S32K3 - GPIO Wakeup example
ssean
Dear NXP.
For S32K312 GPIO Wakeup, I downloaded the S32K344_GPIO_Wkup_S32DS_3_5_RTD_4_0_0_LLD project from the link below.
https://community.nxp.com/t5/S32K-Knowledge-Base/RTD400-amp-500-MCAL-amp-IP-S32K3-Low-Power-Manageme...
In that project, under POWER → ModeSettingConf → McuModeSettingConf_SocStandby, there is a setting for Peripheral Clock Enable.
Could you tell me which items must be enabled if I only want to use the WKPU function of the GPIO port?
For example, LPCMP and PIT_0 don’t seem necessary — can I uncheck them?
Sean Sung
Senlent
Hi@ssean
"WKPU" must be checked. For the new RTD version, such as RTD 6.0.0, the MSCM must also be checked, otherwise it will enter hardfault error.
Senlent
Hi@ssean
ssean
Dear Senlent.
Thank you for reply.
%3CLINGO-SUB%20id%3D%22lingo-sub-2149721%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K3%20-%20GPIO%20Wakeup%20example%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2149721%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%20NXP.%3C%2FP%3E%3CP%3EFor%20S32K312%20GPIO%20Wakeup%2C%26nbsp%3BI%20downloaded%20the%20S32K344_GPIO_Wkup_S32DS_3_5_RTD_4_0_0_LLD%20project%20from%20the%20link%20below.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FRTD400-amp-500-MCAL-amp-IP-S32K3-Low-Power-Management-AN-and%2Fta-p%2F1993152%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FRTD400-amp-500-MCAL-amp-IP-S32K3-Low-Power-Management-AN-and%2Fta-p%2F1993152%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EIn%20that%20project%2C%26nbsp%3Bunder%20POWER%20%E2%86%92%20ModeSettingConf%20%E2%86%92%20McuModeSettingConf_SocStandby%2C%26nbsp%3Bthere%20is%20a%20setting%20for%20Peripheral%20Clock%20Enable.%3CBR%20%2F%3ECould%20you%20tell%20me%20which%20items%20must%20be%20enabled%20if%20I%20only%20want%20to%20use%20the%20WKPU%20function%20of%20the%20GPIO%20port%3F%3C%2FP%3E%3CP%3EFor%20example%2C%20LPCMP%20and%20PIT_0%20don%E2%80%99t%20seem%20necessary%20%E2%80%94%20can%20I%20uncheck%20them%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBest%20Regards%2C%3C%2FP%3E%3CP%3ESean%20Sung%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2149863%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K3%20-%20GPIO%20Wakeup%20example%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2149863%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EDear%20Senlent.%3CBR%20%2F%3EThank%20you%20for%20reply.%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2149844%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K3%20-%20GPIO%20Wakeup%20example%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2149844%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%40%3CSPAN%3Essean%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%22WKPU%22%20must%20be%20checked.%20For%20the%20new%20RTD%20version%2C%20such%20as%20RTD%206.0.0%2C%20the%20MSCM%20must%20also%20be%20checked%2C%20otherwise%20it%20will%20enter%20hardfault%20error.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
