S32K144EVB schematic Rev.C
7,834 次查看
alisonluan
Hi!
I've a demo-board S32K144EVB-Q100 with Schematic Rev.C.
I've downloaded the following archive "S32K144EVB-SCH-29248-RB1" and inside the Rev goes only to "B".
Could you please send me the Rev.C archive?
Thanks in advance!
7,823 次查看
Robin_Shen
Hi alisonluan,
S32K144EVB schematic Rev.C has sent to you through support ticket.
Robin
9 回复数
7,218 次查看
383826029
Hi Robin_Shen,
I have a demo board “S32K144EVB-Q100 Rev.C”, too.
Could you please send me the schematic Rev.C(SCH-29248 REV C)?
Thanks a lot.
7,214 次查看
Robin_Shen
The label in the bottom part of the EVB maybe incorrect. Please check your board.
7,193 次查看
383826029
And, Could you sent me the schematic REV. B1,please.
Because,I Could not Open the WEB to Download.
7,199 次查看
383826029
你好,
敷铜标的是"170-29248 REV B1", 是以这个为准吗?
7,197 次查看
Robin_Shen
yes
That's the correct schematic version.
7,195 次查看
383826029
Thank you very much.
7,219 次查看
383826029
Hi Robin_Shen,
I have S32K144EVB-Q100 Rev.C too, Could you please send me the schematic Rev.C?
Thanks a lot.
7,824 次查看
Robin_Shen
Hi alisonluan,
Robin
7,206 次查看
383826029
Hi ,
I have a demo board "S32K144EVB-Q100",too.
Could you sent me the schematic Rev.C,please.
Thanks a lot.
