#S32K144 Cache write Test
joshua9264
##S32K144 support modifying cache values? Why is it that after I modify a value, reading the same address still returns the original value? Additionally, can the cache's parity bit be tested?thanks
Tags (3)
danielmartynek
joshua9264
OK,thank you,i will have a test
danielmartynek
Hi @joshua9264,
It is technically possible to change the cache value through the LMEN registers.
Let me create a simple test project.
BR, Daniel
