S32K lwip_S32K148
已解决
S32K lwip_S32K148
跳至解决方案
6,204 次查看
Alex19
Hello NXP Community,
I run the the project lwip_S32K148 , it works, I can ping 192.168.0.200 via cmd. But how can I use the driver enet in this project to use ENET_DRV_ReadFrame/ENET_DRV_SendFrame. I need to send/receive the datas by TCP/IP from PC and  after send/receive to another board by UART.
1 解答
6,183 次查看
lukaszadrapa
Hi Aleksandr,
If you want to use TCP IP layer, please check documentation of LWIP stack.
https://www.nongnu.org/lwip/2_0_x/index.html
Notice that LWIP is open source software, so we provide only very limited support.
ENET_DRV... belongs to data link layer which is described in SDK user manual:
c:\NXP\S32DS.3.4\S32DS\software\S32SDK_S32K1XX_RTM_4.0.2\doc\S32SDK_S32K148_UserManual.pdf
Lukas
在原帖中查看解决方案
1 回复
6,184 次查看
lukaszadrapa
Hi Aleksandr,
Lukas
