3 JTAG Password Protection
2,311 次查看
ASN7
MCU: S32K314
RTD: 3.0
HSE_B : For S32K3X4 - v0.2.1.0
I am try to password protect my JTAG on the board using HSE(I am not using Challenge/Response).
These are the steps that I am following:
1. Read the HSE Version to make sure it is active.
SOC Type ID= 5, Major Version= 2, Minor Version=1
HSE Response = 0x55a5aa33 = Success
2. Read the current lifecycle.
Current LC = 0x4 = HSE_LC_CUST_DEL
3. Check if HSE_APP_DEBUG_KEY_ATTR_ID is already set.
I do not get HSE_SRV_RSP_NOT_ALLOWED, which means ADKP is set.
4. If not set, then Set up the ADKP.
5. Check if debug auth mode set to password mode
I see 0x00 which is HSE_DEBUG_AUTH_MODE_PW.
6. I advance the Lifecycle.
    hseAttrSecureLifecycle_t programLC = HSE_LC_SIMULATED_OEM_PROD;
    HSE_AdvanceLifecycle(programLC);
In this step, I get this error: 0xAA55A21CUL = HSE_SRV_RSP_NOT_ALLOWED = The operation is not allowed because of some restrictions (in attributes, life-cycle dependent operations, key-management, etc.) */
And the program is now stuck in  ASSERT(HSE_SRV_RSP_OK == srvResponse);.
What is it that is causing the issue ? I tried to change the lifecycle to HSE_LC_IN_FIELD, HSE_LC_OEM_PROD and even HSE_LC_SIMULATED_OEM_PROD (which is what I want). But all of them throw the same error. I have set everything that is needed.
标记 (4)
4 回复数
2,278 次查看
davidtosenovjan
This procedure seems to be right. Question is how it is actually done.
Which example code are you based on?
2,271 次查看
ASN7
I created a new project just to test locking of JTAG and all my reference have been from S32K344_DemoAppTemplate.
I have copied the files and functions from S32K344_DemoAppTemplate\services\src\fw_attribute\otp\hse_debug_auth_mode.c.
2,247 次查看
davidtosenovjan
Don't you have set CUST_START_AS_USER what would lead in having User rights after reset?
1,073 次查看
kerti1
Thanks for the reply. If user rights set CUST_START_AS_USER then it won't be able to change the LC and also cannot format the keycatalogs. Even If the LC is changed to SIMULATED_OEM using super user rights. The JTAG is not getting locked
%3CLINGO-SUB%20id%3D%22lingo-sub-2130009%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K3%20JTAG%20%E5%AF%86%E7%A0%81%E4%BF%9D%E6%8A%A4%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2130009%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3EMCU%3A%20S32K314%3C%2FDIV%3E%3CDIV%3E%E7%83%AD%E7%94%B5%E9%98%BB%EF%BC%9A%203.0%3C%2FDIV%3E%3CDIV%3EHSE_B%20%3A%20%E9%80%82%E7%94%A8%E4%BA%8E%20S32K3X4%20-%20v0.2.1.0%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20HSE%20%E5%AF%B9%E6%88%91%E7%9A%84%20JTAG%20%E8%BF%9B%E8%A1%8C%E5%AF%86%E7%A0%81%E4%BF%9D%E6%8A%A4%EF%BC%88%E6%88%91%E6%B2%A1%E6%9C%89%E4%BD%BF%E7%94%A8%E8%B4%A8%E8%AF%A2%2F%E5%9B%9E%E5%BA%94%EF%BC%89%E3%80%82%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E8%BF%99%E5%B0%B1%E6%98%AF%E6%88%91%E6%AD%A3%E5%9C%A8%E9%81%B5%E5%BE%AA%E7%9A%84%E6%AD%A5%E9%AA%A4%EF%BC%9A%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E1.