S32K144 Incorrect motor direction
已解决
跳至解决方案
4,365 次查看
fanqi1
I am a beginner. I was trying to calibrate hall sensor offset for PMSM motor ( for Field-Oriented Control of PMSM Using Hall Sensor), and it shows "incorrect motor direction". And I know I need to reverse the motor phase connections from ABC to CBA.
 But the question is, due to some reason (where I live is in lockdown, I can just stay at home), I don't have the tool to switch the phase A and phase C connection, is it possible to run FOC control model successfully?
1 解答
4,341 次查看
_Leo_
Hi @fanqi1,
Thank you so much for your interest in our products and for using our community.
You have to do it from the pin assignment (AN12235 Table 3). But as you mention, physically reversing the motor phase connections is the simplest way to get your motor to spin in the right direction.
Hope it helps you. Please let me know if you have more questions about it.
Have a nice day!
在原帖中查看解决方案
2 回复数
4,342 次查看
_Leo_
Hi @fanqi1,
Have a nice day!
4,263 次查看
fanqi1
Thank you so much for your help!
