S32K146 watchdog timeout
已解决
跳至解决方案
2,699 次查看
yqs77
I want to enable a watchdog with 10 minutes timeout on S32K146, and I have noticed that when CS[PRES] is set, the clock source is prescaled by 256 before clocking the watchdog counter which allows for longer timeout periods. But I am still wondering whether the watchdog timeout can be set to 10 minutes. If cannot, what is the maximum timeout? Thanks a lot!
1 解答
2,696 次查看
Robin_Shen
WDOG has a programmable16-bit timeout counter. And the clock can be selected by WDOG_CS[CLK] and SIM_LPOCLKS[LPOCLKSEL]. If fixed 256 clock prescaler is enabled, then it's able to achieve 10 minutes timeout.
Robin
在原帖中查看解决方案
2 回复数
2,697 次查看
Robin_Shen
Robin
2,691 次查看
yqs77
Thank you very much for the reply, that helps a lot!
