S32K144 Use MCAL PLL configuration
6,263 次查看
Embedded_novice
When I was using MCAL to configure the MCU clock, calling the Mcu_GetPLlStatus () function did not return the PLL_LOCKED signal. I found that the register was not set correctly in this MCU_initClock() function, only PLLEN was set to 1, but PLLSEL and PLLVLD were not set, resulting in the inability to achieve PLL locking.
The MCAL version I am using is SW32K1_S32M24xRTD_R21-11_2.0.0uP04, EB version 29.0.0. I would like to know how to solve this problem, whether it is caused by my configuration or other issues?(At the same time, I would like to know the meaning of the P04 suffix in SW32K1_S32M24xRtD_R21-11_2.0.0uP04).clock_cfg.png
Thanks for help!
6,187 次查看
Senlent
Hi@Embedded_novice
P->PACTH
14 回复数
6,251 次查看
Senlent
Hi@Embedded_novice
The clock switching to PLL is not completed by "Mcu_InitClock".
Please try use the api "Mcu_DistributePllClock".
6,248 次查看
Embedded_novice
This is the order of my API calls,I cannot escape from the while loop because the PLL_LOCKED signal is not set.
标记 (1)
6,244 次查看
Senlent
Hi@Embedded_novice
I can't see any problem with this code. Make sure your current hardware has an external crystal clock.
6,241 次查看
Embedded_novice
The 8MHz clock of the external SOSC is normal.If there are any other suggestions that can be tried, please let me know. Thank you.
6,237 次查看
Senlent
Hi@Embedded_novice
Could you provide me your project's elf file so I can help you test it.
6,233 次查看
Embedded_novice
Thanks for help!
标记 (1)
6,209 次查看
Senlent
Hi@Embedded_novice
Could you please check your McuSystemPll configuration, make sure System PLL is enabled.
6,199 次查看
Embedded_novice
Yes, that's how I did it.Can I send you the EB configuration project to check if there are any configuration errors.EB_CFG.png
6,194 次查看
Senlent
Hi@Embedded_novice
You can refer to the routines we provide.
6,191 次查看
Embedded_novice
Okay, I will first go to the reference configuration items of the routine. Thank you for your help. Also, may I ask what the meaning of P04 after the MACL name is?
6,188 次查看
Senlent
Hi@Embedded_novice
P->PACTH
6,179 次查看
Embedded_novice
I have found the reason. Thank you for your help
6,175 次查看
Senlent
Hi@Embedded_novice
Could you please share the reason why?
6,171 次查看
Embedded_novice
In MCU ->McuLockSettingConfig ->McuSOSCClockConfig, there is an option called "select external reference clock". When I uncheck this option, it will run normally. I personally understand whether this is related to the crystal oscillator I am using. Currently, I am using an external crystal oscillator, and the external clock source requires an internal OSC oscillator to drive my crystal oscillator to start oscillating. When I use an active crystal oscillator, it can start oscillating directly through external voltage without the need for an internal oscillator to provide a source.
