S32K144 Uart Receive Problem
ソリューションへジャンプ
7,673件の閲覧回数
cabz
Hello Sirs,
 I'm using the S32K144 sample cookbook for UART. The transmit function works fine however the receive doesn't work. I've debugged it a little and the program gets stuck in the line
while((LPUART1->STAT & LPUART_STAT_RDRF_MASK)>>LPUART_STAT_RDRF_SHIFT==0);
You can see in the attached photo, the character 'a' should've been echoed in the terminal, but its not.
The source code :
int main(void)
* Initialization:
WDOG_disable(); /* Disable WDOG */
SOSC_init_8MHz(); /* Initialize system oscilator for 8 MHz xtal */
SPLL_init_160MHz(); /* Initialize SPLL to 160 MHz with 8 MHz SOSC */
NormalRUNmode_80MHz(); /* Init clocks: 80 MHz sysclk & core, 40 MHz bus, 20 MHz flash */
PORT_init(); /* Configure ports */
LPUART1_init(); /* Initialize LPUART @ 9600*/
LPUART1_transmit_string("Running LPUART example\n\r"); /* Transmit char string */
LPUART1_transmit_string("Input character to echo...\n\r"); /* Transmit char string */
while(1)
LPUART1_transmit_char('>'); /* Transmit prompt character*/
LPUART1_receive_and_echo_char(); /* Wait for input char, receive & echo it*/
char LPUART1_receive_char(void) { /* Function to Receive single Char */
static char receive;
/* Wait for received buffer to be full */
PTD->PCOR |= (1 << 0);
receive= LPUART1->DATA; /* Read received data*/
return receive;
void LPUART1_receive_and_echo_char(void) { /* Function to echo received char back */
char send = LPUART1_receive_char(); /* Receive Char */
LPUART1_transmit_char(send); /* Transmit same char back to the sender */
LPUART1_transmit_char('\n'); /* New line */
LPUART1_transmit_char('\r'); /* Return */
void LPUART1_init(void) /* Init. summary: 9600 baud, 1 stop bit, 8 bit format, no parity */
PCC->PCCn[PCC_LPUART1_INDEX] &= ~PCC_PCCn_CGC_MASK; /* Ensure clk disabled for config */
PCC->PCCn[PCC_LPUART1_INDEX] |= PCC_PCCn_PCS(2) /* Clock src=2 (SIRCDIV2_CLK) */
| PCC_PCCn_CGC_MASK; /* Enable clock for LPUART1 regs */
LPUART1->BAUD = LPUART_BAUD_SBR(0x34) | LPUART_BAUD_OSR(15);
LPUART1->CTRL = LPUART_CTRL_RE_MASK | LPUART_CTRL_TE_MASK;
タグ(2)
7,598件の閲覧回数
Senlent
Hi@AllenGlen
ok, you don't need to connect like this, just use USB directly
10 返答(返信)
7,657件の閲覧回数
Senlent
Hi@AllenGlen
You type the character 'a' and the device responds with ">a", isn't that normal?
7,652件の閲覧回数
cabz
no, the pink color signifies I sent it. The black color signifies I received it.
I should receive a black colored 'a' character.
7,646件の閲覧回数
Senlent
7,643件の閲覧回数
cabz
do you think this is hardware problem sir?
I also see the CTS in your terminal is shining... what do you think it means
btw I'm using IAR, and this code is from its samples.
7,633件の閲覧回数
Senlent
Hi@AllenGlen
Very likely, I tested the "S32K144_Project_LPUART" routine, the result is normal
7,620件の閲覧回数
cabz
I've checked the 2 other boards, they also doesn't work...
7,615件の閲覧回数
Senlent
Hi@AllenGlen
Are you using S32K144EVB? The following is the code I tested, I don't see any difference.
 * Copyright (c) 2014 - 2016, Freescale Semiconductor, Inc.
