S32K144:backdoor problem
ZEROOO
I am using the demo of S32k144 about backdoor, but I found that the address 0x40c in the SREC file I generated was 0xBF, but it changed to 0xBE after burning to MCU, the MCU I used was S32K118, the demo content has been transplanted, but it does not seem to be unlocked. It has been unsecure. Can you provide some support?
SREC:
debugger:
ZEROOO
In winidea, you need to configure the following two things to modify the security zone correctly. However, the security zone may be permanently locked after modification.
ZEROOO
