S32K118Q048 LIN Stack
yousefdessouki123
I’m working with the LIN stack on an NXP S32K118Q048 EVB to set up a LIN network using an .ldf file. When I upload the .ldf for parsing, I encounter terminal errors stating that some frames are missing from the configurable_frames section in the Node_attributes.
Upon investigation, I found that the missing frames are unconditional frames mapped under a sporadic frame. Interestingly, the error disappears if I explicitly add the sporadic frame name to the configurable_frames list — which seems odd, since sporadic frame names are typically referenced in the schedule table, not in the node configuration. I have doubled checked the LIN 2.0 protocol revision and could not find an explanation for this error that could help me.
For context, I'm using the LIN 2.0 protocol.
danielmartynek
Hi @yousefdessouki123,
Which S32DS IDE version, RTD version and LIN Stack version do you use?
Thank you
%3CLINGO-SUB%20id%3D%22lingo-sub-2138297%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K118Q048%20LIN%20Stack%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2138297%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%3EHi%2C%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%3EI%E2%80%99m%20working%20with%20the%20LIN%20stack%20on%20an%20NXP%20S32K118Q048%20EVB%20to%20set%20up%20a%20LIN%20network%20using%20an%20.ldf%20file.%20When%20I%20upload%20the%20.ldf%20for%20parsing%2C%20I%20encounter%20terminal%20errors%20stating%20that%20some%20frames%20are%20missing%20from%20the%20configurable_frames%20section%20in%20the%20Node_attributes.%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%3EUpon%20investigation%2C%20I%20found%20that%20the%20missing%20frames%20are%20unconditional%20frames%20mapped%20under%20a%20sporadic%20frame.%20Interestingly%2C%20the%20error%20disappears%20if%20I%20explicitly%20add%20the%20sporadic%20frame%20name%20to%20the%20configurable_frames%20list%20%E2%80%94%20which%20seems%20odd%2C%20since%20sporadic%20frame%20names%20are%20typically%20referenced%20in%20the%20schedule%20table%2C%20not%20in%20the%20node%20configuration.%20I%20have%20doubled%20checked%20the%20LIN%202.0%20protocol%20revision%20and%20could%20not%20find%20an%20explanation%20for%20this%20error%20that%20could%20help%20me.%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%3EFor%20context%2C%20I'm%20using%20the%20LIN%202.0%20protocol.%3C%2FFONT%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CFONT%20face%3D%22arial%2Chelvetica%2Csans-serif%22%3ERegards%2C%3C%2FFONT%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2139384%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K118Q048%20LIN%20Stack%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2139384%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F251159%22%20target%3D%22_blank%22%3E%40yousefdessouki123%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EWhich%20S32DS%20IDE%20version%2C%20RTD%20version%20and%20LIN%20Stack%20version%20do%20you%20use%3F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThank%20you%3C%2FP%3E%3C%2FLINGO-BODY%3E
