S32K144- store variable in FlexNVM
Gargi2021
Hi Team,
In S32k144, how can i store variable in FlexNVM and how to read its value. please provide some solution.
Gargi
davidtosenovjan
For detailed description of EEPROM emulation, I would recommend to study AN11983:
https://www.nxp.com/docs/en/application-note/AN11983.pdf
First you need to perform program partition operation to enable EEPROM emulation as shown in the AN11983, section 2.2.2. There is an example code in S32DS SDK (flash_partitioning_s32k144). It needs to be blank new device or with performed mass erase operation before programming the example code.
In this mode FlexRAM acts as access point for EEE memory space, and EEE state machine perform flash erase/program operations to NVM (in this mode assigned to E-flash). From user point of view access to FlexRAM is same as access to ordinary RAM.
