S32K1XX FLEXCAN
已解决
S32K1XX FLEXCAN
跳至解决方案
3,831 次查看
PINKMAN
hello ,experts:
We know FLEXCAN support CAN receive by MB and RXFIFO
I have a question that when i config Message received in RXFIFO mode with interrupt ,the rxFIFO engine occupied 0-5MB,and i set 8  Rx FIFO Filters which occupied 2MB
so the first 8 MB is used for  rxFIFO engine and Filters element. there are 24 MB (S32K116)left,.
It is clear that i can config any MB in the range of left MB for transmit  ,BUT I wonder that  if i can set a MB used for Receive, Even i have used RX FIFO.
if yes ? can you share a demo for me ?
if no , that means the MB after FIFO could only used for transmit MB ?
1 解答
3,701 次查看
PetrS
up to 32 elements of the filter table are individually affected by the Individual Mask
Registers (RXIMRx), according to the setting of CTRL2[RFFN], if individual mask scheme is used (IMRQ=1). If the IRMQ bit is negated, then the FIFO filter table is affected by RXFGMASK only and RXMGMASK, RX14MASK, RX15MASK are used for rest of MBs.
BR, Petr
在原帖中查看解决方案
7 回复数
3,788 次查看
PetrS
rest of available MBs can be set for both TX and/or RX operation.
Some SDK based example is posted at https://community.nxp.com/t5/S32K-Knowledge-Base/Example-S32K144-FlexCAN-RXFIFO-DMA-S32DS-ARM-2018-R...
Hope it helps.
BR, Petr
3,778 次查看
PINKMAN
thank you ! in fact, if i use RXFIFO meanwhile i also set a MB for RX, if the message passed the filter element ,so the MB for RX will not be used ?
3,756 次查看
PetrS
depends on the setting, but if RXFIFO is set to be searched first and the Rx FIFO is a matched structure and is free-to-receive, then the Rx FIFO is the matching winner regardless of the scan for MBs. Then at the end of matching process the message is moved-in to RXFIFO.
I can recommend to read chapters Receive Process and Matching Process of the device RM.
BR, Petr
3,716 次查看
PINKMAN
i'm sorry, there is still a question that if i use RXFIFO, i can only set mask with FLEXCAN_RX_MASK_INDIVIDUAL ? which means only use RXIMR and RXFGMASK to config filter items and other MBs. uder this condition(use RXFIFO),i think use RXMGMASK, RX14MASK, RX15MASK is a wrong configration maybe?
3,702 次查看
PetrS
BR, Petr
3,683 次查看
PINKMAN
OK ,I GOT IT.NB! THANKS
3,745 次查看
PINKMAN
非常感谢
%3CLINGO-SUB%20id%3D%22lingo-sub-1954607%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K1XX%20FLEXCAN%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1954607%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%90%84%E4%BD%8D%E4%B8%93%E5%AE%B6%E6%82%A8%E5%A5%BD%EF%BC%9A%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E7%9F%A5%E9%81%93%20FLEXCAN%20%E6%94%AF%E6%8C%81%20MB%20%E5%92%8C%20RXFIFO%20%E6%8E%A5%E6%94%B6%3C%2FP%3E%3CP%3E%E6%88%91%E6%9C%89%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E5%BD%93%E6%88%91%E9%85%8D%E7%BD%AE%E5%9C%A8%E4%B8%AD%E6%96%AD%E6%A8%A1%E5%BC%8F%E4%B8%8B%E6%8E%A5%E6%94%B6%E7%9A%84%20RXFIFO%20%E6%B6%88%E6%81%AF%E6%97%B6%EF%BC%8CrxFIFO%20%E5%BC%95%E6%93%8E%E5%8D%A0%E7%94%A8%200-5MB%EF%BC%8C%E5%B9%B6%E4%B8%94%E6%88%91%E8%AE%BE%E7%BD%AE%E4%BA%86%208%20%E4%B8%AA%20Rx%20FIFO%20%E8%BF%87%E6%BB%A4%E5%99%A8%EF%BC%8C%E5%8D%A0%E7%94%A8%202MB%3C%2FP%3E%3CP%3E%E5%9B%A0%E6%AD%A4%E5%89%8D%208%20MB%20%E7%94%A8%E4%BA%8E%20rxFIFO%20%E5%BC%95%E6%93%8E%E5%92%8C%E8%BF%87%E6%BB%A4%E5%99%A8%E5%85%