S32DS build report error“Ld error: Cannot run program "make": Launching failed”
3,116件の閲覧回数
xuehai573
i installed S32DS version 2.2, when i create one new project,then build,below error was reported“Ld error: Cannot run program "make": Launching failed, Program "make" not found in PATH”. Can anyone give some suggestion to resolve this issue?
2 返答(返信)
3,099件の閲覧回数
VaneB
Hi @xuehai573
The problem could be the workspace, this should be replaced each time a new version of S32 Design Studio is used. The old workspace will contain settings which work only for the version of S32 Design Studio from which it created it.
B.R.
VaneB
3,109件の閲覧回数
xuehai573
change one new workspace then fix this issue. hope can help a little.
