S32K3 HSE
S32K3 HSE
NiLonghui
Will there be a problem if I call HSE's aes encryption and decryption interface in two threads at the same time? Assume that both threads use the same secret key.
lukaszadrapa
Hi @NiLonghui
due to nature of the HSE interface (Messaging Unit) it is not a problem to call more service requests at the same time. The requests are processed sequentially, not in parallel.
For more details, you can check following sections in the HSE-B Reference Manual:
3.5 The HSE interface
6.4.1 Service execution order
Lukas
lukaszadrapa
Hi @NiLonghui
Lukas
NiLonghui
Thank you for your answer. I also want to ask, can I export the ECC private key stored in HSE to an array in C language?
NiLonghui
Thank you very much!
