S32K MCAL LIN question
1,135 次查看
ykp3036
标记 (1)
1,133 次查看
ykp3036
is the row282 for the LIN-SLAVE-TX-RESPONSE?   why only send 1 byte?   not 8 bytes?
1,042 次查看
PetrS
LIN driver process frame in byte to byte manner using interrupt processing, after byte is send/received. So after LIN header is received, response is started by sending first data byte and next are processed using driver interrupt.
BR, Petr
