S32K Csec Module
S32K Csec Module
3,125 次查看
wanglijun
I have a question about the CSEC module:
In the CSEC module, there are some user keys, is it possible to change only one key value to FF, other keys not changed?
Thank you!
5 回复数
3,115 次查看
wanglijun
Thank you for the reply.
I have another question: If one key value is updated to FF with all the bytes.
Is it possible by csec?
Thank you!
3,103 次查看
wanglijun
Thank you for the feedback.
About the security debug, there is limit for the backdoor key. All 0s or all 1s cannot be used as the backdoor key value.
So they are different about the application rule.
3,106 次查看
lukaszadrapa
There are no restrictions given by CSEc module and by SHE specification. Any value can be used.
Lukas
3,101 次查看
wanglijun
I see the security debug, there is limit for the backdoor key. All 0s or all 1s cannot be used as the backdoor key value.
So there is different application rule.
3,119 次查看
lukaszadrapa
yes, it is possible to update one key only.
https://www.nxp.com/webapp/Download?colCode=AN5401&location=null
https://www.nxp.com/webapp/Download?colCode=AN5401SW&location=null
Take a look at section 4.2.2 Updating key. SW example is also included.
Lukas
