S32DS installation error
dramatic
请帮我解决这个问题。我正在使用 win11 并计划安装 S32DS 3.4。下面的文件包含我遇到的问题的图片和日志。
IsaulO
Hi @dramatic ,
This issue could be related to different situations, please verify that you have the minimum requirements and check the following:
1)Enough space in Disk C: and Driver E:
2)Run the .exe as administrator
If you still have the problem, please try the solution proposed in the following thread: Solved: Re: S32DS for Arm v2.2 Installation is not Starting (Windows 11) - NXP Community
BR,
IsaulO.
IsaulO
Hi @dramatic ,
BR,
IsaulO.
dramatic
thank
dramatic
1) Ensure you have administrator access on your PC
2) Select the option 'Windows 7 compatibility mode' on the file properties for the install file
Both of these conditions were met at the time of installation
%3CLINGO-SUB%20id%3D%22lingo-sub-2050543%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3ES32DS%20installation%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2050543%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EPlease%20help%20me%20to%20solve%20this%20problem.%20I%20am%20using%20win11%20and%20planning%20to%20install%20S32DS%203.4.%20The%20file%20below%20contains%20pictures%20and%20logs%20of%20the%20problem%20I%20am%20facing.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2052430%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32DS%20installation%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2052430%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ethank%3C%2FLINGO-BODY%3E