 * Copyright (c) 2016 - 2018, NXP.
 * All rights reserved.
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions are met:
 * 1. Redistributions of source code must retain the above copyright notice,
 *    this list of conditions and the following disclaimer.
 * 2. Redistributions in binary form must reproduce the above copyright notice,
 *    this list of conditions and the following disclaimer in the documentation
 *    and/or other materials provided with the distribution.
 * 3. Neither the name of the copyright holder nor the names of its contributors
 *    may be used to endorse or promote products derived from this software
 *    without specific prior written permission.
 * THIS SOFTWARE IS PROVIDED BY NXP "AS IS" AND ANY EXPRESSED OR
 * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
 * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
 * IN NO EVENT SHALL NXP OR ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT,
 * INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
 * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
 * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
 * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
 * STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING
 * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
 * THE POSSIBILITY OF SUCH DAMAGE.
#include "device_registers.h"	/* include peripheral declarations S32K144 */
#include "LPUART.h"
	PCC->PCCn[PCC_LPUART1_INDEX] |= PCC_PCCn_PCS(0b010)    /* Clock src=2 (SIRCDIV2_CLK) */
	LPUART1->BAUD = LPUART_BAUD_SBR(0x34)  	/* Initialize for 9600 baud, 1 stop: */
                	|LPUART_BAUD_OSR(15);  	/* SBR=52 (0x34): baud divisor = 8M/9600/16 = ~52 */
											/* OSR=15: Over sampling ratio = 15+1=16 */
											/* SBNS=0: One stop bit */
											/* BOTHEDGE=0: receiver samples only on rising edge */
											/* M10=0: Rx and Tx use 7 to 9 bit data characters */
											/* RESYNCDIS=0: Resync during rec'd data word supported */
											/* LBKDIE, RXEDGIE=0: interrupts disable */
											/* TDMAE, RDMAE, TDMAE=0: DMA requests disabled */
											/* MAEN1, MAEN2,  MATCFG=0: Match disabled */
					|LPUART_CTRL_TE_MASK;   	/* Enable transmitter & receiver, no parity, 8 bit char: */
												/* RE=1: Receiver enabled */
												/* TE=1: Transmitter enabled */
												/* PE,PT=0: No hw parity generation or checking */
												/* M7,M,R8T9,R9T8=0: 8-bit data characters*/
												/* DOZEEN=0: LPUART enabled in Doze mode */
												/* ORIE,NEIE,FEIE,PEIE,TIE,TCIE,RIE,ILIE,MA1IE,MA2IE=0: no IRQ*/
												/* TxDIR=0: TxD pin is input if in single-wire mode */
												/* TXINV=0: TRansmit data not inverted */
												/* RWU,WAKE=0: normal operation; rcvr not in statndby */
												/* IDLCFG=0: one idle character */
												/* ILT=0: Idle char bit count starts after start bit */
												/* SBK=0: Normal transmitter operation - no break char */
												/* LOOPS,Rsrc=0: no loop back */
void LPUART1_transmit_char(char send) {    /* Function to Transmit single Char */
	while((LPUART1->STAT & LPUART_STAT_TDRE_MASK)>>LPUART_STAT_TDRE_SHIFT==0);
	/* Wait for transmit buffer to be empty */
	LPUART1->DATA=send;              /* Send data */
void LPUART1_transmit_string(char data_string[])  {  /* Function to Transmit whole string */
	uint32_t i=0;
	while(data_string[i] != '\0')  {           /* Send chars one at a time */
		LPUART1_transmit_char(data_string[i]);
		i++;
	char receive;
	return receive;
7,613件の閲覧回数
cabz
yes sir,
I think my pin connections are also correct, PTC6, PTC7 and 3.3V and GND
7,599件の閲覧回数
Senlent
Hi@AllenGlen
7,583件の閲覧回数
cabz
It works now, the problem must've been the serial wire. Thank you ^3^