%3CLINGO-SUB%20id%3D%22lingo-sub-2042162%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K144%E4%BD%BF%E7%94%A8MCAL%20PLL%E9%85%8D%E7%BD%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2042162%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%BD%93%E6%88%91%E4%BD%BF%E7%94%A8MCAL%E9%85%8D%E7%BD%AEMCU%E6%97%B6%E9%92%9F%E6%97%B6%EF%BC%8C%E8%B0%83%E7%94%A8Mcu_GetPLlStatus%EF%BC%88%EF%BC%89%E5%87%BD%E6%95%B0%E6%B2%A1%E6%9C%89%E8%BF%94%E5%9B%9EPLL_LOCKED%E4%BF%A1%E5%8F%B7%E3%80%82%E6%88%91%E5%8F%91%E7%8E%B0%E5%9C%A8%E8%BF%99%E4%B8%AAMCU_initClock()%E5%87%BD%E6%95%B0%E4%B8%AD%E6%B2%A1%E6%9C%89%E6%AD%A3%E7%A1%AE%E8%AE%BE%E7%BD%AE%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%8C%E5%8F%AA%E8%AE%BE%E7%BD%AE%E4%BA%86PLLEN%E4%B8%BA1%EF%BC%8C%E4%BD%86%E6%98%AF%E6%B2%A1%E6%9C%89%E8%AE%BE%E7%BD%AEPLLSEL%E5%92%8CPLLVLD%EF%BC%8C%E5%AF%BC%E8%87%B4%E6%97%A0%E6%B3%95%E5%AE%9E%E7%8E%B0PLL%E9%94%81%E5%AE%9A%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84MCAL%E7%89%88%E6%9C%AC%E6%98%AFSW32K1_S32M24xRTD_R21-11_2.0.0uP04%EF%BC%8CEB%20%E7%89%88%E6%9C%AC%2029.0.0%E3%80%82%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%E5%A6%82%E4%BD%95%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E6%98%AF%E5%90%A6%E7%94%B1%E6%88%91%E7%9A%84%E9%85%8D%E7%BD%AE%E6%88%96%E5%85%B6%E4%BB%96%E9%97%AE%E9%A2%98%E5%BC%95%E8%B5%B7%EF%BC%9F%EF%BC%88%E5%9C%A8%E5%90%8C%E6%97%B6%EF%BC%8C%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93SW32K1_S32M24xRtD_R21-11_2.0.0uP04%E4%B8%ADP04%E5%90%8E%E7%BC%80%E7%9A%84%E5%90%AB%E4%B9%89%E3%80%82%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22clock_cfg.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22clock_cfg.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F323521iEB0601720F925442%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22clock_cfg.png%22%20alt%3D%22clock_cfg.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E5%B8%AE%E5%8A%A9%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2042472%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AS32K144%E4%BD%BF%E7%94%A8MCAL%20PLL%E9%85%8D%E7%BD%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2042472%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9C%A8MCU-%26gt%3BMcuLockSettingConfig-%26gt%3BMcuSOSCClockConfig%E4%B8%AD%EF%BC%8C%E6%9C%89%E4%B8%80%E4%B8%AA%E5%90%8D%E4%B8%BA%E2%80%9C%E9%80%89%E6%8B%A9%E5%A4%96%E9%83%A8%E5%8F%82%E8%80%83%E6%97%B6%E9%92%9F%E2%80%9D%E7%9A%84%E9%80%89%E9%A1%B9%E3%80%82%E5%BD%93%E6%88%91%E5%8F%96%E6%B6%88%E9%80%89%E4%B8%AD%E6%AD%A4%E9%80%89%E9%A1%B9%E6%97%B6%EF%BC%8C%E5%AE%83%E5%B0%86%E6%AD%A3%E5%B8%B8%E8%BF%90%E8%A1%8C%E3%80%82%E6%88%91%E4%B8%AA%E4%BA%BA%E4%BA%86%E8%A7%A3%E8%BF%99%E6%98%AF%E5%90%A6%E4%B8%8E%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%99%B6%E6%8C%AF%E6%9C%89%E5%85%B3%E3%80%82%E7%9B%AE%E5%89%8D%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%A4%96%E9%83%A8%E6%99%B6%E6%8C%AF%EF%BC%8C%E5%A4%96%E9%83%A8%E6%97%B6%E9%92%9F%E6%BA%90%E9%9C%80%E8%A6%81%E5%86%85%E9%83%A8OSC%E6%8C%AF%E8%8D%A1%E5%99%A8%E6%9D%A5%E9%A9%B1%E5%8A%A8%E6%88%91%E7%9A%84%E6%99%B6%E6%8C%AF%E5%BC%80%E5%A7%8B%E6%8C%AF%E8%8D%A1%E3%80%82%E5%BD%93%E6%88%91%E4%BD%BF%E7%94%A8%E6%9C%89%E6%BA%90%E6%99%B6%E6%8C%AF%E6%97%B6%EF%BC%8C%E5%AE%83%E5%8F%AF%E4%BB%A5%E7%9B%B4%E6%8E%A5%E9%80%9A%E8%BF%87%E5%A4%96%E9%83%A8%E7%94%B5%E5%8E%8B%E5%90%AF%E5%8A%A8%E6%8C%AF%E8%8D%A1%EF%BC%8C%E8%80%8C%E4%B8%8D%E9%9C%80%E8%A6%81%E5%86%85%E9%83%A8%E6%8C%AF%E8%8D%A1%E5%99%A8%E6%8F%90%E4%BE%9B%E6%BA%90%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2042459%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AS32K144%E4%BD%BF%E7%94%A8MCAL%20PLL%E9%85%8D%E7%BD%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2042459%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%40%20%3CSPAN%3EEmbedded_novice%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E8%83%BD%E5%88%86%E4%BA%AB%E4%B8%80%E4%B8%8B%E5%8