S32K148 Eval Board Pinout?
5,041 次查看
zbellay
Hello, NXP Community!
I am using the NXP S32K148EVB-Q144 and cannot find documentation on which header pins on the eval board correspond to which pins on the microcontroller. I have looked at S32K148_IO_Signal_Description_Input_Multiplexing.xlsx but cannot decipher, for example, how pin 16 corresponds to VSS. I may be reading the docs incorrectly, so your help would be greatly appreciated.
Thank you!
标记 (1)
4,599 次查看
danielmartynek
You can look at the EVB headers in the schematic.
4,600 次查看
danielmartynek
4,599 次查看
andrew_thornbor
Hey Daniel Martynek,
I think the link you provided is dead. Is there a place that the schematic has been moved to?
4,599 次查看
danielmartynek
Hi Andrew,
There is more than one schematic now depending on the EVB revision.
Take a look at the product web page. S32K148EVB: S32K148 Evaluation Board
Under Software & Tools / Schematics.
