S32K148 CAN Bootloader
3,563件の閲覧回数
john_keates
Has anyone successfully got a CAN Bootloader ported for the S32K148, I read a couple of people trying the Unified Bootloader but not seen any succes?
Anyone managed a successful port? or point me in the direction of someone who has a successful CAN Bootloader
3,535件の閲覧回数
danielmartynek
Hi John,
The Unified Bootloader is ported to the S32K148.
I can send you the NxpOpenBus for it.
BR, Daniel
3 返答(返信)
3,536件の閲覧回数
danielmartynek
Hi John,
BR, Daniel
2,724件の閲覧回数
sagarkapate
Does anyone can implement UDS stack s32k148 using unified bootloader in application demo code?
I am import UDS stack in application code in s32k148 controller but when instead of flashing using uds can flashing i can't send /received CAN_ID in application code.
How can we run UDS stack and application code?
My condition is when application code run in proper way without interruption but when i wanna flash new firmware in this application code then application code stop and run UDS stack.
Anyone has solution then let me know please?
3,530件の閲覧回数
john_keates
Daniel, that would be extremely useful if you could and any hints, tips or notes
Many thanks
