S32K116 support bootloader by LIN communication
2,909 次查看
ganeshvaka2
Hello all
we are working on LIN Based Bootloader.as per nxp unified bootloader framework Guideline we are integrated cod and I have an example here about LIN receiving and sending messages, but there is a question. When receiving the information of the master node as a slave node, it will not enter the callback function and cannot receive the information sent by the host. When receiving information as the master node, if you hit a breakpoint where the callback function receives the PID_OK, and then continue to run, you will no longer enter the callback function. What is the reason for this?
Thank you
Ganesh Babu Vaka
0 回复数