E%9F%E5%9B%A0%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2042455%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AS32K144%E4%BD%BF%E7%94%A8MCAL%20PLL%E9%85%8D%E7%BD%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2042455%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%88%91%E6%89%BE%E5%88%B0%E5%8E%9F%E5%9B%A0%E4%BA%86%E3%80%82%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2042403%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AS32K144%E4%BD%BF%E7%94%A8MCAL%20PLL%E9%85%8D%E7%BD%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2042403%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%40%20%3CSPAN%3EEmbedded_novice%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EP-%26gt%3BPACTH%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2042396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AS32K144%E4%BD%BF%E7%94%A8MCAL%20PLL%E9%85%8D%E7%BD%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2042396%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%A5%BD%E7%9A%84%EF%BC%8C%E6%88%91%E5%85%88%E4%B8%8A%E4%BE%8B%E7%A8%8B%E7%9A%84%E5%8F%82%E8%80%83%E9%85%8D%E7%BD%AE%E9%A1%B9%E3%80%82%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%AE%E5%8A%A9%E3%80%82%E5%8F%A6%E5%A4%96%E8%AF%B7%E9%97%AEMACL%E5%90%8D%E7%A7%B0%E5%90%8E%E9%9D%A2%E7%9A%84P04%E6%98%AF%E4%BB%80%E4%B9%88%E6%84%8F%E6%80%9D%EF%BC%9F%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2042390%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AS32K144%E4%BD%BF%E7%94%A8MCAL%20PLL%E9%85%8D%E7%BD%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2042390%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%40%20%3CSPAN%3EEmbedded_novice%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%8F%82%E8%80%83%E6%88%91%E4%BB%AC%E6%8F%90%E4%BE%9B%E7%9A%84%E4%BE%8B%E7%A8%8B%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Senlent_1-1739347782755.png%22%20style%3D%22width%3A%20726px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_1-1739347782755.png%22%20style%3D%22width%3A%20726px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F323587i19FAB9310CEFA632%2Fimage-dimensions%2F726x147%3Fv%3Dv2%22%20width%3D%22726%22%20height%3D%22147%22%20role%3D%22button%22%20title%3D%22Senlent_1-1739347782755.png%22%20alt%3D%22Senlent_1-1739347782755.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2042383%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AS32K144%E4%BD%BF%E7%94%A8MCAL%20PLL%E9%85%8D%E7%BD%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2042383%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%88%91%E5%B0%B1%E6%98%AF%E8%BF%99%E4%B9%88%E5%81%9A%E7%9A%84%E3%80%82%E6%88%91%E5%8F%AF%E4%BB%A5%E6%8A%8A%20EB%20%E9%85%8D%E7%BD%AE%E9%A1%B9%E7%9B%AE%E5%8F%91%E7%BB%99%E4%BD%A0%EF%BC%8C%E6%A3%80%E6%9F%A5%E4%B8%80%E4%B8%8B%E6%98%AF%E5%90%A6%E6%9C%89%E9%85%8D%E7%BD%AE%E9%94%99%E8%AF%AF%E5%90%97%EF%BC%9F%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22EB_CFG.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22EB_CFG.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F323584i95EC66A9A42B6678%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22EB_CFG.png%22%20alt%3D%22EB_CFG.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2042328%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AS32K144%E4%BD%BF%E7%94%A8MCAL%20PLL%E9%85%8D%E7%BD%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2042328%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%40%20%3CSPAN%3EEmbedded_novice%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E8%AF%B7%E6%A3%80%E6%9F%A5%E6%82%A8%E7%9A%84%20McuSystemPll%20%E9%85%8D%E7%BD%AE%EF%BC%8C%E7%A1%AE%E4%BF%9D%E7%B3%BB%E7%BB%9F%20PLL%20%E5%B7%B2%E5%90%AF%E7%94%A8%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Senlent_0-1739344902451.png%22%20style%3D%22width%3A%20631px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_0-1739344902451.png%22%20style%3D%22width%3A%20631px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F323563i5A67B84C492FEBE6%2Fimage-dimensions%2F631x374%3Fv%3Dv2%22%20width%3D%22631%22%20height%3D%22374%22%20role%3D%22button%22%20title%3D%22Senlent_0-1739344902451.png%22%20alt%3D%22Senlent_0-1739344902451.