%E9%98%85%E8%AF%BB%20HSE%20%E7%89%88%E6%9C%AC%EF%BC%8C%E7%A1%AE%E4%BF%9D%E5%85%B6%E5%A4%84%E4%BA%8E%E6%BF%80%E6%B4%BB%E7%8A%B6%E6%80%81%E3%80%82%20%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ESOC%20%E7%B1%BB%E5%9E%8B%20ID%3D5%EF%BC%8C%E4%B8%BB%E8%A6%81%E7%89%88%E6%9C%AC%3D2%EF%BC%8C%E6%AC%A1%E8%A6%81%E7%89%88%E6%9C%AC%3D1%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EHSE%20%E5%93%8D%E5%BA%94%20%3D%200x55a5aa33%20%3D%20%E6%88%90%E5%8A%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E2.%E8%AF%BB%E5%8F%96%E5%BD%93%E5%89%8D%E7%94%9F%E5%91%BD%E5%91%A8%E6%9C%9F%E3%80%82%20%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%BD%93%E5%89%8D%20LC%20%3D%200x4%20%3D%20HSE_LC_CUST_DEL%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EHSE%20%E5%93%8D%E5%BA%94%20%3D%200x55a5aa33%20%3D%20%E6%88%90%E5%8A%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E3.%E6%A3%80%E6%9F%A5%E6%98%AF%E5%90%A6%E5%B7%B2%E8%AE%BE%E7%BD%AE%20HSE_APP_DEBUG_KEY_ATR_ID%E3%80%82%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E6%88%91%E6%B2%A1%E6%9C%89%E6%94%B6%E5%88%B0%20HSE_SRV_RSP_NOT_ALLOWED%EF%BC%8C%E8%BF%99%E6%84%8F%E5%91%B3%E7%9D%80%20ADKP%20%E5%B7%B2%E8%AE%BE%E7%BD%AE%E3%80%82%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EHSE%20%E5%93%8D%E5%BA%94%20%3D%200x55a5aa33%20%3D%20%E6%88%90%E5%8A%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E4%E3%80%82%E5%A6%82%E6%9E%9C%E6%9C%AA%E8%AE%BE%E7%BD%AE%EF%BC%8C%E5%88%99%E8%AE%BE%E7%BD%AE%20ADKP%E3%80%82%3C%2FDIV%3E%3CDIV%3E5.%E6%A3%80%E6%9F%A5%E8%B0%83%E8%AF%95%E9%AA%8C%E8%AF%81%E6%A8%A1%E5%BC%8F%E6%98%AF%E5%90%A6%E8%AE%BE%E7%BD%AE%E4%B8%BA%E5%AF%86%E7%A0%81%E6%A8%A1%E5%BC%8F%20%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E6%88%91%E7%9C%8B%E5%88%B0%200x00%EF%BC%8C%E5%8D%B3%20HSE_DEBUG_AUTH_MODE_PW%E3%80%82%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E6.%E6%88%91%E6%8E%A8%E8%BF%9B%E7%94%9F%E5%91%BD%E5%91%A8%E6%9C%9F%E3%80%82%20%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20hseAttrSecureLifecycle_t%20programLC%20%3D%20HSE_LC_SIMULATED_OEM_PROD%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%20%20%20%20HSE_AdvanceLifecycle(programLC)%EF%BC%9B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%E8%BF%99%E4%B8%80%E6%AD%A5%E4%B8%AD%EF%BC%8C%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E8%BF%99%E4%B8%AA%E9%94%99%E8%AF%AF%EF%BC%9A0xAA55A21CUL%20%3D%20HSE_SRV_RSP_NOT_ALLOWED%20%3D%20%E7%94%B1%E4%BA%8E%E6%9F%90%E4%BA%9B%E9%99%90%E5%88%B6%EF%BC%88%E5%B1%9E%E6%80%A7%E3%80%81%E7%94%9F%E5%91%BD%E5%91%A8%E6%9C%9F%E7%9B%B8%E5%85%B3%E6%93%8D%E4%BD%9C%E3%80%81%E5%AF%86%E9%92%A5%E7%AE%A1%E7%90%86%E7%AD%89%EF%BC%89%EF%BC%8C%E4%B8%8D%E5%85%81%E8%AE%B8%E8%BF%9B%E8%A1%8C%E6%93%8D%E4%BD%9C%20*%2F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E7%8E%B0%E5%9C%A8%E7%A8%8B%E5%BA%8F%E5%81%9C%E7%95%99%E5%9C%A8%20ASSERT(HSE_SRV_RSP_OK%20%3D%3D%20srvResponse)%3B%E3%80%82%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E6%98%AF%E4%BB%80%E4%B9%88%E5%AF%BC%E8%87%B4%E4%BA%86%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9F%E6%88%91%E5%B0%9D%E8%AF%95%E5%B0%86%E7%94%9F%E5%91%BD%E5%91%A8%E6%9C%9F%E6%94%B9%E4%B8%BA%20HSE_LC_IN_FIELD%E3%80%81HSE_LC_OEM_