S32K146 FlexCAN FDEN cannot set 1
2,222 次查看
feng0119
HI,all
I use Flexcan demo, in FLEXCAN_DRV_Init
enable canfd fail,I find FRZ is 1 Freeze Enable,but mcr fden  not be set 1.
I want to know why this is happening.
My English is not good. Thank you!
2,106 次查看
PetrS
try to change FDEN within debugger directly, while in Freeze mode.
And check part number if CAN FD is even implemented.
BR, Petr
2,206 次查看
PetrS
FDEN can be set in Freeze mode only so do you have FRZACK set as well to indicate module is in Freeze mode? Also consider if CAN FD is available for used module, it is not on FlexCAN2 of S32K146.
BR, Petr
2,197 次查看
feng0119
Both FRZACK and FRZ are set 1,but FDEN still cannot be set 1
2,107 次查看
PetrS
BR, Petr