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2042264%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AS32K144%E4%BD%BF%E7%94%A8MCAL%20PLL%E9%85%8D%E7%BD%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2042264%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E5%B8%AE%E5%8A%A9%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2042256%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AS32K144%E4%BD%BF%E7%94%A8MCAL%20PLL%E9%85%8D%E7%BD%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2042256%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%40%20%3CSPAN%3EEmbedded_novice%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E8%83%BD%E5%90%A6%E6%8F%90%E4%BE%9B%E6%82%A8%E7%9A%84%E9%A1%B9%E7%9B%AE%E7%9A%84%20elf%20%E6%96%87%E4%BB%B6%E7%BB%99%E6%88%91%EF%BC%8C%E4%BB%A5%E4%BE%BF%E6%88%91%E5%B8%AE%E5%8A%A9%E6%82%A8%E6%B5%8B%E8%AF%95%E5%AE%83%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2042246%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AS32K144%E4%BD%BF%E7%94%A8MCAL%20PLL%E9%85%8D%E7%BD%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2042246%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%A4%96%E9%83%A8SOSC%E7%9A%848MHz%E6%97%B6%E9%92%9F%E6%AD%A3%E5%B8%B8%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%9C%89%E5%85%B6%E4%BB%96%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E7%9A%84%E5%BB%BA%E8%AE%AE%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E3%80%82%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2042243%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AS32K144%E4%BD%BF%E7%94%A8MCAL%20PLL%E9%85%8D%E7%BD%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2042243%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%40%20%3CSPAN%3EEmbedded_novice%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E6%88%91%E7%9C%8B%E4%B8%8D%E5%87%BA%E8%BF%99%E6%AE%B5%E4%BB%A3%E7%A0%81%E6%9C%89%E4%BB%80%E4%B9%88%E9%97%AE%E9%A2%98%E3%80%82%E7%A1%AE%E4%BF%9D%E6%82%A8%E5%BD%93%E5%89%8D%E7%9A%84%E7%A1%AC%E4%BB%B6%E5%85%B7%E6%9C%89%E5%A4%96%E9%83%A8%E6%99%B6%E4%BD%93%E6%97%B6%E9%92%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2042240%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AS32K144%E4%BD%BF%E7%94%A8MCAL%20PLL%E9%85%8D%E7%BD%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2042240%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22clock.png%22%20style%3D%22width%3A%20523px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22clock.png%22%20style%3D%22width%3A%20523px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F323538iB44AC08B1085233F%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22clock.png%22%20alt%3D%22clock.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E6%98%AF%E6%88%91%E7%9A%84API%E8%B0%83%E7%94%A8%E7%9A%84%E9%A1%BA%E5%BA%8F%EF%BC%8C%E6%88%91%E6%97%A0%E6%B3%95%E9%80%80%E5%87%BAwhile%E5%BE%AA%E7%8E%AF%EF%BC%8C%E5%9B%A0%E4%B8%BA%E6%B2%A1%E6%9C%89%E8%AE%BE%E7%BD%AEPLL_LOCKED%E4%BF%A1%E5%8F%B7%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2042221%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AS32K144%E4%BD%BF%E7%94%A8MCAL%20PLL%E9%85%8D%E7%BD%AE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2042221%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%40%20%3CSPAN%3EEmbedded_novice%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E2%80%9CMcu_InitClock%E2%80%9D%E5%B0%9A%E6%9C%AA%E5%AE%8C%E6%88%90%E6%97%B6%E9%92%9F%E5%88%B0PLL%E7%9A%84%E5%88%87%E6%8D%A2%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20api%E2%80%9CMcu_DistributePllClock%E2%80%9D%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