PROD%EF%BC%8C%E7%94%9A%E8%87%B3%20HSE_LC_SIMULATED_OEM_PROD%EF%BC%88%E8%BF%99%E6%AD%A3%E6%98%AF%E6%88%91%E6%83%B3%E8%A6%81%E7%9A%84%EF%BC%89%E3%80%82%E4%BD%86%E5%AE%83%E4%BB%AC%E9%83%BD%E5%87%BA%E7%8E%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E9%94%99%E8%AF%AF%E3%80%82%E6%88%91%E5%B7%B2%E7%BB%8F%E8%AE%BE%E7%BD%AE%E4%BA%86%E6%89%80%E9%9C%80%E7%9A%84%E4%B8%80%E5%88%87%E3%80%82%20%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2351662%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K3%20JTAG%20Password%20Protection%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2351662%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%E5%A6%82%E6%9E%9C%E7%94%A8%E6%88%B7%E6%9D%83%E9%99%90%E8%AE%BE%E7%BD%AE%E4%B8%BA%20CUST_START_AS_USER%EF%BC%8C%E5%88%99%E6%97%A0%E6%B3%95%E6%9B%B4%E6%94%B9%20LC%EF%BC%8C%E4%B9%9F%E6%97%A0%E6%B3%95%E6%A0%BC%E5%BC%8F%E5%8C%96%20keycatalogs%E3%80%82%E5%8D%B3%E4%BD%BF%E4%BD%BF%E7%94%A8%E8%B6%85%E7%BA%A7%E7%94%A8%E6%88%B7%E6%9D%83%E9%99%90%E5%B0%86%20LC%20%E6%9B%B4%E6%94%B9%E4%B8%BA%20SIMULATED_OEM%E3%80%82JTAG%20%E6%97%A0%E6%B3%95%E9%94%81%E5%AE%9A%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2132537%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K3%20JTAG%20Password%20Protection%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2132537%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E6%B2%A1%E6%9C%89%E8%AE%BE%E7%BD%AE%20CUST_START_AS_USER%20RESET%20%E5%90%8E%E4%BB%80%E4%B9%88%E4%BC%9A%E5%AF%BC%E8%87%B4%E7%94%A8%E6%88%B7%E6%9D%83%E9%99%90%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2131657%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K3%20JTAG%20Password%20Protection%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2131657%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%88%9B%E5%BB%BA%E4%BA%86%E4%B8%80%E4%B8%AA%E6%96%B0%E9%A1%B9%E7%9B%AE%E5%8F%AA%E6%98%AF%E4%B8%BA%E4%BA%86%E6%B5%8B%E8%AF%95%20JTAG%20%E7%9A%84%E9%94%81%E5%AE%9A%EF%BC%8C%E6%88%91%E6%89%80%E6%9C%89%E7%9A%84%E5%8F%82%E8%80%83%E9%83%BD%E6%9D%A5%E8%87%AA%20s32k344_demoAppTemplate%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E4%BB%8E%20s32k344_demoAppTemplate%5C%20services%5C%20src%5C%20fw_attribute%5C%20otp%5C%20hse_debug_auth_mode.c%20%E4%B8%AD%E5%A4%8D%E5%88%B6%E4%BA%86%E6%96%87%E4%BB%B6%E5%92%8C%E5%87%BD%E6%95%B0%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2131502%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K3%20JTAG%20Password%20Protection%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2131502%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%BF%99%E4%B8%AA%E7%A8%8B%E5%BA%8F%E4%BC%BC%E4%B9%8E%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%E3%80%82%E9%97%AE%E9%A2%98%E6%98%AF%E5%A6%82%E4%BD%95%E5%AE%9E%E9%99%85%E6%93%8D%E4%BD%9C%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22HwtZe%22%3E%3CSPAN%20class%3D%22jCAhz%20ChMk0b%22%3E%3CSPAN%20class%3D%22ryNqvb%22%3E%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%93%AA%E4%B8%AA%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%EF%BC%9F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