83%E7%B4%A0%E3%80%82%E8%BF%98%E5%89%A9%E4%B8%8B%2024%20MB%20(S32K116)%E3%80%82%3C%2FP%3E%3CP%3E%E5%BE%88%E6%98%8E%E6%98%BE%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E9%85%8D%E7%BD%AE%E5%B7%A6%E4%BE%A7%20MB%20%E8%8C%83%E5%9B%B4%E5%86%85%E7%9A%84%E4%BB%BB%E4%BD%95%20MB%20%E7%94%A8%E4%BA%8E%E4%BC%A0%E8%BE%93%EF%BC%8C%E4%BD%86%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%E6%88%91%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E8%AE%BE%E7%BD%AE%E7%94%A8%E4%BA%8E%E6%8E%A5%E6%94%B6%E7%9A%84%20MB%EF%BC%8C%E5%8D%B3%E4%BD%BF%E6%88%91%E5%B7%B2%E7%BB%8F%E4%BD%BF%E7%94%A8%E4%BA%86%20RX%20FIFO%E3%80%82%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%98%AF%20%EF%BC%9F%E4%BD%A0%E8%83%BD%E4%B8%BA%E6%88%91%E5%88%86%E4%BA%AB%E4%B8%80%E4%B8%AA%E6%BC%94%E7%A4%BA%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%B2%A1%E6%9C%89%EF%BC%8C%E9%82%A3%E6%98%AF%E5%90%A6%E6%84%8F%E5%91%B3%E7%9D%80%20FIFO%20%E4%B9%8B%E5%90%8E%E7%9A%84%20MB%20%E5%8F%AA%E8%83%BD%E7%94%A8%E4%BA%8E%E4%BC%A0%E8%BE%93%20MB%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1956670%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AS32K1XX%20FLEXCAN%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1956670%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A5%BD%E7%9A%84%EF%BC%8C%E6%88%91%E7%9F%A5%E9%81%93%E4%BA%86%E3%80%82NB%EF%BC%81%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1956146%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AS32K1XX%20FLEXCAN%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1956146%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%AF%B9%E4%B8%8D%E8%B5%B7%EF%BC%8C%E8%BF%98%E6%9C%89%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%88%91%E4%BD%BF%E7%94%A8%20RXFIFO%EF%BC%8C%E6%88%91%E5%8F%AA%E8%83%BD%E7%94%A8%20FLEXCAN_RX_MASK_INDIVIDUAL%20%E8%AE%BE%E7%BD%AE%E6%8E%A9%E7%A0%81%EF%BC%9F%E8%BF%99%E6%84%8F%E5%91%B3%E7%9D%80%E4%BB%85%E4%BD%BF%E7%94%A8%20RXIMR%20%E5%92%8C%20RXFGMASK%20%E6%9D%A5%E9%85%8D%E7%BD%AE%E8%BF%87%E6%BB%A4%E9%A1%B9%E5%92%8C%E5%85%B6%E4%BB%96%20MB%E3%80%82%E5%9C%A8%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%88%E4%BD%BF%E7%94%A8%20RXFIFO%EF%BC%89%EF%BC%8C%E6%88%91%E8%AE%A4%E4%B8%BA%E4%BD%BF%E7%94%A8%20RXMGMASK%E3%80%81RX14MASK%E3%80%81RX15MASK%20%E5%8F%AF%E8%83%BD%E6%98%AF%E9%94%99%E8%AF%AF%E7%9A%84%E9%85%8D%E7%BD%AE%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1955594%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ERe%3A%20S32K1XX%20FLEXCAN%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1955594%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1955264%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AS32K1XX%20FLEXCAN%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1955264%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%E4%BA%8B%E5%AE%9E%E4%B8%8A%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%88%91%E5%90%8C%E6%97%B6%E4%BD%BF%E7%94%A8%20RXFIFO%EF%BC%8C%E6%88%91%E4%B9%9F%E4%B8%BA%20RX%20%E8%AE%BE%E7%BD%AE%E4%B8%80%E4%B8%AA%20MB%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%B6%88%E6%81%AF%E9%80%9A%E8%BF%87%E4%BA%86%E8%BF%87%E6%BB%A4%E5%85%83%E7%B4%A0%EF%BC%8C%E9%82%A3%E4%B9%88%20RX%20%E7%9A%84%20MB%20%E5%B0%86%E4%B8%8D%E4%BC%9A%E8%A2%AB%E4%BD%BF%E7%94%A8%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E
