S32K144 bootloader using CAN protocol
emb02
Contributor V
I want to write bootloader for S32K144 using CAN protocol but not getting any reference code.
I'm using S32DS v 3.4 and SDK v 4.0.1.
Can I get example code of CAN bootloader?
lukaszadrapa
Hi @emb02
We provide application note “S32K1xx Firmware updates” discussing A/B swap and using CAN interface:
https://www.nxp.com/docs/en/application-note/AN12323.pdf
https://www.nxp.com/docs/en/application-note-software/AN12323SW.zip
There are SW examples for S32K144 and S32K146.
S32K144 has one read partition on program flash, so it is not possible to update the application while the old application is still running.
S32K146 has more read partitions on program flash, so old application can run during the update.
Lukas
