S32K144: Question about DAC
4,156 次查看
sripav-7
I understand that the DAC can be used to provide a reference voltage for use in the comparator. My question is, can I use the DAC to convert the digital data I have on my program into analog form and output it from a physical pin? If yes, please guide me.
Thank you,
Sri Harsha Pavuluri
标记 (1)
3,910 次查看
danielmartynek
The DAC is a sub-block of the comparator and its output is available as an internal signal only, it is not available externally on a pin.
3,911 次查看
danielmartynek
3,910 次查看
sripav-7
Guess I will have to use a PWM DAC then. Thank you!
