S32K144 : HSRUN MODE not work with FREERTOS.
cheoljin
Dear,
Can I use FreeRTOS in HSRUN mode?
Because when I changed RUN to HSRUN mode but the result was same.
It runs not 128Mhz  but 48Mhz.
Please let me know how can I change to HSRUN mode with FREERTOS.
Thanks for your help in advance.
danielmartynek
Hello @cheoljin,
How did you configure the SPLL and the HSRUN mode?
Can you double check the SCG registers after clock initialization?
Once you switch to the HSRUN mode, you should see SMC_PMSTAT[PMSTAT] = 0b1000_0000 (Current power mode is HSRUN).
